Combine ECB and pstorage
I read somewhere that to get the callback working on pstorage write, read etc, you need to call pstorage_sys_event_handler() in a function set by softdevice_sys_evt_handler_set() which in turn probably requires SOFTDEVICE_HANDLER_INIT() ?
The problem is when doing this, it just hangs when initializing ECB:
static void sys_evt_dispatch(uint32_t sys_evt)
	pstorage_sys_event_handler(sys_evt);
static void softdevice_stack_init(void)
	// Initialize SoftDevice.
	SOFTDEVICE_HANDLER_INIT(NRF_CLOCK_LFCLKSRC_XTAL_20_PPM, NULL);
	uint32_t err_code = softdevice_sys_evt_handler_set(sys_evt_dispatch);
	softdevice_stack_init();
 (void)nrf_esb_init(NRF_ESB_MODE_PTX); // HANG
The softdevice is loaded, and I use app_timer_ble_gzll.c and esb_sd_resources_arm.a (using GCC) Note: I don't really use the callback, but I guess it's a sign that nothing actually happens in the actual write, read etc.
I read in the documentation:
developer.nordicsemi.com/.../a00104.html
"The radio and timer interrupt handlers run at priority level 0 (highest level), and the ESB callback functions run at priority level 1. Other interrupts used by the application must use priority level 2 or higher to ensure correct operation."
I guess I should do something with this?
Thanks!
