facing issues with commissioning the matter light_bulb with chip-tool
As i was doing some sample example Light_bulb that is given in the nrf connect 1.0 but wile commissioning the light_bulb with chip-tool as controller facing issues
So. logs for the device is
D: 1025349 [IN]SecureSession[0x20003568]: Allocated Type:1 LSID:23439
I: 1025355 [DIS]Updating services using commissioning mode 1
I: 1025362 [DIS]Advertise commission parameter vendorID=65521 productID=32773 discriminator=3840/15 cm=1
E: 1025372 [DIS]Failed to advertise commissionable node: 3
E: 1025377 [DIS]Failed to finalize service update: 1c
I: 1025384 [DL]CHIPoBLE advertising started
I: 1025389 [DL]NFC Tag emulation started
I: 1029114 [DL]BLE connection established (ConnId: 0x00)
I: 1029119 [DL]Current number of connections: 1/1
I: 1029123 [DL]CHIPoBLE advertising stopped
I: 1029127 [DL]NFC Tag emulation stopped
I: 1030907 [BLE]local and remote recv window sizes = 5
I: 1030912 [BLE]selected BTP version 4
I: 1030916 [BLE]using BTP fragment sizes rx 244 / tx 244.
D: 1030998 [IN]BLE EndPoint 0x200124d8 Connection Complete
I: 1031003 [DL]CHIPoBLE connection established (ConnId: 0x00, GATT MTU: 247)
I: 1031089 [EM]>>> [E:28294r M:134199296] (U) Msg RX from 0:393CD4B3AB64E865 [0000] --- Type 0000:20 (Secu)
I: 1031101 [EM]<<< [E:28294r M:156394311] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:21 (Secure)
I: 1031113 [IN](U) Sending msg 156394311 to IP address 'BLE'
I: 1031179 [EM]>>> [E:28294r M:134199297] (U) Msg RX from 0:393CD4B3AB64E865 [0000] --- Type 0000:22 (Secu)
I: 1033064 [EM]<<< [E:28294r M:156394312] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:23 (Secure)
I: 1033075 [IN](U) Sending msg 156394312 to IP address 'BLE'
E: 1033081 [DL]Long dispatch time: 1903 ms, for event type 16388
I: 1033159 [EM]>>> [E:28294r M:134199298] (U) Msg RX from 0:393CD4B3AB64E865 [0000] --- Type 0000:24 (Secu)
I: 1033170 [EM]<<< [E:28294r M:156394313] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:40 (Secure)
I: 1033182 [IN](U) Sending msg 156394313 to IP address 'BLE'
I: 1033188 [SC]SecureSession[0x20003568]: Moving from state 'kEstablishing' --> 'kActive'
D: 1033196 [IN]SecureSession[0x20003568]: Activated - Type:1 LSID:23439
D: 1033203 [IN]New secure session activated for device <FFFFFFFB00000000, 0>, LSID:23439 PSID:51082!
I: 1033212 [SVR]Commissioning completed session establishment step
I: 1033218 [DIS]Updating services using commissioning mode 0
I: 1033225 [DIS]Advertise commission parameter vendorID=65521 productID=32773 discriminator=3840/15 cm=0
E: 1033234 [DIS]Failed to advertise extended commissionable node: 3
D: 1033240 [DIS]Scheduling extended discovery timeout in 900s
E: 1033246 [DIS]Failed to finalize service update: 1c
I: 1033252 [SVR]Device completed Rendezvous process
I: 1033258 [EM]>>> [E:28295r M:120615681] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:R)
D: 1033268 [IM]Received Read request
I: 1033277 [EM]<<< [E:28295r M:84530903] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:05 (IM:Repo)
I: 1033287 [IN](S) Sending msg 84530903 on secure session with LSID: 23439
I: 1033519 [EM]>>> [E:28296r M:120615682] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:I)
I: 1033531 [FS]GeneralCommissioning: Received ArmFailSafe (60s)
I: 1033538 [EM]<<< [E:28296r M:84530904] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:Invo)
I: 1033549 [IN](S) Sending msg 84530904 on secure session with LSID: 23439
I: 1033609 [EM]>>> [E:28297r M:120615683] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:I)
I: 1033623 [EM]<<< [E:28297r M:84530905] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:Invo)
I: 1033634 [IN](S) Sending msg 84530905 on secure session with LSID: 23439
I: 1033699 [EM]>>> [E:28298r M:120615684] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:I)
I: 1033711 [ZCL]OpCreds: Certificate Chain request received for PAI
I: 1033720 [EM]<<< [E:28298r M:84530906] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:Invo)
I: 1033731 [IN](S) Sending msg 84530906 on secure session with LSID: 23439
I: 1033969 [EM]>>> [E:28299r M:120615685] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:I)
I: 1033981 [ZCL]OpCreds: Certificate Chain request received for DAC
I: 1033990 [EM]<<< [E:28299r M:84530907] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:Invo)
I: 1034001 [IN](S) Sending msg 84530907 on secure session with LSID: 23439
I: 1034239 [EM]>>> [E:28300r M:120615686] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:I)
I: 1034251 [ZCL]OpCreds: Received an AttestationRequest command
I: 1034288 [ZCL]OpCreds: AttestationRequest successful.
I: 1034296 [EM]<<< [E:28300r M:84530908] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:Invo)
I: 1034307 [IN](S) Sending msg 84530908 on secure session with LSID: 23439
I: 1034554 [EM]>>> [E:28301r M:120615687] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:I)
I: 1034566 [ZCL]OpCreds: Received a CSRRequest command
I: 1034757 [ZCL]OpCreds: AllocatePendingOperationalKey succeeded
I: 1034793 [ZCL]OpCreds: CSRRequest successful.
I: 1034800 [EM]<<< [E:28301r M:84530909] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:Invo)
I: 1034811 [IN](S) Sending msg 84530909 on secure session with LSID: 23439
E: 1034817 [DL]Long dispatch time: 264 ms, for event type 16388
I: 1035050 [EM]>>> [E:28302r M:120615688] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:I)
I: 1035061 [ZCL]OpCreds: Received an AddTrustedRootCertificate command
I: 1035124 [ZCL]OpCreds: AddTrustedRootCertificate successful.
I: 1035131 [EM]<<< [E:28302r M:84530910] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:Invo)
I: 1035142 [IN](S) Sending msg 84530910 on secure session with LSID: 23439
E: 1035149 [DL]Long dispatch time: 101 ms, for event type 16388
I: 1035411 [EM]>>> [E:28303r M:120615689] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:I)
I: 1035423 [ZCL]OpCreds: Received an AddNOC command
I: 1035430 [FP]Validating NOC chain
I: 1035547 [FP]NOC chain validation successful
I: 1035552 [FP]Added new fabric at index: 0x1
I: 1035556 [FP]Assigned compressed fabric ID: 0xB11330A3FC78D426, node ID: 0x0000000000000001
I: 1035564 [TS]Last Known Good Time: 2023-06-23T09:32:58
I: 1035569 [TS]New proposed Last Known Good Time: 2021-01-01T00:00:00
I: 1035575 [TS]Retaining current Last Known Good Time
I: 1035601 [ZCL]OpCreds: ACL entry created for Fabric index 0x1 CASE Admin Subject 0x000000000001B669
I: 1035610 [DIS]Advertise operational node B11330A3FC78D426-0000000000000001
I: 1035617 [ZCL]OpCreds: successfully created fabric index 0x1 via AddNOC
I: 1035624 [EM]<<< [E:28303r M:84530911] (S) Msg TX to 1:FFFFFFFB00000000 [D426] --- Type 0001:09 (IM:Invo)
I: 1035635 [IN](S) Sending msg 84530911 on secure session with LSID: 23439
E: 1035642 [DL]Long dispatch time: 234 ms, for event type 16388
I: 1035725 [EM]>>> [E:28304r M:120615690] (S) Msg RX from 1:FFFFFFFB00000000 [D426] --- Type 0001:08 (IM:I)
I: 1035743 [EM]<<< [E:28304r M:84530912] (S) Msg TX to 1:FFFFFFFB00000000 [D426] --- Type 0001:09 (IM:Invo)
I: 1035754 [IN](S) Sending msg 84530912 on secure session with LSID: 23439
I: 1035814 [EM]>>> [E:28305r M:120615691] (S) Msg RX from 1:FFFFFFFB00000000 [D426] --- Type 0001:08 (IM:I)
I: 1064178 [DL]SRP Client was started, detected server: fd36:f93b:1aa0:ce03:52bc:82e4:351d:8e44
I: 1064191 [EM]<<< [E:28305r M:84530913] (S) Msg TX to 1:FFFFFFFB00000000 [D426] --- Type 0001:09 (IM:Invo)
I: 1064202 [IN](S) Sending msg 84530913 on secure session with LSID: 23439
I: 1064209 [DIS]Advertise operational node B11330A3FC78D426-0000000000000001
I: 1064216 [SVR]Operational advertising enabled
I: 1065023 [DIS]Setting operational delegate post init
I: 1065032 [SWU]Stopping the watchdog timer
I: 1065036 [SWU]Starting the periodic query timer, timeout: 86400 seconds
I: 1065042 [DIS]Updating services using commissioning mode 0
I: 1065048 [DIS]Advertise operational node B11330A3FC78D426-0000000000000001
I: 1065055 [DL]advertising srp service: B11330A3FC78D426-0000000000000001._matter._tcp
I: 1065064 [DIS]Advertise commission parameter vendorID=65521 productID=32773 discriminator=3840/15 cm=0
I: 1065074 [DL]advertising srp service: B9F3F83F698476BA._matterc._udp
E: 1065360 [DL]SRP update error: domain name or RRset is duplicated
E: 1070179 [DL]SRP update error: timed out waiting on server response
E: 1070722 [DL]SRP update error: domain name or RRset is duplicated
E: 1075960 [DL]SRP update error: domain name or RRset is duplicated
E: 1084854 [DL]SRP update error: domain name or RRset is duplicated
I: 1093537 [FS]Fail-safe timer expired
E: 1093540 [SVR]Failsafe timer expired
D: 1093544 [IN]SecureSession[0x20003568]: MarkForEviction Type:1 LSID:23439
I: 1093551 [SC]SecureSession[0x20003568]: Moving from state 'kActive' --> 'kPendingEviction'
D: 1093559 [IN]SecureSession[0x20003568]: Released - Type:1 LSID:23439
E: 1093565 [SVR]Commissioning failed (attempt 1): 32
D: 1093570 [IN]Clearing BLE pending packets.
I: 1093574 [BLE]Releasing end point's BLE connection back to application.
I: 1093581 [DL]Closing BLE GATT connection (ConnId 00)
D: 1093588 [IN]SecureSession[0x20003568]: Allocated Type:1 LSID:23440
I: 1093595 [DIS]Updating services using commissioning mode 1
I: 1093600 [DIS]Advertise operational node B11330A3FC78D426-0000000000000001
I: 1093608 [DIS]Advertise commission parameter vendorID=65521 productID=32773 discriminator=3840/15 cm=1
I: 1093618 [DL]advertising srp service: B9F3F83F698476BA._matterc._udp
E: 1093624 [ZCL]OpCreds: Got FailSafeTimerExpired
E: 1093629 [ZCL]OpCreds: Proceeding to FailSafeCleanup on fail-safe expiry!
D: 1093636 [IN]Expiring all sessions for fabric 0x1!!
E: 1093641 [FP]Reverting pending fabric data for fabric 0x1
E: 1093647 [FP]Warning: metadata not found during delete of fabric 0x1
I: 1093658 [FP]Fabric (0x1) deleted.
I: 1093662 [ZCL]OpCreds: Fabric index 0x1 was removed
I: 1093667 [DIS]Updating services using commissioning mode 1
I: 1093673 [DIS]Advertise commission parameter vendorID=65521 productID=32773 discriminator=3840/15 cm=1
I: 1093683 [DL]advertising srp service: B9F3F83F698476BA._matterc._udp
I: 1093689 [DL]removing srp service: B11330A3FC78D426-0000000000000001._matter._tcp
I: 1093816 [TS]Pending Last Known Good Time: 2023-06-23T09:32:58
I: 1093823 [TS]Previous Last Known Good Time: 2023-06-23T09:32:58
I: 1093828 [TS]Reverted Last Known Good Time to previous value
E: 1093835 [FP]Warning: metadata not found during delete of fabric 0x1
E: 1093844 [ZCL]OpCreds: failed to delete fabric at index 1: d8
I: 1093850 [NP]Reverting Thread operational dataset
E: 1093860 [DL]Long dispatch time: 320 ms, for event type 32782
I: 1093866 [FS]Fail-safe cleanly disarmed
I: 1093871 [DL]BLE GAP connection terminated (reason 0x16)
I: 1093877 [DL]Current number of connections: 0/1
I: 1093883 [DL]CHIPoBLE advertising started
I: 1093888 [DL]NFC Tag emulation started
and the logs for the chip-tool for pc is
./chip-tool-release pairing ble-thread 1 hex:0e080000000000010000000300001135060004001fffe002086fa9d405754a44f70708fd36f93b1aa0ce030510d645ad53670e4076efbce31100978b2b030f4f70656e5468726561642d393133630102913c041090de57e044a398375de7f887ec9670af0c0402a0f7f8 20202021 3840
[1687496900.819313][12710:12710] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-JyntcP)
[1687496900.819519][12710:12710] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
[1687496900.819535][12710:12710] CHIP:DL: NVS set: chip-counters/reboot-count = 9 (0x9)
[1687496900.819826][12710:12710] CHIP:DL: Got Ethernet interface: enp2s0
[1687496900.819991][12710:12710] CHIP:DL: Found the primary Ethernet interface:enp2s0
[1687496900.820172][12710:12710] CHIP:DL: Got WiFi interface: wlp0s20f3
[1687496900.821155][12710:12710] CHIP:DL: Found the primary WiFi interface:wlp0s20f3
[1687496900.821262][12710:12710] CHIP:TS: Last Known Good Time: 2023-03-02T09:28:16
[1687496900.821383][12710:12710] CHIP:FP: Fabric index 0x1 was retrieved from storage. Compressed FabricId 0xB11330A3FC78D426, FabricId 0x0000000000000001, NodeId 0x000000000001B669, VendorId 0xFFF1
[1687496900.821812][12710:12710] CHIP:ZCL: Using ZAP configuration...
[1687496900.823019][12710:12710] CHIP:DL: Avahi client registered
[1687496900.823352][12710:12710] CHIP:CTL: Setting attestation nonce to random value
[1687496900.823363][12710:12710] CHIP:CTL: Setting CSR nonce to random value
[1687496900.823789][12710:12712] CHIP:CTL: Setting attestation nonce to random value
[1687496900.823803][12710:12712] CHIP:CTL: Setting CSR nonce to random value
[1687496900.826169][12710:12712] CHIP:CTL: Generating NOC
[1687496900.828612][12710:12712] CHIP:FP: Validating NOC chain
[1687496900.837266][12710:12712] CHIP:FP: NOC chain validation successful
[1687496900.837278][12710:12712] CHIP:FP: Updated fabric at index: 0x1, Node ID: 0x000000000001B669
[1687496900.837282][12710:12712] CHIP:TS: Last Known Good Time: 2023-03-02T09:28:16
[1687496900.837284][12710:12712] CHIP:TS: New proposed Last Known Good Time: 2021-01-01T00:00:00
[1687496900.837285][12710:12712] CHIP:TS: Retaining current Last Known Good Time
[1687496900.837726][12710:12712] CHIP:FP: Metadata for Fabric 0x1 persisted to storage.
[1687496900.838003][12710:12712] CHIP:TS: Committing Last Known Good Time to storage: 2023-03-02T09:28:16
[1687496900.838478][12710:12712] CHIP:CTL: Joined the fabric at index 1. Fabric ID is 0x0000000000000001 (Compressed Fabric ID: B11330A3FC78D426)
[1687496900.841153][12710:12712] CHIP:CTL: Setting thread operational dataset from parameters
[1687496900.841163][12710:12712] CHIP:CTL: Setting attempt thread scan from parameters
[1687496900.841174][12710:12712] CHIP:CTL: Setting attestation nonce to random value
[1687496900.841186][12710:12712] CHIP:CTL: Setting CSR nonce to random value
[1687496900.841190][12710:12712] CHIP:CTL: Setting PASE-only commissioning from parameters
[1687496900.841194][12710:12712] CHIP:CTL: Commission called for node ID 0x0000000000000001
[1687496900.844627][12710:12711] CHIP:BLE: BLE removing known devices.
[1687496900.844867][12710:12711] CHIP:BLE: BLE initiating scan.
[1687496900.966241][12710:12712] CHIP:DL: Long dispatch time: 125 ms, for event type 2
[1687496900.982151][12710:12711] CHIP:BLE: New device scanned: ED:37:F1:0F:75:5A
[1687496900.982175][12710:12711] CHIP:BLE: Device discriminator match. Attempting to connect.
[1687496900.986963][12710:12711] CHIP:BLE: Scan complete notification without an active scan.
[1687496902.457944][12710:12712] CHIP:DIS: Closing all BLE connections
[1687496902.458004][12710:12712] CHIP:EM: <<< [E:28294i M:134199296] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:20 (SecureChannel:PBKDFParamRequest)
[1687496902.458012][12710:12712] CHIP:IN: (U) Sending msg 134199296 to IP address 'BLE'
[1687496903.029800][12710:12712] CHIP:BLE: subscribe complete, ep = 0x556402315d60
[1687496903.030164][12710:12712] CHIP:BLE: peripheral chose BTP version 4; central expected between 4 and 4
[1687496903.030193][12710:12712] CHIP:BLE: using BTP fragment sizes rx 244 / tx 244.
[1687496903.030202][12710:12712] CHIP:BLE: local and remote recv window size = 5
[1687496903.120920][12710:12712] CHIP:EM: >>> [E:28294i M:156394311] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:21 (SecureChannel:PBKDFParamResponse)
[1687496903.133864][12710:12712] CHIP:EM: <<< [E:28294i M:134199297] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:22 (SecureChannel:PASE_Pake1)
[1687496903.133872][12710:12712] CHIP:IN: (U) Sending msg 134199297 to IP address 'BLE'
[1687496905.101107][12710:12712] CHIP:EM: >>> [E:28294i M:156394312] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:23 (SecureChannel:PASE_Pake2)
[1687496905.111516][12710:12712] CHIP:EM: <<< [E:28294i M:134199298] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:24 (SecureChannel:PASE_Pake3)
[1687496905.111530][12710:12712] CHIP:IN: (U) Sending msg 134199298 to IP address 'BLE'
[1687496905.189864][12710:12712] CHIP:EM: >>> [E:28294i M:156394313] (U) Msg RX from 0:0000000000000000 [0000] --- Type 0000:40 (SecureChannel:StatusReport)
[1687496905.189969][12710:12712] CHIP:SC: SecureSession[0x7fbd0000e800]: Moving from state 'kEstablishing' --> 'kActive'
[1687496905.189984][12710:12712] CHIP:TOO: Pairing Success
[1687496905.189993][12710:12712] CHIP:TOO: PASE establishment successful
[1687496905.190005][12710:12712] CHIP:CTL: Commissioning stage next step: 'SecurePairing' -> 'ReadCommissioningInfo'
[1687496905.190017][12710:12712] CHIP:CTL: Performing next commissioning step 'ReadCommissioningInfo'
[1687496905.190026][12710:12712] CHIP:CTL: Sending request for commissioning information
[1687496905.190121][12710:12712] CHIP:EM: <<< [E:28295i M:120615681] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:02 (IM:ReadRequest)
[1687496905.190137][12710:12712] CHIP:IN: (S) Sending msg 120615681 on secure session with LSID: 51082
[1687496905.460289][12710:12712] CHIP:EM: >>> [E:28295i M:84530903] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:05 (IM:ReportData)
[1687496905.460911][12710:12712] CHIP:CTL: ----- NetworkCommissioning Features: has Thread. endpointid = 0
[1687496905.460959][12710:12712] CHIP:CTL: Successfully finished commissioning step 'ReadCommissioningInfo'
[1687496905.460972][12710:12712] CHIP:CTL: Commissioning stage next step: 'ReadCommissioningInfo' -> 'ArmFailSafe'
[1687496905.460983][12710:12712] CHIP:CTL: Performing next commissioning step 'ArmFailSafe'
[1687496905.460989][12710:12712] CHIP:CTL: Arming failsafe (60 seconds)
[1687496905.461062][12710:12712] CHIP:EM: <<< [E:28296i M:120615682] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
[1687496905.461081][12710:12712] CHIP:IN: (S) Sending msg 120615682 on secure session with LSID: 51082
[1687496905.550314][12710:12712] CHIP:EM: >>> [E:28296i M:84530904] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
[1687496905.550504][12710:12712] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0001
[1687496905.550560][12710:12712] CHIP:CTL: Received ArmFailSafe response errorCode=0
[1687496905.550574][12710:12712] CHIP:CTL: Successfully finished commissioning step 'ArmFailSafe'
[1687496905.550583][12710:12712] CHIP:CTL: Commissioning stage next step: 'ArmFailSafe' -> 'ConfigRegulatory'
[1687496905.550596][12710:12712] CHIP:CTL: Performing next commissioning step 'ConfigRegulatory'
[1687496905.550603][12710:12712] CHIP:CTL: Setting Regulatory Config
[1687496905.550617][12710:12712] CHIP:CTL: Device does not support configurable regulatory location
[1687496905.550689][12710:12712] CHIP:EM: <<< [E:28297i M:120615683] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
[1687496905.550704][12710:12712] CHIP:IN: (S) Sending msg 120615683 on secure session with LSID: 51082
[1687496905.640313][12710:12712] CHIP:EM: >>> [E:28297i M:84530905] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
[1687496905.640428][12710:12712] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_0030 Command=0x0000_0003
[1687496905.640450][12710:12712] CHIP:CTL: Received SetRegulatoryConfig response errorCode=0
[1687496905.640463][12710:12712] CHIP:CTL: Successfully finished commissioning step 'ConfigRegulatory'
[1687496905.640469][12710:12712] CHIP:CTL: Commissioning stage next step: 'ConfigRegulatory' -> 'SendPAICertificateRequest'
[1687496905.640478][12710:12712] CHIP:CTL: Performing next commissioning step 'SendPAICertificateRequest'
[1687496905.640484][12710:12712] CHIP:CTL: Sending request for PAI certificate
[1687496905.640569][12710:12712] CHIP:EM: <<< [E:28298i M:120615684] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
[1687496905.640584][12710:12712] CHIP:IN: (S) Sending msg 120615684 on secure session with LSID: 51082
[1687496905.910677][12710:12712] CHIP:EM: >>> [E:28298i M:84530906] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
[1687496905.910836][12710:12712] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_003E Command=0x0000_0003
[1687496905.910861][12710:12712] CHIP:CTL: Received certificate chain from the device
[1687496905.910881][12710:12712] CHIP:CTL: Successfully finished commissioning step 'SendPAICertificateRequest'
[1687496905.910897][12710:12712] CHIP:CTL: Commissioning stage next step: 'SendPAICertificateRequest' -> 'SendDACCertificateRequest'
[1687496905.910911][12710:12712] CHIP:CTL: Performing next commissioning step 'SendDACCertificateRequest'
[1687496905.910928][12710:12712] CHIP:CTL: Sending request for DAC certificate
[1687496905.911023][12710:12712] CHIP:EM: <<< [E:28299i M:120615685] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
[1687496905.911043][12710:12712] CHIP:IN: (S) Sending msg 120615685 on secure session with LSID: 51082
[1687496906.180869][12710:12712] CHIP:EM: >>> [E:28299i M:84530907] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
[1687496906.181011][12710:12712] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_003E Command=0x0000_0003
[1687496906.181031][12710:12712] CHIP:CTL: Received certificate chain from the device
[1687496906.181047][12710:12712] CHIP:CTL: Successfully finished commissioning step 'SendDACCertificateRequest'
[1687496906.181060][12710:12712] CHIP:CTL: Commissioning stage next step: 'SendDACCertificateRequest' -> 'SendAttestationRequest'
[1687496906.181075][12710:12712] CHIP:CTL: Performing next commissioning step 'SendAttestationRequest'
[1687496906.181087][12710:12712] CHIP:CTL: Sending Attestation Request to the device.
[1687496906.181168][12710:12712] CHIP:EM: <<< [E:28300i M:120615686] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
[1687496906.181187][12710:12712] CHIP:IN: (S) Sending msg 120615686 on secure session with LSID: 51082
[1687496906.497127][12710:12712] CHIP:EM: >>> [E:28300i M:84530908] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
[1687496906.497273][12710:12712] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_003E Command=0x0000_0001
[1687496906.497298][12710:12712] CHIP:CTL: Received Attestation Information from the device
[1687496906.497318][12710:12712] CHIP:CTL: Successfully finished commissioning step 'SendAttestationRequest'
[1687496906.497339][12710:12712] CHIP:CTL: Commissioning stage next step: 'SendAttestationRequest' -> 'AttestationVerification'
[1687496906.497354][12710:12712] CHIP:CTL: Performing next commissioning step 'AttestationVerification'
[1687496906.497363][12710:12712] CHIP:CTL: Verifying attestation
[1687496906.514113][12710:12712] CHIP:CR: mbedTLS error: ERROR - Generic error
[1687496906.529906][12710:12712] CHIP:CTL: Successfully validated 'Attestation Information' command received from the device.
[1687496906.529916][12710:12712] CHIP:CTL: Successfully finished commissioning step 'AttestationVerification'
[1687496906.529918][12710:12712] CHIP:CTL: Commissioning stage next step: 'AttestationVerification' -> 'SendOpCertSigningRequest'
[1687496906.529922][12710:12712] CHIP:CTL: Performing next commissioning step 'SendOpCertSigningRequest'
[1687496906.529964][12710:12712] CHIP:EM: <<< [E:28301i M:120615687] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
[1687496906.529969][12710:12712] CHIP:IN: (S) Sending msg 120615687 on secure session with LSID: 51082
[1687496906.901141][12710:12712] CHIP:EM: >>> [E:28301i M:84530909] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
[1687496906.901268][12710:12712] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_003E Command=0x0000_0005
[1687496906.901287][12710:12712] CHIP:CTL: Received certificate signing request from the device
[1687496906.901302][12710:12712] CHIP:CTL: Successfully finished commissioning step 'SendOpCertSigningRequest'
[1687496906.901311][12710:12712] CHIP:CTL: Commissioning stage next step: 'SendOpCertSigningRequest' -> 'ValidateCSR'
[1687496906.901321][12710:12712] CHIP:CTL: Performing next commissioning step 'ValidateCSR'
[1687496906.917375][12710:12712] CHIP:CTL: Successfully finished commissioning step 'ValidateCSR'
[1687496906.917383][12710:12712] CHIP:CTL: Commissioning stage next step: 'ValidateCSR' -> 'GenerateNOCChain'
[1687496906.917389][12710:12712] CHIP:CTL: Performing next commissioning step 'GenerateNOCChain'
[1687496906.917394][12710:12712] CHIP:CTL: Getting certificate chain for the device from the issuer
[1687496906.917419][12710:12712] CHIP:CTL: Verifying Certificate Signing Request
[1687496906.925488][12710:12712] CHIP:CTL: Generating NOC
[1687496906.927741][12710:12712] CHIP:CTL: Providing certificate chain to the commissioner
[1687496906.927745][12710:12712] CHIP:CTL: Received callback from the CA for NOC Chain generation. Status ../../src/controller/ExampleOperationalCredentialsIssuer.cpp:396: Success
[1687496906.927747][12710:12712] CHIP:CTL: Successfully finished commissioning step 'GenerateNOCChain'
[1687496906.927768][12710:12712] CHIP:CTL: Performing next commissioning step 'SendTrustedRootCert'
[1687496906.927772][12710:12712] CHIP:CTL: Sending root certificate to the device
[1687496906.927802][12710:12712] CHIP:EM: <<< [E:28302i M:120615688] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
[1687496906.927807][12710:12712] CHIP:IN: (S) Sending msg 120615688 on secure session with LSID: 51082
[1687496906.927823][12710:12712] CHIP:CTL: Sent root certificate to the device
[1687496907.170136][12710:12712] CHIP:EM: >>> [E:28302i M:84530910] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
[1687496907.170245][12710:12712] CHIP:DMG: Received Command Response Status for Endpoint=0 Cluster=0x0000_003E Command=0x0000_000B Status=0x0
[1687496907.170260][12710:12712] CHIP:CTL: Device confirmed that it has received the root certificate
[1687496907.170278][12710:12712] CHIP:CTL: Successfully finished commissioning step 'SendTrustedRootCert'
[1687496907.170292][12710:12712] CHIP:CTL: Commissioning stage next step: 'SendTrustedRootCert' -> 'SendNOC'
[1687496907.170308][12710:12712] CHIP:CTL: Performing next commissioning step 'SendNOC'
[1687496907.170415][12710:12712] CHIP:EM: <<< [E:28303i M:120615689] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
[1687496907.170436][12710:12712] CHIP:IN: (S) Sending msg 120615689 on secure session with LSID: 51082
[1687496907.170486][12710:12712] CHIP:CTL: Sent operational certificate to the device
[1687496907.665134][12710:12712] CHIP:EM: >>> [E:28303i M:84530911] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
[1687496907.665242][12710:12712] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_003E Command=0x0000_0008
[1687496907.665259][12710:12712] CHIP:CTL: Device returned status 0 on receiving the NOC
[1687496907.665265][12710:12712] CHIP:CTL: Operational credentials provisioned on device 0x7fbd0000ba00
[1687496907.665271][12710:12712] CHIP:TOO: Secure Pairing Success
[1687496907.665275][12710:12712] CHIP:TOO: CASE establishment successful
[1687496907.665285][12710:12712] CHIP:CTL: Successfully finished commissioning step 'SendNOC'
[1687496907.665292][12710:12712] CHIP:CTL: No NetworkScan enabled or WiFi/Thread endpoint not specified, skipping ScanNetworks
[1687496907.665298][12710:12712] CHIP:CTL: Commissioning stage next step: 'SendNOC' -> 'ThreadNetworkSetup'
[1687496907.665306][12710:12712] CHIP:CTL: Performing next commissioning step 'ThreadNetworkSetup'
[1687496907.665365][12710:12712] CHIP:EM: <<< [E:28304i M:120615690] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
[1687496907.665378][12710:12712] CHIP:IN: (S) Sending msg 120615690 on secure session with LSID: 51082
[1687496907.755239][12710:12712] CHIP:EM: >>> [E:28304i M:84530912] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
[1687496907.755335][12710:12712] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_0031 Command=0x0000_0005
[1687496907.757569][12710:12712] CHIP:CTL: Received NetworkConfig response, networkingStatus=0
[1687496907.757585][12710:12712] CHIP:CTL: Successfully finished commissioning step 'ThreadNetworkSetup'
[1687496907.757596][12710:12712] CHIP:CTL: Commissioning stage next step: 'ThreadNetworkSetup' -> 'ThreadNetworkEnable'
[1687496907.757605][12710:12712] CHIP:CTL: Performing next commissioning step 'ThreadNetworkEnable'
[1687496907.757669][12710:12712] CHIP:EM: <<< [E:28305i M:120615691] (S) Msg TX to 0:FFFFFFFB00000000 [0000] --- Type 0001:08 (IM:InvokeCommandRequest)
[1687496907.757684][12710:12712] CHIP:IN: (S) Sending msg 120615691 on secure session with LSID: 51082
[1687496936.240354][12710:12712] CHIP:EM: >>> [E:28305i M:84530913] (S) Msg RX from 0:FFFFFFFB00000000 [0000] --- Type 0001:09 (IM:InvokeCommandResponse)
[1687496936.240488][12710:12712] CHIP:DMG: Received Command Response Data, Endpoint=0 Cluster=0x0000_0031 Command=0x0000_0007
[1687496936.240513][12710:12712] CHIP:CTL: Received ConnectNetwork response, networkingStatus=0
[1687496936.240528][12710:12712] CHIP:CTL: Successfully finished commissioning step 'ThreadNetworkEnable'
[1687496936.240540][12710:12712] CHIP:CTL: Commissioning stage next step: 'ThreadNetworkEnable' -> 'FindOperational'
[1687496936.240553][12710:12712] CHIP:CTL: Performing next commissioning step 'FindOperational'
[1687496936.240581][12710:12712] CHIP:DIS: Resolving B11330A3FC78D426:0000000000000001 ...
[1687496936.440931][12710:12712] CHIP:DIS: Checking node lookup status after 200 ms
[1687496941.244400][12710:12712] CHIP:DL: Re-trying resolve
[1687496946.249386][12710:12712] CHIP:DL: Re-trying resolve
[1687496951.252339][12710:12712] CHIP:DL: Re-trying resolve
[1687496956.256895][12710:12712] CHIP:DL: Avahi resolve failed
[1687496965.625157][12710:12711] CHIP:DL: Bluez notify CHIPoBluez connection disconnected
[1687496981.248469][12710:12712] CHIP:DIS: Checking node lookup status after 45008 ms
[1687496981.248516][12710:12712] CHIP:DIS: OperationalSessionSetup[1:0000000000000001]: operational discovery failed: ../../src/lib/address_resolve/AddressResolve_DefaultImpl.cpp:114: CHIP Error 0x00000032: Timeout
[1687496981.248528][12710:12712] CHIP:CTL: Device connection failed. Error ../../src/lib/address_resolve/AddressResolve_DefaultImpl.cpp:114: CHIP Error 0x00000032: Timeout
[1687496981.248546][12710:12712] CHIP:CTL: Error on commissioning step 'FindOperational': '../../src/lib/address_resolve/AddressResolve_DefaultImpl.cpp:114: CHIP Error 0x00000032: Timeout'
[1687496981.248554][12710:12712] CHIP:CTL: Failed to perform commissioning step 18
[1687496981.248561][12710:12712] CHIP:CTL: Going from commissioning step 'FindOperational' with lastErr = '../../src/lib/address_resolve/AddressResolve_DefaultImpl.cpp:114: CHIP Error 0x00000032: Timeout' -> 'Cleanup'
[1687496981.248577][12710:12712] CHIP:CTL: Performing next commissioning step 'Cleanup' with completion status = '../../src/lib/address_resolve/AddressResolve_DefaultImpl.cpp:114: CHIP Error 0x00000032: Timeout'
[1687496981.248587][12710:12712] CHIP:CTL: Successfully finished commissioning step 'Cleanup'
[1687496981.248604][12710:12712] CHIP:TOO: Device commissioning Failure: ../../src/lib/address_resolve/AddressResolve_DefaultImpl.cpp:114: CHIP Error 0x00000032: Timeout
[1687496981.248867][12710:12710] CHIP:DIS: Closing all BLE connections
[1687496981.248897][12710:12710] CHIP:SC: SecureSession[0x7fbd0000e800]: Moving from state 'kActive' --> 'kPendingEviction'
[1687496981.248935][12710:12710] CHIP:FP: Forgetting fabric 0x1
[1687496981.248952][12710:12710] CHIP:TS: Pending Last Known Good Time: 2023-03-02T09:28:16
[1687496981.249049][12710:12710] CHIP:TS: Previous Last Known Good Time: 2023-03-02T09:28:16
[1687496981.249057][12710:12710] CHIP:TS: Reverted Last Known Good Time to previous value
[1687496981.249866][12710:12710] CHIP:BLE: BleConnectionDelegate::CancelConnection is not implemented.
[1687496981.249915][12710:12710] CHIP:FP: Shutting down FabricTable
[1687496981.249936][12710:12710] CHIP:TS: Pending Last Known Good Time: 2023-03-02T09:28:16
[1687496981.250021][12710:12710] CHIP:TS: Previous Last Known Good Time: 2023-03-02T09:28:16
[1687496981.250032][12710:12710] CHIP:TS: Reverted Last Known Good Time to previous value
[1687496981.250245][12710:12710] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-TrOXO5)
[1687496981.250709][12710:12710] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
[1687496981.250755][12710:12710] CHIP:DL: NVS set: chip-counters/total-operational-hours = 0 (0x0)
[1687496981.250768][12710:12710] CHIP:DL: Inet Layer shutdown
[1687496981.250778][12710:12710] CHIP:DL: BLE shutdown
[1687496981.251692][12710:12710] CHIP:DL: System Layer shutdown
[1687496981.251973][12710:12710] CHIP:TOO: Run command failure: ../../src/lib/address_resolve/AddressResolve_DefaultImpl.cpp:114: CHIP Error 0x00000032: Timeout
and I am using the nrr52840 for the light bulb and using the ncs v2.3.0 and using same version for the chip tool for the linux pc
Now what to do now?
  • and i am using Rashberry pi and  nrf52840 Dongle as OTBR
    I think that the problem here is the line "domain name or RRset is duplicated" in the log. Please make sure you erase the full flash of the device and try again. This ticket contains details about a similar issue, please check if the suggestions helps with your issue.
    If you are not able to resolve it, please post exact steps used to reproduce this behavior.
    Jørgen
    Let me List the steps i have done.
    1). I have flashed the Light_Bulb sample to the nrf52840 DK and started the Screen Logs.
    2). After that i have the OTBR .i.e., RashberryPi with nrf52840 Dongle. So I have the dataset required for pairing
    rpi@raspberrypi:~ $ sudo ot-ctl dataset active -x
    Done
    3). After that I have started the pairing with below command
    $ ./chip-tool-debug pairing ble-thread 1 hex:0e080000000000010000000300001135060004001fffe002086fa9d405754a44f70708fd36f93b1aa0ce030510d645ad53670e4076efbce31100978b2b030f4f70656e5468726561642d393133630102913c041090de57e044a398375de7f887ec9670af0c0402a0f7f8 20202021 3840
    4). After that the Logs i have already provided.
    AS I have tried earlier It was working but now it is not so what to do know.
    And the reference you have given is not giving me the clear solution and things are not cleared. and I have full flashed the device.
    Did you manage to resolve this issue, or do you still need assistance from us?
    Jørgen
