Replacing RS485 link with NRF24L01+
As Pevious ticket: Using NRF24L01+ with pure assembler programing becomes very long,  I open a new one as Torbjørn suggested
This is a description about what I have doing in my proyect and at the end there are some questions.
My application has a Central unit connected to several Handheld controllers  with RS485 cable.
Bit rate is 62.500 , 9bits
The central unit is sending in secuence a Callbyte for each Handheld address (from1 to 31) and wait about 100 us for a reply, before it will send a Callbyte to the following address
In this cable system a Handheld only changes to Tx mode after a Callbyte with his address is received.
The Central unit has connected two rails for Model Electric trains. (Ferromedelism)
I will add an interfase  with a uP and a NRF24L04p that will handle the RF link and connected to the Central by 485 cable
No modifications at the Central unit hadware or software willbemade.
The the handheld will be re-designated by adding one NRF24L01+, removing the 485 part and modifying the program as needed.
Using the usual star configuration , the intefase will use PRX mode and may be up to 6 handheldwill using the NRF part in PTX mode.
All the 485 packets are 9 bits but the MSB is only for the information about if the byte is an Address (= 1) or a DATA  (= 0)
Only the Central may send Address and Data bytes.   Handheld units only send DATA bytes
In my aproach the interfase unit decodes only the Callbytes and the NRF will need to handle only 8 bits.
There are 3 types of Callbytes:
1) Callbytes with no more bytes in the packet, that allows the matching address Handheld to
send a packet to the central
2) Callbytes with 1 or more DATA with information requested before by one specific handheld.
The regarding address will be in the Callbyte
3) Broadcast Callbytes: The packet will have information that must be sent to all the Handhelds units.
The program for the interfase unit has 6 RX buffers and 6 TX buffers for the USART and 485 , one pair for each PIPE
Data send from a Handheld by NRF is received by interfase and stored in the TX buffer , for case 1)
Data received by USART (from RS485) is stored in Rx buffer and loaded in NRF TXFIFO  for sending it as an ACK PAYLOAD
I will use some time slots system (not defined yet) for each PTX for avoid collitions and to get back  information when available
------------------------- Some quetions here ---------------------
At the moment the matter  1) is working OK
Each information sent from Handheld is received at interfase side and sent by RS485 when type 1) Callbyte arrives.
For cases 2) and 3)  ,  information from Handheld is received but ACK PAYLOAD is sent some times yes  other times no
uP reset do not helps .  If the NRF supply is disconected and reconected, ACK PAYLOAD begins to work
It may be  working in all the PTX packets or alternately one yes one not.
I have a low cost , 8 channels Logic Analizer and I will investigate this problem by reading STATUS and FIFO_STATUS
I guess the problem is at PRX side, not sending ACK, but I am no sure.
Please send any suggestion about where it may be the problem.
Also how to diferenciate  which side is not working well.
Best Regards, Osvaldo Hojvat
  • Hi Osvaldo
    Did you figure this out, since you marked your reply as verified answer, or do you still have some questions you need help with?
    Best regards
    Torbjørn
  • Thank you for your reply
    As the ticket seems to be closed , I press Verify answer but I did not know for what function it is, sorry.
    I read again carefully page 75 of data sheet and I gess I undestand well the matter.
    Please confirm:
    In PRX mode, Tx address is not used . PIPE0 works  similar to the others PIPES
    In PRX mode,  only Tx address and PIPE0 address are used and must be the same
    PIPE number is not defined at Tx - The number of PIPE are detected at PRX device because  the matching with this PIPE rxaddres matces wiith the received packet.
    This PIPE number must be detected in STATUS_REG and used for ACK payload.
    I can use any of the 6 PIPEs ok
    The minimal instructions are:
    PRX    write 3F to Reg02    -  all Rx PIPES    ON
    PTX6      tx and PIPE0  default addr..   E7E7E7E7E7
    In each PTX 1 to 5    set TXaddr and PIPE0  RX addr with same default values  from PIPES 1 to 5 of the PRX.    C2C2C2C2C2 - C2C2C2C2C3 -C2C2C2C2C4-C2C2C2C2C5-C2C2C2C2C6
    It is working.  I expect have no errors when writing this  information.
    In production parts I will not use default values and channels.
    Some remaining problems that are in my program will be solved using 8 ch. logic analyzer and MPLAB 8.92  with PIC16F1936 and PIC16F1826.
  • Hi Osvaldo
    Correct. You don't need to worry about the TX address in PRX mode, setting the RX addresses is sufficient.
    Assuming you mean in PTX mode, then yes. Only TX and pipe 0 addresses are used, and they both need to be set to the same address as the device you are transmitting to.
    Correct. You always use pipe 0 in PTX mode, but in PRX mode you can receive on any of the enabled pipes.
    The RX_P_NO field of the STATUS register will contain the pipe number of the oldest payload in the FIFO. If you only have one packet in the FIFO it will be the pipe number of the previously received packet.
    Good Slight smile
    It is recommended to use a randomized address, and ensure that you have a certain number of bit shifts in the address (avoid several bytes of 0x00 or 0xFF).
    Best regards
    Torbjørn
  • Hi  Torbjørn
    Thank you for yor reply.
    I will do some testing about distances for RF link
    Also I will add retrasmiting n times.
    If I may need some aditional help I will open a new ticket.
  • Hi Osvaldo
    Great, good luck finalizing your project Slight smile
    Best regards
    Torbjørn
