Two calls to sd_ble_uuid_vs_add with same parameter fails
I'm using nrf51-ble-driver_win_0.4.1 to connect BLE devices on PC. When device has a 128bits UUID, you have to call sd_ble_uuid_vs_add( &uuid128, &p_type ) to register the 128bits UUID and get a VENDOR type (p_type).
But, if your device has two 128bits services, for instance: "0xAABB5500-CCCC-DDDD-EEEE-FFFFFFFFFFFF" and "0xAABB5501-CCCC-DDDD-EEEE-FFFFFFFFFFFF"
  • When discovering first service (0xAABB5500-CCCC-DDDD-EEEE-FFFFFFFFFFFF) first call to sd_ble_uuid_vs_add( &uuid128, &p_type ) (with 0xAABB0000-CCCC-DDDD-EEEE-FFFFFFFFFFFF as parameter, where 0 replaces short service UUID) returns NRF_SUCCESS and p_type is set.
  • Now when discovering secondservice (0xAABB5501-CCCC-DDDD-EEEE-FFFFFFFFFFFF) second call to sd_ble_uuid_vs_add( &uuid128, &p_type ) (with again 0xAABB0000-CCCC-DDDD-EEEE-FFFFFFFFFFFF as parameter, where 0 replaces short service UUID) does not return NRF_SUCCESS (it returns NRF_ERROR_FORBIDDEN) and does not set p_type.
Then, API client has to store a local list of UUIDs for which sd_ble_uuid_vs_add was already called and map them to vendor types to workaround the bug...
    This is all according to the documentation. The return values for sd_ble_uuid_vs_add are described like this:
    NRF_SUCCESS	Successfully added the Vendor Specific UUID.
    NRF_ERROR_INVALID_ADDR	If p_vs_uuid or p_uuid_type is NULL or invalid.
    NRF_ERROR_NO_MEM	If there are no more free slots for VS UUIDs.
    NRF_ERROR_FORBIDDEN	If p_vs_uuid has already been added to the VS UUID table.
    In a later version of the SoftDevices, this has been changed to simply return NRF_SUCCESS and the already-assigned type.
    Please also do a search for "sd_ble_uuid_vs_add" here and you will find many similar questions with helpful answers.
  • Thanks, if that's already adressed in next versions, it's great.
  • I, personally, cannot speak for the nrf51-ble-driver, but the latest SoftDevices already have this change. Once a driver based on these is out, it should be included. For now you should avoid adding things multiple times, or expect NRF_ERROR_FORBIDDEN to occur every now and then.
