HI all
How to test the hid transmission rate between DK board and PC?
Can you provide an example
Thank you.
HI all
Thank you.
Hi
Since the level of details in this case is pretty scarce, here are the 3 most common HID sample projects we have available in the nRF Connect SDK:
Let me know if you're struggling to find what you're looking for.
Simon
Hi Simon
I'm working on SDK nRF5_SDK_17.1.0_ddde560, my project is hid(no mouse or keyboard)+nus
Reference examples are as follows:
nRF5_SDK_17.1.0_ddde560\examples\peripheral\usbd_ble_uart
nRF5_SDK_17.1.0_ddde560\examples\peripheral\usbd_hid_generic
#define APP_USBD_HID_GENERIC_REPORT_DSC() { \
0x06, 0x0A, 0xFF, /* Usage Page (Vendor-Defined 11) */ \
0x09, 0x01, /* Usage (Vendor-Defined 11) */ \
0xA1, 0x01, /* Collection (Application) */ \
0x85, 0x02, /* REPORT_ID (mouse) */ \
0x09, 0x02, /* Usage (Vendor-Defined 1) */ \
0x75, 0x08, /* Report Size (8) */ \
0x95, 0x0b, /* Report Count (20) */ \
0x15, 0x00, /* Usage Minimum (0) */ \
0x26, 0xFF, 0x00, /* Usage Maximum (255) */ \
0x81, 0x02, /* Output (Data,Var,Abs) */ \
0x09, 0x03, /* Usage (Vendor-Defined 3) */ \
0x95, 0x20, /* Report Count (32) */ \
0x15, 0x00, /* Logical Minimum (0) */ \
0x26, 0xFF, 0x00, /* Logical Maximum (255) */ \
0x91, 0x02, /* input (Data,Var,Abs) */ \
0xC0 /* END_COLLECTION */ \
APP_USBD_HID_GENERIC_SUBCLASS_REPORT_DESC(generic_desc, APP_USBD_HID_GENERIC_REPORT_DSC());
static const app_usbd_hid_subclass_desc_t * generic_reps[] = {&generic_desc};
/*lint -save -e26 -e64 -e123 -e505 -e651*/
* @brief Global HID generic instance
/*lint -restore*/
APP_USBD_HID_GENERIC_GLOBAL_DEF(m_app_hid_generic,
HID_GENERIC_INTERFACE,
hid_user_ev_handler,
GENERIC_ENDPOINT_LIST(),
generic_reps,
GENERIC_REPORT_IN_QUEUE_SIZE,
GENERIC_REPORT_OUT_MAXSIZE,
GENERIC_REPORT_FEATURE_MAXSIZE,
APP_USBD_HID_SUBCLASS_NONE,
APP_USBD_HID_PROTO_GENERIC);
Now I have another problem: when I want to send data to the dK through Bluetooth on my phone, I find that the Nus handle received the data, but when I call the app_usbd_hid_generic_in_report_set, it always returns a failure. I debugged and found that after I inserted the USB, about 2 seconds later, a suspend occurred,
<info>app: APP_ USBD_ EVT_ DRV_ SUSPEND
I am stuck in this place now and I hope you can help me,thank you.
HuangTao
Hi
Are you able to see what the application does before the USB is suspended? What device are you connecting the USB (J3 header on the DK) to on your device? Usually it's the USB host that suspends a USB device, so I would guess it is the PC you connect to that put the nRF into this state.
Simon
Hi Simonr
Thank you very much for your reply
I connected my DK board to my laptop. At this time, the laptop did not have a screen, but after 2-3 seconds of connecting, a suspend occurred
* Copyright (c) 2017 - 2021, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* Nordic Semiconductor ASA integrated circuit.
* engineered, decompiled, modified and/or disassembled.
/** @file
* @defgroup usbd_ble_uart_example main.c
* @ingroup usbd_ble_uart_example
* @brief USBD CDC ACM over BLE application main file.
* This file contains the source code for a sample application that uses the Nordic UART service
* and USBD CDC ACM library.
* This application uses the @ref srvlib_conn_params module.
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "ble_hci.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "nrf_ble_gatt.h"
#include "app_timer.h"
#include "ble_nus.h"
#include "app_uart.h"
#include "bsp_btn_ble.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "nrf_drv_usbd.h"
#include "nrf_drv_clock.h"
#include "nrf_gpio.h"
#include "nrf_delay.h"
#include "nrf_drv_power.h"
#include "app_error.h"
#include "app_util.h"
#include "app_usbd_core.h"
#include "app_usbd.h"
#include "app_usbd_string_desc.h"
#include "app_usbd_cdc_acm.h"
#include "app_usbd_serial_num.h"
#include <stdint.h>
#include <stdbool.h>
#include <stddef.h>
#include "nrf.h"
#include "app_usbd_hid_generic.h"
#include "app_usbd_hid_mouse.h"
#include "app_usbd_hid_kbd.h"
#include "bsp.h"
#include "bsp_cli.h"
#include "nrf_cli.h"
#include "nrf_cli_uart.h"
/* GPIO used as LED & buttons in this example */
#define LED_BLE_NUS_CONN (BSP_BOARD_LED_0)
#define LED_BLE_NUS_RX (BSP_BOARD_LED_1)
#define LED_USB_START (BSP_BOARD_LED_2)
#define LED_HID_REP_IN (BSP_BOARD_LED_3)
#define LED_BLINK_INTERVAL 800
APP_TIMER_DEF(m_blink_ble);
APP_TIMER_DEF(m_blink_cdc);
* @brief App timer handler for blinking the LEDs.
* @param p_context LED to blink.
void blink_handler(void * p_context)
bsp_board_led_invert((uint32_t) p_context);
#define ENDLINE_STRING "\r\n"
// USB DEFINES START
static bool m_report_pending;
* @brief Enable USB power detection
#ifndef USBD_POWER_DETECTION
#define USBD_POWER_DETECTION true
* @brief HID generic class interface number.
#define HID_GENERIC_INTERFACE 0
* @brief HID generic class endpoint number.
#define HID_GENERIC_EPIN NRF_DRV_USBD_EPIN3
#define HID_GENERIC_EPOUT NRF_DRV_USBD_EPOUT3
* @brief Number of reports defined in report descriptor.
#define REPORT_IN_QUEUE_SIZE 1
* @brief Size of maximum output report. HID generic class will reserve
* this buffer size + 1 memory space.
* Maximum value of this define is 63 bytes. Library automatically adds
* one byte for report ID. This means that output report size is limited
* to 64 bytes.
#define REPORT_OUT_MAXSIZE 63
* @brief Feature report maximum size. HID generic class will reserve
#define REPORT_FEATURE_MAXSIZE 31
#define GENERIC_REPORT_FEATURE_MAXSIZE 63
* @brief HID generic class endpoints count.
#define HID_GENERIC_EP_COUNT 1
* @brief List of HID generic class endpoints.
#define ENDPOINT_LIST() \
HID_MOUSE_EPIN \
#define GENERIC_ENDPOINT_LIST() \
HID_GENERIC_EPIN, \
HID_GENERIC_EPOUT \
#define GENERIC_REPORT_IN_QUEUE_SIZE 63
#define GENERIC_REPORT_OUT_MAXSIZE 63
#if 0
#else
0x05, 0x8c, /* USAGE_PAGE (ST Page) */ \
0x09, 0x01, /* USAGE (Demo Kit) */ \
0xa1, 0x01, /* COLLECTION (Application) */\
0x09, 0x03, /* USAGE ID - Vendor defined */ \
0x15, 0x00, /* LOGICAL_MINIMUM (0) */ \
0x26, 0x00, 0xFF, /* LOGICAL_MAXIMUM (255) */\
0x75, 0x08, /* REPORT_SIZE (8bit) */\
0x95, 0x3C, /* REPORT_COUNT (64Byte) */\
0x81, 0x02, /* Input (Data,Var,Abs,NWrp,Lin,Pref,NNul,Bit) */\
0x09, 0x04, /* Usage (Consumer Control) */\
0x15, 0x00, /* Logical Minimum (0) */\
0x26, 0x00, 0xFF, /* Logical Maximum (-1) */\
0x75, 0x08, /* Report Size (8) */\
0x95, 0x3C, /* Report Count (40) */\
0x91, 0x02, /* Output (Data,Var,Abs,NWrp,Lin,Pref,NNul,NVol,Bit) */\
0xC0 /* End Collection */\
* @brief User event handler.
static void hid_user_ev_handler(app_usbd_class_inst_t const * p_inst,
app_usbd_hid_user_event_t event);
* @brief Reuse HID mouse report descriptor for HID generic class
//APP_USBD_HID_GENERIC_SUBCLASS_REPORT_DESC(mouse_desc,APP_USBD_HID_MOUSE_REPORT_DSC_BUTTON(2));
//static const app_usbd_hid_subclass_desc_t * reps[] = {&mouse_desc};
/*lint -restore*/
generic_reps,
// USB DEFINES END
// BLE DEFINES START
#define APP_BLE_CONN_CFG_TAG 1 /**< A tag identifying the SoftDevice BLE configuration. */
#define APP_FEATURE_NOT_SUPPORTED BLE_GATT_STATUS_ATTERR_APP_BEGIN + 2 /**< Reply when unsupported features are requested. */
#define DEVICE_NAME "Nordic_HID_BLE_UART" /**< Name of device. Will be included in the advertising data. */
#define NUS_SERVICE_UUID_TYPE BLE_UUID_TYPE_VENDOR_BEGIN /**< UUID type for the Nordic UART Service (vendor specific). */
#define APP_BLE_OBSERVER_PRIO 3 /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_ADV_INTERVAL 64 /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
#define APP_ADV_DURATION 18000 /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define MIN_CONN_INTERVAL MSEC_TO_UNITS(30, UNIT_1_25_MS) /**< Minimum acceptable connection interval (20 ms). Connection interval uses 1.25 ms units. */
#define MAX_CONN_INTERVAL MSEC_TO_UNITS(30, UNIT_1_25_MS) /**< Maximum acceptable connection interval (75 ms). Connection interval uses 1.25 ms units. */
#define SLAVE_LATENCY 0 /**< Slave latency. */
#define CONN_SUP_TIMEOUT MSEC_TO_UNITS(4000, UNIT_10_MS) /**< Connection supervisory timeout (4 seconds). Supervision Timeout uses 10 ms units. */
#define FIRST_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(5000) /**< Time from initiating an event (connect or start of notification) to the first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(30000) /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT 3 /**< Number of attempts before giving up the connection parameter negotiation. */
#define DEAD_BEEF 0xDEADBEEF /**< Value used as error code on stack dump. Can be used to identify stack location on stack unwind. */
#define UART_TX_BUF_SIZE 256 /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE 256 /**< UART RX buffer size. */
BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT); /**< BLE NUS service instance. */
NRF_BLE_GATT_DEF(m_gatt); /**< GATT module instance. */
BLE_ADVERTISING_DEF(m_advertising); /**< Advertising module instance. */
static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID; /**< Handle of the current connection. */
static uint16_t m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3; /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
static ble_uuid_t m_adv_uuids[] = /**< Universally unique service identifier. */
static char m_nus_data_array[BLE_NUS_MAX_DATA_LEN];
APP_TIMER_DEF(m_timer_speed);
uint8_t m_data_array[6300];
uint32_t m_len_sent;
uint32_t m_cnt_7ms;
// BLE DEFINES END
* @brief Function for assert macro callback.
* how your product is supposed to react in case of an assert.
* @param[in] line_num Line number of the failing ASSERT call.
* @param[in] p_file_name File name of the failing ASSERT call.
/** @brief Function for initializing the timer module. */
static void timers_init(void)
err_code = app_timer_create(&m_blink_ble, APP_TIMER_MODE_REPEATED, blink_handler);
err_code = app_timer_create(&m_blink_cdc, APP_TIMER_MODE_REPEATED, blink_handler);
* @brief Function for the GAP initialization.
* @details This function sets up all the necessary GAP (Generic Access Profile) parameters of
* the device. It also sets the permissions and appearance.
uint32_t err_code;
ble_gap_conn_params_t gap_conn_params;
strlen(DEVICE_NAME));
gap_conn_params.slave_latency = SLAVE_LATENCY;
gap_conn_params.conn_sup_timeout = CONN_SUP_TIMEOUT;
* @brief Function for handling the data from the Nordic UART Service.
* @details This function processes the data received from the Nordic UART BLE Service and sends
* it to the USBD CDC ACM module.
* @param[in] p_evt Nordic UART Service event.
ret_code_t ret;
bsp_board_led_invert(LED_BLE_NUS_RX);
NRF_LOG_DEBUG("Received data from BLE NUS. Writing data on CDC ACM.");
memcpy(m_nus_data_array, p_evt->params.rx_data.p_data, p_evt->params.rx_data.length);
// Add endline characters
uint16_t length = p_evt->params.rx_data.length;
if (length + sizeof(ENDLINE_STRING) < BLE_NUS_MAX_DATA_LEN)
memcpy(m_nus_data_array + length, ENDLINE_STRING, sizeof(ENDLINE_STRING));
length += sizeof(ENDLINE_STRING);
// Send data through CDC ACM
//if(ret != NRF_SUCCESS)
NRF_LOG_INFO("BLE NUS data received: %s", m_nus_data_array);
ret = app_usbd_hid_generic_in_report_set(&m_app_hid_generic, m_nus_data_array, 2);
if(ret == NRF_SUCCESS)
NRF_LOG_INFO("send success");
else if (p_evt->type == BLE_NUS_EVT_COMM_STARTED)
//APP_ERROR_CHECK(app_timer_start(m_timer_speed, APP_TIMER_TICKS(7),NULL));
else if (p_evt->type == BLE_NUS_EVT_COMM_STOPPED)
//APP_ERROR_CHECK(app_timer_stop(m_timer_speed));
//m_len_sent = 0;
//m_cnt_7ms = 0;
else if (p_evt->type == BLE_NUS_EVT_TX_RDY)
#if 0
#ifndef APP_QUEUE
ret_code_t err_code;
uint16_t length;
//sending code lines
length = m_ble_nus_max_data_len;
do
if(m_cnt_7ms == 143)
err_code = ble_nus_data_send(&m_nus, m_data_array, &length, m_conn_handle);
if ( (err_code != NRF_ERROR_INVALID_STATE) && (err_code != NRF_ERROR_RESOURCES) &&
(err_code != NRF_ERROR_NOT_FOUND) )
if (err_code == NRF_SUCCESS)
m_len_sent += length;
m_data_array[0]++;
m_data_array[length-1]++;
} while (err_code == NRF_SUCCESS);
#else
ble_data_send_with_queue();
/** @brief Function for initializing services that will be used by the application. */
uint32_t err_code;
ble_nus_init_t nus_init;
* @brief Function for handling errors from the Connection Parameters module.
* @param[in] nrf_error Error code containing information about what went wrong.
APP_ERROR_HANDLER(nrf_error);
/** @brief Function for initializing the Connection Parameters module. */
uint32_t err_code;
cp_init.p_conn_params = NULL;
cp_init.next_conn_params_update_delay = NEXT_CONN_PARAMS_UPDATE_DELAY;
cp_init.max_conn_params_update_count = MAX_CONN_PARAMS_UPDATE_COUNT;
cp_init.start_on_notify_cccd_handle = BLE_GATT_HANDLE_INVALID;
cp_init.disconnect_on_fail = true;
cp_init.evt_handler = NULL;
cp_init.error_handler = conn_params_error_handler;
* @brief Function for putting the chip into sleep mode.
* @note This function does not return.
// Prepare wakeup buttons.
/** @brief Function for starting advertising. */
* @brief Function for handling advertising events.
* @details This function is called for advertising events which are passed to the application.
* @param[in] ble_adv_evt Advertising event.
uint32_t err_code;
switch (ble_adv_evt)
case BLE_ADV_EVT_FAST:
err_code = app_timer_start(m_blink_ble,
APP_TIMER_TICKS(LED_BLINK_INTERVAL),
(void *) LED_BLE_NUS_CONN);
case BLE_ADV_EVT_IDLE:
NRF_LOG_INFO("Advertising timeout, restarting.")
advertising_start();
* @brief Function for handling BLE events.
* @param[in] p_ble_evt Bluetooth stack event.
* @param[in] p_context Unused.
uint32_t err_code;
case BLE_GAP_EVT_CONNECTED:
NRF_LOG_INFO("BLE NUS connected");
err_code = app_timer_stop(m_blink_ble);
bsp_board_led_on(LED_BLE_NUS_CONN);
NRF_LOG_INFO("BLE NUS disconnected");
ble_gap_phys_t const phys =
.rx_phys = BLE_GAP_PHY_AUTO,
.tx_phys = BLE_GAP_PHY_AUTO,
} break;
// Pairing not supported.
case BLE_GAP_EVT_DATA_LENGTH_UPDATE_REQUEST:
ble_gap_data_length_params_t dl_params;
// Clearing the struct will effectively set members to @ref BLE_GAP_DATA_LENGTH_AUTO.
memset(&dl_params, 0, sizeof(ble_gap_data_length_params_t));
err_code = sd_ble_gap_data_length_update(p_ble_evt->evt.gap_evt.conn_handle, &dl_params, NULL);
} break;
case BLE_GATTC_EVT_TIMEOUT:
case BLE_GATTS_EVT_TIMEOUT:
case BLE_EVT_USER_MEM_REQUEST:
err_code = sd_ble_user_mem_reply(p_ble_evt->evt.gattc_evt.conn_handle, NULL);
case BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST:
ble_gatts_evt_rw_authorize_request_t req;
ble_gatts_rw_authorize_reply_params_t auth_reply;
req = p_ble_evt->evt.gatts_evt.params.authorize_request;
if (req.type != BLE_GATTS_AUTHORIZE_TYPE_INVALID)
if ((req.request.write.op == BLE_GATTS_OP_PREP_WRITE_REQ) ||
(req.request.write.op == BLE_GATTS_OP_EXEC_WRITE_REQ_NOW) ||
(req.request.write.op == BLE_GATTS_OP_EXEC_WRITE_REQ_CANCEL))
if (req.type == BLE_GATTS_AUTHORIZE_TYPE_WRITE)
auth_reply.type = BLE_GATTS_AUTHORIZE_TYPE_WRITE;
auth_reply.type = BLE_GATTS_AUTHORIZE_TYPE_READ;
auth_reply.params.write.gatt_status = APP_FEATURE_NOT_SUPPORTED;
err_code = sd_ble_gatts_rw_authorize_reply(p_ble_evt->evt.gatts_evt.conn_handle,
&auth_reply);
} break; // BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST
// No implementation needed.
* @brief Function for the SoftDevice initialization.
* @details This function initializes the SoftDevice and the BLE event interrupt.
uint32_t ram_start = 0;
// Enable BLE stack.
/** @brief Function for handling events from the GATT library. */
void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
p_gatt->att_mtu_desired_central,
p_gatt->att_mtu_desired_periph);
/** @brief Function for initializing the GATT library. */
void gatt_init(void)
err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, 64);
* @brief Class specific event handler.
* @param p_inst Class instance.
* @param event Class specific event.
NRF_LOG_INFO("hid_user_ev_handler=%d", event);
switch (event)
case APP_USBD_HID_USER_EVT_OUT_REPORT_READY:
/* No output report defined for this example.*/
size_t size;
uint8_t *ptr;
static int pack_cnt = 0;
//NRF_LOG_INFO("APP_USBD_HID_USER_EVT_OUT_REPORT_READY");
ptr = (uint8_t *)app_usbd_hid_generic_out_report_get(&m_app_hid_generic, &size);
//NRF_LOG_INFO("hid receive size=%d", size);
//for(int i=0;i<size;i++)
//NRF_LOG_INFO("[USB_RX] %02x", ptr[63]);
if(pack_cnt == 0)
char str[64] = {0};
snprintf(str, 64, "start: %d", pack_cnt);
app_usbd_hid_generic_in_report_set(&m_app_hid_generic, str, 60);
//ble_nus_data_send(&m_nus, ptr, (uint16_t*)&size, m_conn_handle);
if(++pack_cnt == 64)
char str[64] = {0};
snprintf(str, 64, "pack_cnt: %d", pack_cnt);
pack_cnt = 0;
//NRF_LOG_INFO("size=%d", size);
size=60;
err_code = ble_nus_data_send(&m_nus, ptr, (uint16_t*)&size, m_conn_handle);
m_len_sent += size;
if (m_cnt_7ms == 143)
NRF_LOG_INFO("==**Speed: %d B/s**==", m_len_sent);
//NRF_LOG_INFO("<DEBUG> [USB_RX] %02x %02x %02x %02x %02x %02x %02x %02x %02x %02x %02x %02x %02x %02x %02x|%d\r\n",
//ptr[0], ptr[1], ptr[2], ptr[3], ptr[4], ptr[5], ptr[6], ptr[7], ptr[8], ptr[9], ptr[10], ptr[11], ptr[12], ptr[13], ptr[14], size);
if(ptr);
// xxxx(ptr, size);
//ASSERT(0);
case APP_USBD_HID_USER_EVT_IN_REPORT_DONE:
NRF_LOG_INFO("APP_USBD_HID_USER_EVT_IN_REPORT_DONE");
m_report_pending = false;
//hid_generic_mouse_process_state();
bsp_board_led_invert(LED_HID_REP_IN);
UNUSED_RETURN_VALUE(hid_generic_clear_buffer(p_inst));
case APP_USBD_HID_USER_EVT_SET_BOOT_PROTO:
NRF_LOG_INFO("SET_BOOT_PROTO");
case APP_USBD_HID_USER_EVT_SET_REPORT_PROTO:
NRF_LOG_INFO("SET_REPORT_PROTO");
* @brief USBD library specific event handler.
* @param event USBD library event.
static void usbd_user_ev_handler(app_usbd_event_type_t event)
//bool ret=false;
switch (event)
case APP_USBD_EVT_DRV_SOF:
case APP_USBD_EVT_DRV_RESET:
NRF_LOG_INFO("APP_USBD_EVT_DRV_RESET");
case APP_USBD_EVT_DRV_SUSPEND:
NRF_LOG_INFO("APP_USBD_EVT_DRV_SUSPEND");
//ret = app_usbd_wakeup_req();
//NRF_LOG_INFO("app_usbd_wakeup_req ret = %d", ret);
//app_usbd_suspend_req(); // Allow the library to put the peripheral into sleep mode
bsp_board_leds_off();
case APP_USBD_EVT_DRV_RESUME:
NRF_LOG_INFO("APP_USBD_EVT_DRV_RESUME");
bsp_board_led_on(LED_USB_START);
case APP_USBD_EVT_STARTED:
NRF_LOG_INFO("APP_USBD_EVT_STARTED");
case APP_USBD_EVT_STOPPED:
NRF_LOG_INFO("APP_USBD_EVT_STOPPED");
app_usbd_disable();
case APP_USBD_EVT_POWER_DETECTED:
NRF_LOG_INFO("USB power detected");
if (!nrf_drv_usbd_is_enabled())
app_usbd_enable();
case APP_USBD_EVT_POWER_REMOVED:
NRF_LOG_INFO("USB power removed");
app_usbd_stop();
case APP_USBD_EVT_POWER_READY:
NRF_LOG_INFO("USB ready");
app_usbd_start();
* @brief Function for handling events from the BSP module.
* @param[in] event Event generated by button press.
uint32_t err_code;
NRF_LOG_INFO("bsp_event_handler=%d", event);
switch (event)
case BSP_EVENT_SLEEP:
sleep_mode_enter();
case BSP_EVENT_DISCONNECT:
err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
case BSP_EVENT_WHITELIST_OFF:
/** @brief Function for initializing the Advertising functionality. */
uint32_t err_code;
ble_advertising_init_t init;
init.advdata.name_type = BLE_ADVDATA_FULL_NAME;
init.advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
init.srdata.uuids_complete.p_uuids = m_adv_uuids;
init.config.ble_adv_fast_enabled = true;
init.config.ble_adv_fast_timeout = APP_ADV_DURATION;
/** @brief Function for initializing buttons and LEDs. */
static void buttons_leds_init(void)
uint32_t err_code = bsp_init(BSP_INIT_LEDS, bsp_event_handler);
/** @brief Function for initializing the nrf_log module. */
static void log_init(void)
static ret_code_t idle_handle(app_usbd_class_inst_t const * p_inst, uint8_t report_id)
switch (report_id)
case 0:
NRF_LOG_INFO("idle_handle");
#if 1
uint8_t report[] = {0xBE, 0xEF};
return app_usbd_hid_generic_idle_report_set(
&m_app_hid_generic,
report,
sizeof(report));
return NRF_ERROR_NOT_SUPPORTED;
// USB CODE END
static void throughput_timer_handler(void * p_context)
#ifndef APP_QUEUE
//the snippet used to test data throughput only. no queue is involved
uint16_t length;
m_cnt_7ms++;
do
m_data_array[0]++;
//calculate speed every 1 second
//m_len_sent = 0;
//m_cnt_7ms = 0;
//m_cnt_7ms = 0;
m_len_sent = 0;
m_data_array[0] = 0;
m_data_array[length-1] = 0;
NRF_LOG_INFO("PacketNo.: %d == Time: %d *7ms", m_data_array[0], m_cnt_7ms);
#else
//the snippet simulate a real application scenairo. Queue is involved.
ret_code_t err_code1, err_code2;
buffer_t buf;
static uint8_t val = 0;
//produce the data irregard of BLE activity
m_data_array[(m_cnt_7ms%10)*420] = val++;
m_data_array[(m_cnt_7ms%10)*420+210] = val++;
//put the data into a queue to cache them
buf.p_data = &m_data_array[(m_cnt_7ms%10)*420];
buf.length = MIN(m_ble_nus_max_data_len,210);
err_code1 = nrf_queue_push(&m_buf_queue, &buf);
//APP_ERROR_CHECK(err_code1); //it may return NRF_ERROR_NO_MEM. we skip this error
buf.p_data = &m_data_array[(m_cnt_7ms%10)*420+210];
err_code2 = nrf_queue_push(&m_buf_queue, &buf);
//APP_ERROR_CHECK(err_code2); //it may return NRF_ERROR_NO_MEM. we skip this error
if(err_code1 == NRF_ERROR_NO_MEM || err_code2 == NRF_ERROR_NO_MEM)
NRF_LOG_INFO("Drop");
m_cnt_7ms++;
m_cnt_7ms = 0;
m_len_sent = 0;
//NRF_LOG_INFO("Time: %d *7ms", m_cnt_7ms);
void throughput_test()
err_code = app_timer_create(&m_timer_speed, APP_TIMER_MODE_REPEATED, throughput_timer_handler);
/** @brief Application main function. */
ret_code_t ret;
static const app_usbd_config_t usbd_config = {
.ev_state_proc = usbd_user_ev_handler
// Initialize.
log_init();
timers_init();
buttons_leds_init();
app_usbd_serial_num_generate();
ret = nrf_drv_clock_init();
APP_ERROR_CHECK(ret);
NRF_LOG_INFO("USBD BLE UART example started.");
ret = app_usbd_init(&usbd_config);
app_usbd_class_inst_t const * class_inst_generic;
class_inst_generic = app_usbd_hid_generic_class_inst_get(&m_app_hid_generic);
ret = hid_generic_idle_handler_set(class_inst_generic, idle_handle);
ret = app_usbd_class_append(class_inst_generic);
if (USBD_POWER_DETECTION)
ret = app_usbd_power_events_enable();
NRF_LOG_INFO("No USB power detection enabled\r\nStarting USB now");
app_usbd_enable();
app_usbd_start();
ble_stack_init();
gap_params_init();
gatt_init();
services_init();
advertising_init();
conn_params_init();
// Start execution.
throughput_test();
//ret = app_usbd_power_events_enable();
//APP_ERROR_CHECK(ret);
// Enter main loop.
for (;;)
while (app_usbd_event_queue_process())
/* Nothing to do */
the laptop did not rest screen
