Connection failure error during DFU over Matter guide
Hi
I have a question because a connection failure error occurred during the DFU over Matter guide.
- guide URL : developer.nordicsemi.com/.../nrfconnect_examples_software_update.html
The PC using Ubuntu OS(with nRF52840 dongle) is configured as the OTA provider and the nRF52840DK board is configured as the OTA requester.
I completed the installation of ota-provider-app and chip-tool on the Linux PC and commissioned the Linux PC as an OTA provider through the command below
./out/chiptool/chip-tool pairing onnetwork 1 20202021
And after configuring the new thread network through OTBR, nRF52840DK board was commissioned with node ID 2.
./out/chiptool/chip-tool pairing ble-thread 2 hex:0e08000000000001000035060004001fffe00708fdb96028cd2611df0c0402a0f7f8051000112233445566778899aabbccddeeff030
e4f70656e54687265616444656d6f0410445f2b5ca6f2a93a55ce570a70efeecb000300000f0208111111112222222201021234 20202021 3840
Finally, I performed the steps 8 and 9 commands.
./out/chiptool/chip-tool otasoftwareupdaterequestor write default-otaproviders '[{"fabricIndex": 1, "providerNodeID": 1, "endpoint": 0}]' 2 0
('default-ota-providers' command did not exist, so we used 'default-otaproviders')
./out/chiptool/chip-tool accesscontrol write acl '[{"fabricIndex": 1, "privilege": 5, "authMode": 2, "subjects": [112233], "targets": null}, {"fabricIndex": 1, "privilege": 3, "authMode": 2, "subjects": null, "targets": null}]' 1 0
And I sent Announce OTA Provider command using Chip tool, but an error appears in the nRF52840DK board log
./out/chiptool/chip-tool otasoftwareupdaterequestor announce-otaprovider 1 0 0 0 2 0
('announce-ota-provider' command did not exist, so we used 'announce-ota-provider')
Log >>
I: 1515622 [EM]>>> [E:60665r S:0 M:182234332] (U) Msg RX from 0:EBA082CFD0009BF0 [0000] --- Type 0000:30 (SecureChannel:CASE_Sigma1)
I: 1515634 [IN]CASE Server received Sigma1 message . Starting handshake. EC 0x20004e60
I: 1515641 [IN]CASE Server disabling CASE session setups
I: 1515647 [EM]<<< [E:60665r S:0 M:209788448 (Ack:182234332)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
I: 1515660 [IN](U) Sending msg 209788448 to IP address 'UDP:[fd11:db8:1::1]:46385'
I: 1515668 [SC]Received Sigma1 msg
I: 1515676 [SC]CASE matched destination ID: fabricIndex 1, NodeID 0x0000000000000002
I: 1515885 [EM]<<< [E:60665r S:0 M:209788449 (Ack:182234332)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:31 (SecureChannel:CASE_Sigma2)
I: 1515898 [IN](U) Sending msg 209788449 to IP address 'UDP:[fd11:db8:1::1]:46385'
I: 1515907 [SC]Sent Sigma2 msg
I: 1516027 [EM]>>> [E:60665r S:0 M:182234333 (Ack:209788449)] (U) Msg RX from 0:EBA082CFD0009BF0 [0000] --- Type 0000:32 (SecureChannel:CASE_Sigma3)
I: 1516040 [EM]<<< [E:60665r S:0 M:209788450 (Ack:182234333)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
I: 1516053 [IN](U) Sending msg 209788450 to IP address 'UDP:[fd11:db8:1::1]:46385'
I: 1516062 [SC]Received Sigma3 msg
E: 1516070 [SC]The device does not support GetClock_RealTimeMS() API: 3. Falling back to Last Known Good UTC Time
E: 1516267 [DL]Long dispatch time: 187 ms, for event type 2
I: 1516368 [EM]<<< [E:60665r S:0 M:209788451 (Ack:182234333)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:40 (SecureChannel:StatusReport)
I: 1516381 [IN](U) Sending msg 209788451 to IP address 'UDP:[fd11:db8:1::1]:46385'
I: 1516391 [SC]SecureSession[0x20003838]: Moving from state 'kEstablishing' --> 'kActive'
D: 1516400 [IN]SecureSession[0x20003838]: Activated - Type:2 LSID:38704
D: 1516406 [IN]New secure session activated for device <000000000001B669, 1>, LSID:38704 PSID:14355!
I: 1516419 [IN]CASE Session established to peer: <000000000001B669, 1>
I: 1516425 [IN]CASE Server enabling CASE session setups
D: 1516431 [IN]SecureSession[0x200038f0]: Allocated Type:2 LSID:38706
E: 1516437 [DL]Long dispatch time: 165 ms, for event type 2
I: 1516443 [EM]>>> [E:60666r S:38704 M:131944375] (S) Msg RX from 1:000000000001B669 [4661] --- Type 0001:08 (IM:InvokeCommandRequest)
I: 1516456 [SWU]OTA Requestor received AnnounceOTAProvider
D: 1516461 [SWU] FabricIndex: 1
D: 1516464 [SWU] ProviderNodeID: 0x0000000000000001
D: 1516469 [SWU] VendorID: 0x0
D: 1516472 [SWU] AnnouncementReason: 0
D: 1516475 [SWU] Endpoint: 0
I: 1516479 [EM]<<< [E:60666r S:38704 M:3219666 (Ack:131944375)] (S) Msg TX to 1:000000000001B669 [4661] --- Type 0001:09 (IM:InvokeCommandResponse)
I: 1516492 [IN](S) Sending msg 3219666 on secure session with LSID: 38704
I: 1516500 [EM]>>> [E:60665r S:0 M:182234334 (Ack:209788451)] (U) Msg RX from 0:EBA082CFD0009BF0 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
I: 1516514 [SWU]Stopping the Periodic Query timer
I: 1516519 [SWU]Starting the watchdog timer, timeout: 21600 seconds
D: 1516525 [SWU]Establishing session to provider node ID 0x0000000000000001 on fabric index 1
D: 1516535 [DIS]OperationalSessionSetup[1:0000000000000001]: State change 1 --> 2
I: 1516543 [DIS]Resolving DFAABB27E9334661:0000000000000001 ...
I: 1516551 [EM]>>> [E:60666r S:38704 M:131944376 (Ack:3219666)] (S) Msg RX from 1:000000000001B669 [4661] --- Type 0000:10 (SecureChannel:StandaloneAck)
I: 1516635 [DIS]Node ID resolved for DFAABB27E9334661:0000000000000001
D: 1516641 [DIS] Hostname: E0D55EB9F3140000
D: 1516645 [DIS] IP Address #1: fd11:db8:1::1
D: 1516649 [DIS] Port: 5540
D: 1516652 [DIS] Mrp Interval idle: 300 ms
D: 1516656 [DIS] Mrp Interval active: 2000 ms
D: 1516660 [DIS] TCP Supported: 1
D: 1516663 [DIS]Lookup clearing interface for non LL address
I: 1516668 [DIS]UDP:[fd11:db8:1::1]:5540: new best score: 4
I: 1516674 [DIS]Checking node lookup status after 131 ms
I: 1516679 [DIS]Keeping DNSSD lookup active
I: 1516743 [DIS]Checking node lookup status after 200 ms
D: 1516748 [DIS]OperationalSessionSetup[1:0000000000000001]: Updating device address to UDP:[fd11:db8:1::1]:5540 while in state 2
D: 1516760 [DIS]OperationalSessionSetup[1:0000000000000001]: State change 2 --> 3
D: 1516767 [IN]SecureSession[0x200039a8]: Allocated Type:2 LSID:38707
I: 1516774 [SC]Initiating session on local FabricIndex 1 from 0x0000000000000002 -> 0x0000000000000001
I: 1516924 [EM]<<< [E:31162i S:0 M:209788452] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:30 (SecureChannel:CASE_Sigma1)
I: 1516936 [IN](U) Sending msg 209788452 to IP address 'UDP:[fd11:db8:1::1]:5540'
I: 1516944 [SC]Sent Sigma1 msg
D: 1516947 [DIS]OperationalSessionSetup[1:0000000000000001]: State change 3 --> 4
I: 1517852 [IN](U) Sending msg 209788452 to IP address 'UDP:[fd11:db8:1::1]:5540'
I: 1518686 [IN](U) Sending msg 209788452 to IP address 'UDP:[fd11:db8:1::1]:5540'
I: 1519741 [IN](U) Sending msg 209788452 to IP address 'UDP:[fd11:db8:1::1]:5540'
I: 1521217 [IN](U) Sending msg 209788452 to IP address 'UDP:[fd11:db8:1::1]:5540'
E: 1523365 [EM]Failed to Send CHIP MessageCounter:209788452 on exchange 31162i sendCount: 4 max retries: 4
E: 1525648 [SC]CASESession timed out while waiting for a response from the peer. Current state was 1
D: 1525657 [IN]SecureSession[0x200039a8]: Released - Type:2 LSID:38707
D: 1525664 [DIS]OperationalSessionSetup[1:0000000000000001]: State change 4 --> 2
D: 1525671 [DIS]OperationalSessionSetup[1:0000000000000001]: State change 2 --> 1
E: 1525679 [SWU]Failed to connect to node 0x0000000000000001: 32
I: 1525686 [SWU]Unknown idle state reason so set the periodic timer for a next attempt
I: 1525694 [SWU]Stopping the watchdog timer
I: 1525698 [SWU]Starting the periodic query timer, timeout: 86400 seconds
When you send the Query command from the nRF52840DK board, the error log appears as shown below.
matter ota query
Log >>
matter ota query
uart:~$ I: 1682151 [SWU]Triggered immediate OTA query for fabric: 0x1
I: 1682159 [SWU]Stopping the Periodic Query timer
I: 1682163 [SWU]Starting the watchdog timer, timeout: 21600 seconds
D: 1682169 [SWU]Establishing session to provider node ID 0x0000000000000001 on fabric index 1
D: 1682177 [DIS]OperationalSessionSetup[1:0000000000000001]: State change 1 --> 2
I: 1682185 [DIS]Resolving DFAABB27E9334661:0000000000000001 ...
I: 1682284 [DIS]Node ID resolved for DFAABB27E9334661:0000000000000001
D: 1682290 [DIS] Hostname: E0D55EB9F3140000
D: 1682294 [DIS] IP Address #1: fd11:db8:1::1
D: 1682298 [DIS] Port: 5540
D: 1682301 [DIS] Mrp Interval idle: 300 ms
D: 1682305 [DIS] Mrp Interval active: 2000 ms
D: 1682309 [DIS] TCP Supported: 1
D: 1682312 [DIS]Lookup clearing interface for non LL address
I: 1682317 [DIS]UDP:[fd11:db8:1::1]:5540: new best score: 4
I: 1682323 [DIS]Checking node lookup status after 138 ms
I: 1682328 [DIS]Keeping DNSSD lookup active
I: 1682385 [DIS]Checking node lookup status after 200 ms
D: 1682390 [DIS]OperationalSessionSetup[1:0000000000000001]: Updating device address to UDP:[fd11:db8:1::1]:5540 while in state 2
D: 1682402 [DIS]OperationalSessionSetup[1:0000000000000001]: State change 2 --> 3
D: 1682409 [IN]SecureSession[0x200039a8]: Allocated Type:2 LSID:38709
I: 1682416 [SC]Initiating session on local FabricIndex 1 from 0x0000000000000002 -> 0x0000000000000001
I: 1682567 [EM]<<< [E:31164i S:0 M:209788454] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:30 (SecureChannel:CASE_Sigma1)
I: 1682578 [IN](U) Sending msg 209788454 to IP address 'UDP:[fd11:db8:1::1]:5540'
I: 1682587 [SC]Sent Sigma1 msg
D: 1682590 [DIS]OperationalSessionSetup[1:0000000000000001]: State change 3 --> 4
I: 1683417 [IN](U) Sending msg 209788454 to IP address 'UDP:[fd11:db8:1::1]:5540'
I: 1684297 [IN](U) Sending msg 209788454 to IP address 'UDP:[fd11:db8:1::1]:5540'
I: 1685441 [IN](U) Sending msg 209788454 to IP address 'UDP:[fd11:db8:1::1]:5540'
I: 1686890 [IN](U) Sending msg 209788454 to IP address 'UDP:[fd11:db8:1::1]:5540'
E: 1688790 [EM]Failed to Send CHIP MessageCounter:209788454 on exchange 31164i sendCount: 4 max retries: 4
E: 1691290 [SC]CASESession timed out while waiting for a response from the peer. Current state was 1
D: 1691299 [IN]SecureSession[0x200039a8]: Released - Type:2 LSID:38709
D: 1691305 [DIS]OperationalSessionSetup[1:0000000000000001]: State change 4 --> 2
D: 1691313 [DIS]OperationalSessionSetup[1:0000000000000001]: State change 2 --> 1
E: 1691320 [SWU]Failed to connect to node 0x0000000000000001: 32
I: 1691327 [SWU]Unknown idle state reason so set the periodic timer for a next attempt
I: 1691334 [SWU]Stopping the watchdog timer
I: 1691338 [SWU]Starting the periodic query timer, timeout: 86400 seconds
How can I solve this problem?
Also, could you check if DFU over Matter works well with the contents of the above guide Url?
+) The example "ncs\v2.4.0\nrf\samples\matter\light_bulb" was used, and only 'CONFIG_CHIP_DFU_OVER_BT_SMP=y' was added to the prj.conf file.
    Just a heads up that I've queried the Matter team regarding the results you've posted and but I am yet to receive a result. The log from item 2 is still very helpful if you are able to get one!
    I will be out of office until next week starting today, but I'll check back in with you and the status from the developers when I return.
    Andreas
  • Hi
    I'm back with some more info from the Matter team:
    It is hard to say what is going wrong. Everything looks quite correct regarding IP addresses and etc. The developers reproduced the test on their desk and pcap looks the same, with the one difference. For them the procedure works correctly and packets are forwarded. The next thing they suspect is that something must be wrong with the OpenThread Border Router or routing configuration, but since communication with CHIP Tool works correctly, this might not be the case
    1. Could you try to invoke the following two commands before running the OTBR docker and report back the result??
    sudo sysctl -w net.ipv6.conf.otbr0.accept_ra_rt_info_max_plen=128
    sudo sysctl -w net.ipv6.conf.otbr0.accept_ra=2
    2. If you've used a different OTBR setup than what is recommended/specified in the DFU guide & testing Matter in NCS guide, could you try with the recommended hardware and see if that makes any changes?
    Andreas
  • Thank you for your confirmation.
    The results of the confirmation of your request are as follows.
    1. After entering that command, I configured OTBR again and tested it, but the OTA did not proceed similarly. However, a different log has been identified.
    - Log to Matter Device
    I: 465451 [EM]>>> [E:34015r S:0 M:186092791] (U) Msg RX from 0:DBA51F5EF7A1A2AD [0000] --- Type 0000:30 (SecureChannel:CASE_Sigma1)
    I: 465463 [IN]CASE Server received Sigma1 message . Starting handshake. EC 0x20004e60
    I: 465471 [IN]CASE Server disabling CASE session setups
    I: 465476 [EM]<<< [E:34015r S:0 M:220419010 (Ack:186092791)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
    I: 465489 [IN](U) Sending msg 220419010 to IP address 'UDP:[fd11:1111:1122:2222:3079:47c7:9eda:cb9a]:45258'
    I: 465500 [SC]Received Sigma1 msg
    I: 465507 [SC]CASE matched destination ID: fabricIndex 1, NodeID 0x0000000000000005
    I: 465723 [EM]<<< [E:34015r S:0 M:220419011 (Ack:186092791)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:31 (SecureChannel:CASE_Sigma2)
    I: 465735 [IN](U) Sending msg 220419011 to IP address 'UDP:[fd11:1111:1122:2222:3079:47c7:9eda:cb9a]:45258'
    I: 465747 [SC]Sent Sigma2 msg
    I: 465868 [EM]>>> [E:34015r S:0 M:186092792 (Ack:220419011)] (U) Msg RX from 0:DBA51F5EF7A1A2AD [0000] --- Type 0000:32 (SecureChannel:CASE_Sigma3)
    I: 465882 [EM]<<< [E:34015r S:0 M:220419012 (Ack:186092792)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
    I: 465895 [IN](U) Sending msg 220419012 to IP address 'UDP:[fd11:1111:1122:2222:3079:47c7:9eda:cb9a]:45258'
    I: 465905 [SC]Received Sigma3 msg
    E: 465914 [SC]The device does not support GetClock_RealTimeMS() API: 3.  Falling back to Last Known Good UTC Time
    E: 466111 [DL]Long dispatch time: 187 ms, for event type 2
    I: 466214 [EM]<<< [E:34015r S:0 M:220419013 (Ack:186092792)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:40 (SecureChannel:StatusReport)
    I: 466227 [IN](U) Sending msg 220419013 to IP address 'UDP:[fd11:1111:1122:2222:3079:47c7:9eda:cb9a]:45258'
    I: 466239 [SC]SecureSession[0x20003838]: Moving from state 'kEstablishing' --> 'kActive'
    D: 466247 [IN]SecureSession[0x20003838]: Activated - Type:2 LSID:46171
    D: 466254 [IN]New secure session activated for device <000000000001B669, 1>, LSID:46171 PSID:48533!
    I: 466263 [IN]CASE Session established to peer: <000000000001B669, 1>
    I: 466270 [IN]CASE Server enabling CASE session setups
    D: 466277 [IN]SecureSession[0x200038f0]: Allocated Type:2 LSID:46173
    E: 466284 [DL]Long dispatch time: 168 ms, for event type 2
    I: 466291 [EM]>>> [E:34016r S:46171 M:85657165] (S) Msg RX from 1:000000000001B669 [E4A4] --- Type 0001:08 (IM:InvokeCommandRequest)
    I: 466303 [SWU]OTA Requestor received AnnounceOTAProvider
    D: 466308 [SWU]  FabricIndex: 1
    D: 466311 [SWU]  ProviderNodeID: 0x0000000000000001
    D: 466316 [SWU]  VendorID: 0x0
    D: 466319 [SWU]  AnnouncementReason: 0
    D: 466322 [SWU]  Endpoint: 0
    I: 466326 [EM]<<< [E:34016r S:46171 M:119443558 (Ack:85657165)] (S) Msg TX to 1:000000000001B669 [E4A4] --- Type 0001:09 (IM:InvokeCommandResponse)
    I: 466339 [IN](S) Sending msg 119443558 on secure session with LSID: 46171
    I: 466347 [EM]>>> [E:34015r S:0 M:186092793 (Ack:220419013)] (U) Msg RX from 0:DBA51F5EF7A1A2AD [0000] --- Type 0000:10 (SecureChannel:StandaloneAck)
    I: 466362 [SWU]Stopping the Periodic Query timer
    I: 466367 [SWU]Starting the watchdog timer, timeout: 21600 seconds
    D: 466373 [SWU]Establishing session to provider node ID 0x0000000000000001 on fabric index 1
    D: 466383 [DIS]OperationalSessionSetup[1:0000000000000001]: State change 1 --> 2
    I: 466390 [DIS]Resolving 8FAB4E5B9E78E4A4:0000000000000001 ...
    I: 466398 [EM]>>> [E:34016r S:46171 M:85657166 (Ack:119443558)] (S) Msg RX from 1:000000000001B669 [E4A4] --- Type 0000:10 (SecureChannel:StandaloneAck)
    I: 466451 [DIS]Node ID resolved for 8FAB4E5B9E78E4A4:0000000000000001
    D: 466457 [DIS] Hostname: E0D55EB9F3140000
    D: 466461 [DIS] IP Address #1: fd11:1111:1122:2222:3079:47c7:9eda:cb9a
    D: 466467 [DIS] Port: 5540
    D: 466470 [DIS] Mrp Interval idle: 300 ms
    D: 466474 [DIS] Mrp Interval active: 2000 ms
    D: 466478 [DIS] TCP Supported: 1
    D: 466481 [DIS]Lookup clearing interface for non LL address
    I: 466486 [DIS]UDP:[fd11:1111:1122:2222:3079:47c7:9eda:cb9a]:5540: new best score: 4
    I: 466493 [DIS]Checking node lookup status after 103 ms
    I: 466498 [DIS]Keeping DNSSD lookup active
    I: 466591 [DIS]Checking node lookup status after 200 ms
    D: 466596 [DIS]OperationalSessionSetup[1:0000000000000001]: Updating device address to UDP:[fd11:1111:1122:2222:3079:47c7:9eda:cb9a]:5540 while in state 2
    D: 466609 [DIS]OperationalSessionSetup[1:0000000000000001]: State change 2 --> 3
    D: 466617 [IN]SecureSession[0x200039a8]: Allocated Type:2 LSID:46174
    I: 466623 [SC]Initiating session on local FabricIndex 1 from 0x0000000000000005 -> 0x0000000000000001
    I: 466780 [EM]<<< [E:4672i S:0 M:220419014] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:30 (SecureChannel:CASE_Sigma1)
    I: 466792 [IN](U) Sending msg 220419014 to IP address 'UDP:[fd11:1111:1122:2222:3079:47c7:9eda:cb9a]:5540'
    I: 466802 [SC]Sent Sigma1 msg
    D: 466805 [DIS]OperationalSessionSetup[1:0000000000000001]: State change 3 --> 4
    I: 467642 [IN](U) Sending msg 220419014 to IP address 'UDP:[fd11:1111:1122:2222:3079:47c7:9eda:cb9a]:5540'
    I: 468516 [IN](U) Sending msg 220419014 to IP address 'UDP:[fd11:1111:1122:2222:3079:47c7:9eda:cb9a]:5540'
    I: 469603 [IN](U) Sending msg 220419014 to IP address 'UDP:[fd11:1111:1122:2222:3079:47c7:9eda:cb9a]:5540'
    I: 470977 [IN](U) Sending msg 220419014 to IP address 'UDP:[fd11:1111:1122:2222:3079:47c7:9eda:cb9a]:5540'
    E: 472953 [EM]Failed to Send CHIP MessageCounter:220419014 on exchange 4672i sendCount: 4 max retries: 4
    E: 475504 [SC]CASESession timed out while waiting for a response from the peer. Current state was 1
    D: 475513 [IN]SecureSession[0x200039a8]: Released - Type:2 LSID:46174
    D: 475520 [DIS]OperationalSessionSetup[1:0000000000000001]: State change 4 --> 2
    D: 475527 [DIS]OperationalSessionSetup[1:0000000000000001]: State change 2 --> 1
    E: 475534 [SWU]Failed to connect to node 0x0000000000000001: 32
    I: 475541 [SWU]Unknown idle state reason so set the periodic timer for a next attempt
    I: 475549 [SWU]Stopping the watchdog timer
    I: 475553 [SWU]Starting the periodic query timer, timeout: 86400 seconds
    - Log to OTBR
    Jul  5 01:21:54 f6de2ba70eca otbr-agent[191]: 00:52:08.213 [I] MeshForwarder-: Sent IPv6 UDP msg, len:214, chksum:4ee2, ecn:no, to:0x6400, sec:yes, prio:low
    Jul  5 01:21:54 f6de2ba70eca otbr-agent[191]: 00:52:08.213 [I] MeshForwarder-:     src:[fd11:1111:1122:2222:3079:47c7:9eda:cb9a]:46501
    Jul  5 01:21:54 f6de2ba70eca otbr-agent[191]: 00:52:08.213 [I] MeshForwarder-:     dst:[fd11:22:0:0:33c1:f158:876a:7d0a]:5540
    Jul  5 01:21:54 f6de2ba70eca otbr-agent[191]: 00:52:08.270 [I] MeshForwarder-: Received IPv6 UDP msg, len:74, chksum:b837, ecn:no, from:0x6400, sec:yes, prio:normal, rss:-43.0
    Jul  5 01:21:54 f6de2ba70eca otbr-agent[191]: 00:52:08.270 [I] MeshForwarder-:     src:[fd11:22:0:0:33c1:f158:876a:7d0a]:5540
    Jul  5 01:21:54 f6de2ba70eca otbr-agent[191]: 00:52:08.270 [I] MeshForwarder-:     dst:[fd11:1111:1122:2222:3079:47c7:9eda:cb9a]:46501
    Jul  5 01:21:54 f6de2ba70eca otbr-agent[191]: 00:52:08.567 [I] MeshForwarder-: Received IPv6 UDP msg, len:780, chksum:763c, ecn:no, from:0x6400, sec:yes, prio:normal, rss:-40.0
    Jul  5 01:21:54 f6de2ba70eca otbr-agent[191]: 00:52:08.567 [I] MeshForwarder-:     src:[fd11:22:0:0:33c1:f158:876a:7d0a]:5540
    Jul  5 01:21:54 f6de2ba70eca otbr-agent[191]: 00:52:08.567 [I] MeshForwarder-:     dst:[fd11:1111:1122:2222:3079:47c7:9eda:cb9a]:46501
    Jul  5 01:21:54 f6de2ba70eca otbr-agent[191]: 00:52:08.626 [I] MeshForwarder-: Sent IPv6 UDP msg, len:646, chksum:e796, ecn:no, to:0x6400, sec:yes, prio:low
    Jul  5 01:21:54 f6de2ba70eca otbr-agent[191]: 00:52:08.626 [I] MeshForwarder-:     src:[fd11:1111:1122:2222:3079:47c7:9eda:cb9a]:46501
    Jul  5 01:21:54 f6de2ba70eca otbr-agent[191]: 00:52:08.627 [I] MeshForwarder-:     dst:[fd11:22:0:0:33c1:f158:876a:7d0a]:5540
    Jul  5 01:21:54 f6de2ba70eca otbr-agent[191]: 00:52:08.673 [I] MeshForwarder-: Received IPv6 UDP msg, len:74, chksum:b537, ecn:no, from:0x6400, sec:yes, prio:normal, rss:-41.0
    Jul  5 01:21:54 f6de2ba70eca otbr-agent[191]: 00:52:08.673 [I] MeshForwarder-:     src:[fd11:22:0:0:33c1:f158:876a:7d0a]:5540
    Jul  5 01:21:54 f6de2ba70eca otbr-agent[191]: 00:52:08.673 [I] MeshForwarder-:     dst:[fd11:1111:1122:2222:3079:47c7:9eda:cb9a]:46501
    Jul  5 01:21:55 f6de2ba70eca otbr-agent[191]: 00:52:09.008 [I] MeshForwarder-: Received IPv6 UDP msg, len:82, chksum:aff7, ecn:no, from:0x6400, sec:yes, prio:normal, rss:-41.0
    Jul  5 01:21:55 f6de2ba70eca otbr-agent[191]: 00:52:09.008 [I] MeshForwarder-:     src:[fd11:22:0:0:33c1:f158:876a:7d0a]:5540
    Jul  5 01:21:55 f6de2ba70eca otbr-agent[191]: 00:52:09.008 [I] MeshForwarder-:     dst:[fd11:1111:1122:2222:3079:47c7:9eda:cb9a]:46501
    Jul  5 01:21:55 f6de2ba70eca otbr-agent[191]: 00:52:09.025 [I] MeshForwarder-: Sent IPv6 UDP msg, len:119, chksum:a387, ecn:no, to:0x6400, sec:yes, prio:low
    Jul  5 01:21:55 f6de2ba70eca otbr-agent[191]: 00:52:09.025 [I] MeshForwarder-:     src:[fd11:1111:1122:2222:3079:47c7:9eda:cb9a]:46501
    Jul  5 01:21:55 f6de2ba70eca otbr-agent[191]: 00:52:09.025 [I] MeshForwarder-:     dst:[fd11:22:0:0:33c1:f158:876a:7d0a]:5540
    Jul  5 01:21:55 f6de2ba70eca otbr-agent[191]: 00:52:09.031 [I] MeshForwarder-: Sent IPv6 UDP msg, len:74, chksum:af37, ecn:no, to:0x6400, sec:yes, prio:low
    Jul  5 01:21:55 f6de2ba70eca otbr-agent[191]: 00:52:09.031 [I] MeshForwarder-:     src:[fd11:1111:1122:2222:3079:47c7:9eda:cb9a]:46501
    Jul  5 01:21:55 f6de2ba70eca otbr-agent[191]: 00:52:09.031 [I] MeshForwarder-:     dst:[fd11:22:0:0:33c1:f158:876a:7d0a]:5540
    Jul  5 01:21:55 f6de2ba70eca otbr-agent[191]: 00:52:09.124 [I] MeshForwarder-: Received IPv6 UDP msg, len:115, chksum:9ac8, ecn:no, from:0x6400, sec:yes, prio:normal, rss:-40.0
    Jul  5 01:21:55 f6de2ba70eca otbr-agent[191]: 00:52:09.124 [I] MeshForwarder-:     src:[fd11:22:0:0:33c1:f158:876a:7d0a]:5540
    Jul  5 01:21:55 f6de2ba70eca otbr-agent[191]: 00:52:09.124 [I] MeshForwarder-:     dst:[fd11:1111:1122:2222:3079:47c7:9eda:cb9a]:46501
    Jul  5 01:21:55 f6de2ba70eca otbr-agent[191]: 00:52:09.133 [I] MeshForwarder-: Sent IPv6 UDP msg, len:82, chksum:ab89, ecn:no, to:0x6400, sec:yes, prio:low
    Jul  5 01:21:55 f6de2ba70eca otbr-agent[191]: 00:52:09.133 [I] MeshForwarder-:     src:[fd11:1111:1122:2222:3079:47c7:9eda:cb9a]:46501
    Jul  5 01:21:55 f6de2ba70eca otbr-agent[191]: 00:52:09.133 [I] MeshForwarder-:     dst:[fd11:22:0:0:33c1:f158:876a:7d0a]:5540
    Jul  5 01:21:55 f6de2ba70eca otbr-agent[191]: 00:52:09.180 [I] MeshForwarder-: Received IPv6 UDP msg, len:206, chksum:88a0, ecn:no, from:0x6400, sec:yes, prio:normal, rss:-40.5
    Jul  5 01:21:55 f6de2ba70eca otbr-agent[191]: 00:52:09.180 [I] MeshForwarder-:     src:[fd4b:93b9:8e2f:21a9:e105:3c31:c9a6:c5fb]:49153
    Jul  5 01:21:55 f6de2ba70eca otbr-agent[191]: 00:52:09.180 [I] MeshForwarder-:     dst:[fd4b:93b9:8e2f:21a9:2cd6:7f27:11c9:efdf]:53
    Jul  5 01:21:55 f6de2ba70eca otbr-agent[191]: 00:52:09.180 [I] DnssdServer---: ANSWER: TRANSACTION=0x5f24, QUESTION=[8FAB4E5B9E78E4A4-0000000000000001._matter._tcp.default.service.arpa. 1 33], RCODE=3
    Jul  5 01:21:55 f6de2ba70eca otbr-agent[191]: 00:52:09.180 [I] DnssdServer---: ANSWER: TRANSACTION=0x5f24, QUESTION=[8FAB4E5B9E78E4A4-0000000000000001._matter._tcp.default.service.arpa. 1 16], RCODE=3
    Jul  5 01:21:55 f6de2ba70eca otbr-agent[191]: [INFO]-DPROXY--: Subscribe: 8FAB4E5B9E78E4A4-0000000000000001._matter._tcp.default.service.arpa.
    Jul  5 01:21:55 f6de2ba70eca otbr-agent[191]: [INFO]-MDNS----: Subscribe service 8FAB4E5B9E78E4A4-0000000000000001._matter._tcp (total 1)
    Jul  5 01:21:55 f6de2ba70eca otbr-agent[191]: [INFO]-MDNS----: DNSServiceResolve 8FAB4E5B9E78E4A4-0000000000000001 _matter._tcp inf 0
    Jul  5 01:21:55 f6de2ba70eca otbr-agent[191]: [INFO]-MDNS----: DNSServiceResolve reply: 8FAB4E5B9E78E4A4-0000000000000001._matter._tcp.local. host E0D55EB9F3140000.local.:42005, TXT=21B inf 6, flags=0
    Jul  5 01:21:55 f6de2ba70eca otbr-agent[191]: [INFO]-MDNS----: DNSServiceGetAddrInfo E0D55EB9F3140000.local. inf 6
    Jul  5 01:21:55 f6de2ba70eca otbr-agent[191]: [INFO]-MDNS----: DNSServiceGetAddrInfo reply: flags=1073741827, host=E0D55EB9F3140000.local., sa_family=10, error=0
    Jul  5 01:21:55 f6de2ba70eca otbr-agent[191]: [INFO]-MDNS----: DNSServiceGetAddrInfo reply: address=fd11:1111:1122:2222:3079:47c7:9eda:cb9a, ttl=120
    Jul  5 01:21:55 f6de2ba70eca otbr-agent[191]: [INFO]-MDNS----: Service _matter._tcp is resolved successfully: add 8FAB4E5B9E78E4A4-0000000000000001 host E0D55EB9F3140000.local. addresses 1
    Jul  5 01:21:55 f6de2ba70eca otbr-agent[191]: [INFO]-DPROXY--: Service discovered: _matter._tcp, instance 8FAB4E5B9E78E4A4-0000000000000001 hostname E0D55EB9F3140000.local. addresses 1 port 5540 priority 0 weight 0
    Jul  5 01:21:55 f6de2ba70eca otbr-agent[191]: [DEBG]-DPROXY--: Translate domain: E0D55EB9F3140000.local. => E0D55EB9F3140000.default.service.arpa.
    Jul  5 01:21:55 f6de2ba70eca otbr-agent[191]: [INFO]-DPROXY--: Unsubscribe: 8FAB4E5B9E78E4A4-0000000000000001._matter._tcp.default.service.arpa.
    Jul  5 01:21:55 f6de2ba70eca otbr-agent[191]: [INFO]-MDNS----: Unsubscribe service 8FAB4E5B9E78E4A4-0000000000000001._matter._tcp (left 0)
    Jul  5 01:21:55 f6de2ba70eca otbr-agent[191]: 00:52:09.181 [I] DnssdServer---: send DNS-SD reply: OK, RCODE=0
    Jul  5 01:21:55 f6de2ba70eca otbr-agent[191]: 00:52:09.205 [I] MeshForwarder-: Sent IPv6 UDP msg, len:257, chksum:4f65, ecn:no, to:0x6400, sec:yes, prio:normal
    Jul  5 01:21:55 f6de2ba70eca otbr-agent[191]: 00:52:09.205 [I] MeshForwarder-:     src:[fd4b:93b9:8e2f:21a9:2cd6:7f27:11c9:efdf]:53
    Jul  5 01:21:55 f6de2ba70eca otbr-agent[191]: 00:52:09.205 [I] MeshForwarder-:     dst:[fd4b:93b9:8e2f:21a9:e105:3c31:c9a6:c5fb]:49153
    Jul  5 01:21:55 f6de2ba70eca otbr-agent[191]: 00:52:09.583 [I] MeshForwarder-: Received IPv6 UDP msg, len:225, chksum:8bd1, ecn:no, from:0x6400, sec:yes, prio:normal, rss:-40.0
    Jul  5 01:21:55 f6de2ba70eca otbr-agent[191]: 00:52:09.583 [I] MeshForwarder-:     src:[fd11:22:0:0:33c1:f158:876a:7d0a]:5540
    Jul  5 01:21:55 f6de2ba70eca otbr-agent[191]: 00:52:09.583 [I] MeshForwarder-:     dst:[fd11:1111:1122:2222:3079:47c7:9eda:cb9a]:5540
    Jul  5 01:21:56 f6de2ba70eca otbr-agent[191]: 00:52:10.473 [I] MeshForwarder-: Received IPv6 UDP msg, len:225, chksum:8bd1, ecn:no, from:0x6400, sec:yes, prio:normal, rss:-41.25
    Jul  5 01:21:56 f6de2ba70eca otbr-agent[191]: 00:52:10.473 [I] MeshForwarder-:     src:[fd11:22:0:0:33c1:f158:876a:7d0a]:5540
    Jul  5 01:21:56 f6de2ba70eca otbr-agent[191]: 00:52:10.473 [I] MeshForwarder-:     dst:[fd11:1111:1122:2222:3079:47c7:9eda:cb9a]:5540
    Jul  5 01:21:57 f6de2ba70eca otbr-agent[191]: 00:52:11.339 [I] MeshForwarder-: Received IPv6 UDP msg, len:225, chksum:8bd1, ecn:no, from:0x6400, sec:yes, prio:normal, rss:-41.0
    Jul  5 01:21:57 f6de2ba70eca otbr-agent[191]: 00:52:11.340 [I] MeshForwarder-:     src:[fd11:22:0:0:33c1:f158:876a:7d0a]:5540
    Jul  5 01:21:57 f6de2ba70eca otbr-agent[191]: 00:52:11.340 [I] MeshForwarder-:     dst:[fd11:1111:1122:2222:3079:47c7:9eda:cb9a]:5540
    Jul  5 01:21:58 f6de2ba70eca otbr-agent[191]: 00:52:12.464 [I] MeshForwarder-: Received IPv6 UDP msg, len:225, chksum:8bd1, ecn:no, from:0x6400, sec:yes, prio:normal, rss:-41.0
    Jul  5 01:21:58 f6de2ba70eca otbr-agent[191]: 00:52:12.464 [I] MeshForwarder-:     src:[fd11:22:0:0:33c1:f158:876a:7d0a]:5540
    Jul  5 01:21:58 f6de2ba70eca otbr-agent[191]: 00:52:12.464 [I] MeshForwarder-:     dst:[fd11:1111:1122:2222:3079:47c7:9eda:cb9a]:5540
    Jul  5 01:22:00 f6de2ba70eca otbr-agent[191]: 00:52:13.958 [I] MeshForwarder-: Received IPv6 UDP msg, len:225, chksum:8bd1, ecn:no, from:0x6400, sec:yes, prio:normal, rss:-41.0
    Jul  5 01:22:00 f6de2ba70eca otbr-agent[191]: 00:52:13.958 [I] MeshForwarder-:     src:[fd11:22:0:0:33c1:f158:876a:7d0a]:5540
    Jul  5 01:22:00 f6de2ba70eca otbr-agent[191]: 00:52:13.958 [I] MeshForwarder-:     dst:[fd11:1111:1122:2222:3079:47c7:9eda:cb9a]:5540
    Jul  5 01:22:09 f6de2ba70eca otbr-agent[191]: 00:52:22.967 [I] Mle-----------: Send Advertisement (ff02:0:0:0:0:0:0:1)
    Jul  5 01:22:09 f6de2ba70eca otbr-agent[191]: 00:52:22.971 [I] MeshForwarder-: Sent IPv6 UDP msg, len:91, chksum:872d, ecn:no, to:0xffff, sec:no, prio:net
    Jul  5 01:22:09 f6de2ba70eca otbr-agent[191]: 00:52:22.971 [I] MeshForwarder-:     src:[fe80:0:0:0:c11:c613:ac00:ab74]:19788
    Jul  5 01:22:09 f6de2ba70eca otbr-agent[191]: 00:52:22.971 [I] MeshForwarder-:     dst:[ff02:0:0:0:0:0:0:1]:19788
    Jul  5 01:22:13 f6de2ba70eca otbr-agent[191]: 00:52:27.630 [I] MeshForwarder-: Received IPv6 UDP msg, len:91, chksum:5158, ecn:no, from:46f1453276713147, sec:no, prio:net, rss:-40.0
    Jul  5 01:22:13 f6de2ba70eca otbr-agent[191]: 00:52:27.630 [I] MeshForwarder-:     src:[fe80:0:0:0:44f1:4532:7671:3147]:19788
    Jul  5 01:22:13 f6de2ba70eca otbr-agent[191]: 00:52:27.630 [I] MeshForwarder-:     dst:[ff02:0:0:0:0:0:0:1]:19788
    Jul  5 01:22:13 f6de2ba70eca otbr-agent[191]: 00:52:27.630 [I] Mle-----------: Receive Advertisement (fe80:0:0:0:44f1:4532:7671:3147,0x6400)
    - Wire Shark capture
    Cp3.pcapng
    Unlike before, OTBR also showed a response during the announce-otaprovider.
    2. Yes, I configured it the same as the site guide. But could you check if the environment we organized is correct? The configuration is as follows.
    (Please let me know if you need additional confirmation of our configuration environment)
    - OTBR Form Therd Networks
    Lastly, can I get the OTA file (Build Target: nrf52840DK) that the Matter team used?
    I'd like to replace the OTA file we used for the test.
    Thank you..Smile
    Starting with the "simplest" first:
    The topology looks correct. The CHIP tool is missing in the picture, but we assume that it is running on the Ubuntu PC on the left (you've mentioned this at some point).
    Here's the files
    Matter_OTA_files.zip
    Once again it looks like everything should be fine with your setup, but the logs looks similar. The CASE Sigma1 message is not forwarded by the OTBR to the OTA Provider so we strongly believe that it is caused by a routing issue related to the used IP addresses, but what is strange is that a couple of messages before this should occur, the OTBR is able to forward messages to the CHIP Tool running on the same PC and using the same IP addresses. The Matter devs will be looking into this, but for now this is unfortunately where we're stuck
    I will let you know if they conclude on anything, but do note that we're entering the main summer vacation period here in Norway so response time will be slower from now on and out
    I apologize for the inconvenience that may cause, and I hope we're able to resolve the issue in spite of the longer response time
    Andreas
