I am using an Adafruit Feather with NRF52840 IC to interface with a BNO085 IMU over SPI. I am coding using the NRF Connect Zephyr environment in VS Code. I have gotten communication between the two devices almost working, but a high MOSI pin during read is messing up my transfer.
The BNO works by first having an initialization stage, and then a timed output stage. Anytime I perform an spi_read command, I have found that my MOSI pin is going high. This is fine during the init stage, but screws up the output stage. I have found that unplugging the MOSI after init leads to a working output reading, otherwise the program freezes after a single read. Is there a way I can configure the MOSI not to go high?
Logic Analyzer showing the high MOSI during a read:
SPI main.c configuration:
#define SPI1_NODE DT_NODELABEL(spi1) static const struct device *spi1_dev = DEVICE_DT_GET(SPI1_NODE); static struct spi_config spi_cfg ={ .frequency = 1000000, //125000U .operation = SPI_WORD_SET(8) | SPI_TRANSFER_MSB | SPI_OP_MODE_MASTER | SPI_MODE_CPOL | SPI_MODE_CPHA, //SPI_MODE_CPHA .slave = 0, };
SPI read command:
gpio_pin_set(gpio1_dev, CS_PIN, 0); struct spi_buf rx_buf2 = { .buf = pBuffer, .len = packet_size, }; const struct spi_buf_set rx2 = { .buffers = &rx_buf2, .count = 1 }; if (spi_read(spi1_dev, &spi_cfg, &rx2)) { printk("SPI Read Failed\r\n"); return 0; } gpio_pin_set(gpio1_dev, CS_PIN, 1);
Full prj.conf:
CONFIG_USB_DEVICE_STACK=y CONFIG_USB_DEVICE_PRODUCT="Zephyr USB console sample" CONFIG_USB_DEVICE_PID=0x0004 CONFIG_USB_DEVICE_INITIALIZE_AT_BOOT=n CONFIG_SERIAL=y CONFIG_CONSOLE=y CONFIG_UART_CONSOLE=y CONFIG_UART_LINE_CTRL=y CONFIG_STDOUT_CONSOLE=y CONFIG_UART_INTERRUPT_DRIVEN=y CONFIG_CONSOLE_SUBSYS=y CONFIG_CONSOLE_GETCHAR=y CONFIG_SPI=y CONFIG_GPIO=y CONFIG_SPI_NRFX=y CONFIG_NRFX_SPIM3=y CONFIG_CBPRINTF_FP_SUPPORT=y
Board File:
&pinctrl { spi1_default: spi1_default { group1 { psels = <NRF_PSEL(SPIM_SCK, 0, 14)>, <NRF_PSEL(SPIM_MISO, 0, 15)>, <NRF_PSEL(SPIM_MOSI, 0, 13)>; }; }; spi1_sleep: spi1_sleep { group1 { psels = <NRF_PSEL(SPIM_SCK, 0, 14)>, <NRF_PSEL(SPIM_MISO, 0, 15)>, <NRF_PSEL(SPIM_MOSI, 0, 13)>; low-power-enable; }; }; }; &spi1 { compatible = "nordic,nrf-spim"; status = "okay"; //cs-gpios = <&gpio0 8 GPIO_ACTIVE_HIGH>; pinctrl-0 = <&spi1_default>; pinctrl-1 = <&spi1_sleep>; pinctrl-names = "default", "sleep"; };
Thank you for the help
