SPIM3 peripheral not reliable
Environment: NCS v2.0.2
Chip: NRF52840_xxAA_REV2
Board: Custom pre-production board
I know that there are several existing tickets that revolve around SPIM3, but I have tried all suggestions int the 20-some-odd tickets that I've researched so far with no change in results.
What I'm trying to accomplish
We have been using the SPIM2 peripheral with no problems whatsoever. However, as we move towards production we would like to squeeze more speed out of the bus if possible. In the case of our chip, that would mean moving to the SPIM3 peripheral that offers up to 32Mhz operation. We have two devices on the SPI lines: a WiFi module (25MHz max) and an SD card. All physical SPI pins are high-speed capable. Due to the WiFi chip's speed limitation we only really need to go to 16 Mhz. So far, SPIM3 is not being reliable at any speed.
Symptoms
The bus seems to work fine for a small amount of time. I can write maybe 500kbit to the SD card or can start to configure the wifi module, but after a small amount of traffic the bus seems to have a hiccup and stops working, In the case of the SD card I get a file write error, and with the wifi module it just stops sending the correct next command to continue configuration.
Troubleshooting
I have scoped the lines at 8, 16, and 32Mhz and they have essentially identical form. It does not seem to be raw signal related. I know the devices can work at 8Mhz because they work fine when using SPIM2. I tried using SPIM3 at 8Mhz and even down to 4Mhz and get the exact same behavior. So again, that leads me to believe that the issue is not speed or signal related, but that is just an assumption on my part.
I also printed all of the spi traffic from the wifi module to see where things start to differ. It always differs at the exact same spot in configuration. It makes an 2 byte transmit and expects a 2 byte response of 0x00 0x58. I get the correct response when using SPIM2, but on SPIM3 it always responds with 0x00 0xb0. It may be a coincidence, but 0x58 left-bit-shifted by 1 is equal to 0xb0 so it may be that the RX value is being shifted to the left by one. (0x58 = 01011000; 0xb0 = 1011000).
I've read the various errata related to SPIM3 such as anomaly 198 and am working through ensuring that all relevant anomalies are being addressed.
Thank you for any advice or help,
Louis
  • You should ideally measure both CLK, MISO and MOSI here.
    It's only the MOSI that can show/confirm the correct mode is used every time by the SPI master, the MISO however is fully controlled by the slave device, and if MISO randomly change mode or polarity, then it's more likely a pin floating here somewhere that potentially cause the slave to change mode of operation than what you configure the SPI mode of the master.
    Kenneth
  • I agree with you, but it still leads to confusion since 2 independent spi devices have that same problem at the same time. In addition, the wifi chip is only capable of operating in one spi mode and there is no way to change it. This leads me to believe I could have measured the signals wrong or something.
    Also, I have a dev kit for the wifi module and hooked it up to an nrf52840DK where the only code / peripheral I was using was that single device and it works 9/10 times (1/10 times it fails in the same way as the production application on SPIM3 only).
    This leads me to believe that If I implement the suggestion by about explicitly allocating memory for the SPIM3 buffers I might have better results. Our production application is quite busy using a majority of the peripherals available. Putting it on the dev kit by itself seemed to help when only that single peripheral was being used.
    In addition, these SPI devices are the most important devices for our application, so learning that SPIM3 is the lowest priority peripheral might mean that the speed benefits are not worth it when many peripherals are being used simultaneously.
    Thanks for everyone's help. I will close this ticket for now since I think I have all the suggestions possible.
