DHT11 Sensor on Matter
Hey, Varshil here,
I got stuck during implementation of DHT11 Sensor on Matter SDK.
I follow this Link of Adding clusters to Matter application — nRF Connect SDK 2.4.0 documentation (nordicsemi.com) and I successfully completed all the steps which are available in that link.
Now when I pass the command to the Chip-Tool and below I pasted the commands which I write in Chip-Tool.
sudo ./chip-tool-debug onoff off 12 1
sudo ./chip-tool-debug identify identify 10 12 1
And After this commands I got an Error that:
I: 34957 [SC]Received Sigma3 msg
E: 34966 [SC]The device does not support GetClock_RealTimeMS() API: 3.  Falling back to Last Known Good UTC Time
E: 35163 [DL]Long dispatch time: 187 ms, for event type 2
I: 35263 [EM]<<< [E:4417r S:0 M:58029193 (Ack:51879023)] (U) Msg TX to 0:0000000000000000 [0000] --- Type 0000:40 (SecureChannel:StatusReport)
I: 35276 [IN](U) Sending msg 58029193 to IP address 'UDP:[fd5a:d4ce:1ab2:5fa8:e99b:db8:b197:cff9]:56825'
I: 35287 [SC]SecureSession[0x200034f8]: Moving from state 'kEstablishing' --> 'kActive'
D: 35295 [IN]SecureSession[0x200034f8]: Activated - Type:2 LSID:25501
Your kindly help will be genuinely appreciated.
Thank You.
