strange packet loss with ESS service
I need your help to understand better why I see packet loss even on the bench.
I have two Telit BlueMod+S50 chips (based on nRF52382) as central and peripheral. The peripheral uses a custom firmware based on SDK v17.1.0, with SoftDevice S132; the central is running a pre-compiled firmware provided by Telit itself
The peripheral every 50 ms collects data from an ADC and an accelerometer, creates a frame of 47 bytes and stored it in an application queue; then it tries to send as much packets as possible from the queue to SoftDevice, until sd_ble_gatts_hvx() returns an error or no resource available. packets are sent as Notifications
The main MCU talks with the central via AT interface based on UART. The data are passed from the central to the main MCU as serial LENOTI messages .
ideally every 50ms a packet is created and sent immediately, so I have a rate of 1 packet/50ms. in reality on the field packets can't be sent out immediately, due to interferences the central is not acknowledging immediately the Notifications, so the rate is much lower, hence the need to store packets in the queue.
on the bench I have modified the firmware so it first saves 50 packets in the queue and then tries to send as much packets as possible on each 50ms connection. in this way I can see that for each connection around 13-15 packets are sent until the queue is empty.
the problem is, on the main MCU, every 30 packets (LENOTI messages received) there are 3-4 packets lost (LENOTI messages without any payload).
the interesting thing is that if I manually limit the transmission to maximum 3 packets per connection , no packet is lost!
this makes me thing that it could be a configuration issue and some packets are actually discarded and not transmitted.
these are my configuration settings:
#define APP_ADV_INTERVAL 400
#define APP_ADV_DURATION 0
#define GATT_QUEUE_MAX_SIZE 4
#define MIN_CONN_INTERVAL MSEC_TO_UNITS(45, UNIT_1_25_MS)
#define MAX_CONN_INTERVAL MSEC_TO_UNITS(50, UNIT_1_25_MS)
#define SLAVE_LATENCY 3
#define CONN_SUP_TIMEOUT BLE_GAP_CP_CONN_SUP_TIMEOUT_MAX
#define FIRST_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(5000)
#define NEXT_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(30000)
#define MAX_CONN_PARAMS_UPDATE_COUNT 9
the function which is sending packets is the follow:
#define OPCODE_LENGTH 1
#define HANDLE_LENGTH 2
#define MAX_TPM_LEN (NRF_SDH_BLE_GATT_MAX_MTU_SIZE - OPCODE_LENGTH - HANDLE_LENGTH)
#define CC_TPM_FRAME_LENGTH 47
uint32_t ble_ess_temperature_measurement_send(ble_ess_t * p_ess, uint8_t *temperature)
    uint32_t err_code;
    // Send value if connected and notifying
    if (p_ess->conn_handle != BLE_CONN_HANDLE_INVALID)
        uint8_t                encoded_tpm[MAX_TPM_LEN];
        uint16_t               len;
        uint16_t               hvx_len;
        ble_gatts_hvx_params_t hvx_params;
        len     = CC_TPM_FRAME_LENGTH;
        hvx_len = len;
        memset(&hvx_params, 0, sizeof(hvx_params));
        hvx_params.handle = p_ess->tpm_handles.value_handle;
        hvx_params.type   = BLE_GATT_HVX_NOTIFICATION;
        hvx_params.offset = 0;
        hvx_params.p_len  = &hvx_len;
        hvx_params.p_data = temperature;
        err_code = sd_ble_gatts_hvx(p_ess->conn_handle, &hvx_params);
        if ((err_code == NRF_SUCCESS) && (hvx_len != len))
            err_code = NRF_ERROR_DATA_SIZE;
        err_code = NRF_ERROR_INVALID_STATE;
    return err_code;
on startup these messages are displayed:
debug> nrf_ble_gatt: Requesting to update ATT MTU to 247 bytes on connection 0x0.
<debug> nrf_ble_gatt: Updating data length to 251 on connection 0x0.
<info> tm_ble: Connected
<debug> nrf_ble_gatt: Peer on connection 0x0 requested an ATT MTU of 158 bytes.
<debug> nrf_ble_gatt: Updating ATT MTU to 158 bytes (desired: 247) on connection 0x0.
<debug> nrf_ble_gatt: ATT MTU updated to 158 bytes on connection 0x0 (response).
<info> tm_ble: GATT ATT MTU on connection 0x0 changed to 158.
<debug> nrf_ble_gatt: Data length updated to 162 on connection 0x0.
<debug> nrf_ble_gatt: max_rx_octets: 162
<debug> nrf_ble_gatt: max_tx_octets: 162
<debug> nrf_ble_gatt: max_rx_time: 1408
<debug> nrf_ble_gatt: max_tx_time: 1408
can you please help me understand why I'm losing packet and how to change configuration settings in order to achieve the transmission of the maximum number of packets per connection?
