SDK 9.0.0 PSTORAGE
Hi . I try to use the Persistent Storage Interface. but i can't write.
static void example_cb_handler(pstorage_handle_t  * handle,
															 uint8_t              op_code,
                               uint32_t             result,
                               uint8_t            * p_data,
                               uint32_t             data_len)
		if(handle->block_id == pstorage_wait_handle) { pstorage_wait_flag = 0; }  //If we are waiting for this callback, clear the wait flag.
		switch(op_code)
			case PSTORAGE_LOAD_OP_CODE:
				 if (result == NRF_SUCCESS)
						// nrf_gpio_pin_clear(21);
							printf("PSTORAGE_LOAD_OP_CODE_SUCCESS\r\n");
					//	 nrf_gpio_pin_set(21);
						printf("PSTORAGE_LOAD_OP_CODE_FAIL\r\n");
			case PSTORAGE_STORE_OP_CODE:
						// nrf_gpio_pin_clear(22);
					 printf("PSTORAGE_STORE_OP_CODE_SUCCESS\r\n");
					//	 nrf_gpio_pin_set(22);
					 printf("PSTORAGE_STORE_OP_CODE_FAIL\r\n");
			case PSTORAGE_UPDATE_OP_CODE:
				//		 nrf_gpio_pin_clear(23);
					 printf("PSTORAGE_UPDATE_OP_CODE_SUCCESS\r\n");
				//		 nrf_gpio_pin_set(23);
					 printf("PSTORAGE_UPDATE_OP_CODE_FAIL\r\n");
			case PSTORAGE_CLEAR_OP_CODE:
				//		 nrf_gpio_pin_clear(24);
					 printf("PSTORAGE_CLEAR_OP_CODE_SUCCESS\r\n");
				//		 nrf_gpio_pin_set(24);
					 printf("PSTORAGE_CLEAR_OP_CODE_FAIL\r\n");
/*			case PSTORAGE_ERROR_OP_CODE:
						//nrf_gpio_pin_set(PSTORAGE_ERROR_LED_PIN_NO);
				 break;				 */
void pstorage_write()
	pstorage_handle_t       handle;
//	pstorage_handle_t base_handle;
	pstorage_handle_t block_handle;
	pstorage_module_param_t param;
	uint8_t           source_data[16] = {0, 1, 3, 4, 6, 7, 4, 6, 3, 6, 3, 1, 9, 8, 7, 5};
	uint32_t retval;
	retval = pstorage_init();
	if(retval == NRF_SUCCESS)
			printf("INIT_SUCCESS\r\n");
		printf("INIT_FAIL\r\n");
	param.block_size  = 100;
	param.block_count = 10;
	param.cb          = example_cb_handler;
	retval = pstorage_register(&param, &handle);
	if (retval == NRF_SUCCESS)
			printf("REGISTER_SUCCESS\r\n");
			printf("REGISTER_FAIL\r\n");// Failed to register, take corrective action.
	// Request to get identifier for 3rd block.
	retval = pstorage_block_identifier_get(&handle, 0 &block_handle);
			printf("IDENTIFIER_GET_SUCCESS\r\n");// Get Block Identifier successful.
			printf("IDENTIFIER_GET_FAIL\r\n");// Failed to get block id, take corrective action.
	// Request to write 8 bytes to block at an offset of 20 bytes.
	retval = pstorage_store(&block_handle, source_data, 16, 0);
			printf("STORE_SUCCESS\r\n");// Store successfully requested. Wait for operation result.
			printf("STORE_FAIL\r\n");// Failed to request store, take corrective action.
	retval = pstorage_update(&block_handle, source_data, 16, 0);
			printf("UPDATE_SUCCESS\r\n");// Update successfully requested. Wait for operation result.
			printf("UPDATE_FAIL\r\n");// Failed to request update, take corrective action.
void pstorage_read(void)
		pstorage_handle_t				block_0_handle;
		uint8_t                 dest_data_0[200];
		pstorage_init();
		param.block_size  = 100;                   //Select block size of 16 bytes
		param.block_count = 10;                   //Select 10 blocks, total of 160 bytes
		param.cb          = example_cb_handler;   //Set the pstorage callback handler
		//Get block identifiers
		pstorage_block_identifier_get(&handle, 0, &block_0_handle);
		pstorage_wait_handle = block_0_handle.block_id;            //Specify which pstorage handle to wait for
		pstorage_wait_flag = 1;                                    //Set the wait flag. Cleared in the example_cb_handler
		pstorage_load(dest_data_0, &block_0_handle, 100, 0);				 //Read from flash, only one block is allowed for each pstorage_load command
	//	printf("dest_data_0 :");
		for(int i=0;i<16;i++){
				printf("%d\r\n",dest_data_0[i]);
I blocked at 'retval = pstorage_store(&block_handle, source_data, 16, 0);' I received til "IDENTIFIER_GET_SUCCESS". I don't know the reason. please help me..
