Replacing RS485 link with NRF24L01+
As Pevious ticket: Using NRF24L01+ with pure assembler programing becomes very long,  I open a new one as Torbjørn suggested
This is a description about what I have doing in my proyect and at the end there are some questions.
My application has a Central unit connected to several Handheld controllers  with RS485 cable.
Bit rate is 62.500 , 9bits
The central unit is sending in secuence a Callbyte for each Handheld address (from1 to 31) and wait about 100 us for a reply, before it will send a Callbyte to the following address
In this cable system a Handheld only changes to Tx mode after a Callbyte with his address is received.
The Central unit has connected two rails for Model Electric trains. (Ferromedelism)
I will add an interfase  with a uP and a NRF24L04p that will handle the RF link and connected to the Central by 485 cable
No modifications at the Central unit hadware or software willbemade.
The the handheld will be re-designated by adding one NRF24L01+, removing the 485 part and modifying the program as needed.
Using the usual star configuration , the intefase will use PRX mode and may be up to 6 handheldwill using the NRF part in PTX mode.
All the 485 packets are 9 bits but the MSB is only for the information about if the byte is an Address (= 1) or a DATA  (= 0)
Only the Central may send Address and Data bytes.   Handheld units only send DATA bytes
In my aproach the interfase unit decodes only the Callbytes and the NRF will need to handle only 8 bits.
There are 3 types of Callbytes:
1) Callbytes with no more bytes in the packet, that allows the matching address Handheld to
send a packet to the central
2) Callbytes with 1 or more DATA with information requested before by one specific handheld.
The regarding address will be in the Callbyte
3) Broadcast Callbytes: The packet will have information that must be sent to all the Handhelds units.
The program for the interfase unit has 6 RX buffers and 6 TX buffers for the USART and 485 , one pair for each PIPE
Data send from a Handheld by NRF is received by interfase and stored in the TX buffer , for case 1)
Data received by USART (from RS485) is stored in Rx buffer and loaded in NRF TXFIFO  for sending it as an ACK PAYLOAD
I will use some time slots system (not defined yet) for each PTX for avoid collitions and to get back  information when available
------------------------- Some quetions here ---------------------
At the moment the matter  1) is working OK
Each information sent from Handheld is received at interfase side and sent by RS485 when type 1) Callbyte arrives.
For cases 2) and 3)  ,  information from Handheld is received but ACK PAYLOAD is sent some times yes  other times no
uP reset do not helps .  If the NRF supply is disconected and reconected, ACK PAYLOAD begins to work
It may be  working in all the PTX packets or alternately one yes one not.
I have a low cost , 8 channels Logic Analizer and I will investigate this problem by reading STATUS and FIFO_STATUS
I guess the problem is at PRX side, not sending ACK, but I am no sure.
Please send any suggestion about where it may be the problem.
Also how to diferenciate  which side is not working well.
Best Regards, Osvaldo Hojvat
  • Hi Osvaldo
    Do you upload multiple ACK payloads in the nRF24L01+ FIFO's at once, or only one at a time?
    What if you flush the TX FIFO on the PRX side, is this not enough to get ACK payloads to work again?
    Since the buffer is a simple FIFO it doesn't handle the situation very well where you have multiple packets intended for different pipes. The following snippet from the datasheet describes this issue:
    If the TX FIFO (PRX) contains more than one payload to a PTX, payloads are handled using the first in – first out principle. The TX FIFO (PRX) is blocked if all pending payloads are addressed to a PTX where the link is lost. In this case, the MCU can flush the TX FIFO (PRX) by using the FLUSH_TX command.
    Best regards
    Torbjørn
  • Thank you for your reply
    I upload information for one pipe in case 2) or 3 pipes in case 3)
    I had readed this data sheet information and used flush Tx FIFO and Rx FIFO at PTX side but not yet at PRX side
    I will add and test again.
    I guess that flush will erase the 3 levels of FIFO
    I need to use the POWER ON delay of uP in the PRX because some unwanted signals arises in SPI at power-up
    Recently I change Logic Analyzer cables with 4 to PRX SPI and 4 to PTX SPI and have a capture after / later re-seting PRX
    I will check this information and I will make a summary
    As I add some FIFO sate reading, it may be usefull information about the problem.
    Regards, Osvaldo
  • I found the cause by looking at bit 0 of STATUS in the first SPI messages on the PRX
    I have a wired handheld connected to the control panel, and its address is 12
     It is in the range of 10 to 15 that can be used for RF, for some tests what did I do.
     At the start, this unit requests and receives information from the control panel and because it is in range, the interface receives it by cable and upload it to send it by NRF.
    The PTX that is working has address 10 (PIPE = 0) and it do not attend packets to 12 ( PIPE 2) They accumulate in the buffer and stop everything.
    Disconected handheld 12 (or change it address to 9) and RF link works fine from power-up
    Test again with address 10 in the handheld and the packets are sended with ack when PTX sends a new packet and also there are pending packets received at PTX
    At the moment the PTX-PRX is working well as follows:
    With a pushbuttom at PTX  there is one message sent to the Central requesting some information.
    The reply is ulpoad with the ACK but it is not sent until the next packet sent from PTX.
    This is OK as expected.  In the proyect the PTX must send periodically packets
     Please tell me when to use waiting times and where they are necessary.
     Regards Osvaldo
  • Hi Osvaldo
    Yes. A flush will clear all the packets currently in the FIFO. In order to avoid packet loss you might need to buffer the packets in the host MCU as well, so that you can upload them to the nRF device after the flush.
    It sounds like you were able to figure out the issues then? In the end it was a problem of having the wrong address?
    If you check chapter 6.1.7 on page 24 in the nRF24L01+ Product Specification it explains the most important timing parameters, such as the time it takes to power up the chip from power down, and the time it takes to start the radio.
    The protocol timing requirements is covered by chapter 7.7 on page 42.
    Best regards
    Torbjørn
  • I have  measured some delay times and found that sending a packet from PTX and get the reply available again at PRX takes about 2,5ms in total
    This includes NRF tx -rx times to interfase and USART times and reply from central unit by 485 cable
    In my future time division schema , I guess 20ms for each PTX, so it will be 120ms from each PTX trasmition to the following for the ack payload of previus packet.
    In the 20ms slot PTX can send a packet and after after 2,5 ms the reply will upload as ACK payload at PRX
    My last idea is at by example  5ms from the  first packet sent, the PTX will send a second special packet one byte length, only to geting the ACK PAYLOAD information.
    This byte will have a special code ("F0" by example) that tells PRX it is not to be send by the USART (as it is done for all the usual packets)
    In this way the reply will be at PRX in the same 20ms time slot
    This one byte packet will be send all the lime to keep syncronized the PTx
    Aditionally the most important advantage is to avoid TXFIFO full in PRX
    The case 3) broadcast packet, it will be loaded in the 6 microprocesor buffers (in PRX =  interfase) an loaded to the PRX  TxFIFO  one in each slot time , a little before the expected one byte repetitive packet.
    So I will begin using all 6 address PIPES and time slot matter, before include the short test program in the complete handheld one.
    Until now I never change the default address in NRF
    The 6 USART address matter was make an well tested .  Handheld with 485 cable with several different address  was used  for this purpose,
    The problem with wrong address arises because I used a normal handheld with cable to generate and receive USART signals in the debug.
    I was not the problem because an error remaining in the interfase (with the PRX) program but it was an error or confusion in the tests..
    With the repetitive special packet it may be more simple to identificate PIPES not in use or out of range PTX
