Cannot disable Zephyr file system with nRF Connect SDK 2.4.0
On our platform we don't use the filesystem, so we would like to exclude it from the build. For this reason, we have been disabling it in Kconfig (CONFIG_FILE_SYSTEM=n in prj.conf).
This has worked well with SDK version 2.3.0. However, with 2.4.0 this now results in the following error:
C:\ncs\v2.4.0\modules\fs\fatfs\ff.c:499:2: error: #error LFN must be enabled when enable exFAT
499 | #error LFN must be enabled when enable exFAT
This happens even if I explicitly add CONFIG_FS_FATFS_EXFAT=n to the configuration file (although as I understand it, this should follow from CONFIG_FILE_SYSTEM=n).
The same happens if I remove all these settings from prj.conf and disable the file system via the Kconfig GUI (Subsystems and OS Services -> File Systems -> File system support).
Is this a known error? Or is there some additional setting that I know have to use?
