thang47 - Interesting to know. You got the operating channel of that sensor?
Well it might be configured with a different link key than the default, which can make it unusable on other coordinators than the Aqara Hub. Considering this response on the Amazon link I am concerned that might be the case.
But either way it can also be a bit of a hazzle to modify the coordinator to work with it. Here is a previous old case in which someone got an Aqara sensor to work with nRF5 SDK though, that might be interesting to look at. I assume you are using NCS though?
I guess you could ask Aguara themselves to be sure, or just try and see if it works. If the link key is okay and it uses Zigbee3.0, I think it should be possible even though it can be a lot of work.
Elfving
Hi Elfving,
I tried adding Aqara sensor but when I view the log I get:
I: Device update received (short: 0xd1fb, long: 00158d00079ae1bd, status: 0)
I: New device commissioned or rejoined (short: 0xd1fb)
I: Joining period extended.
I: Device authorization event received (short: 0xd1fb, long: 00158d00079ae1bd, authorization type: 1, authorization status: 1)
I: Child left the network (long: 00158d00079ae1bd, rejoin flag: 0)
I don't know if it's the right channel or not?
Hi Askabu,
Actually I don't know its active channel, but when I run the sample example, I get the log:
Hi Elfving,
I paired that sensor, I got temperature and humidity data, but I didn't get the battery message. I'm sure that sensor fires the pin message. Do you know how to configure receiving pin messages?
