[MATTER] CHIP:DL: FAIL: NULL apEndpoint->mpAdapter in bluezObjectsSetup
Hi
Referred to below link, installed OTBR and CHOIP-TOOL at RaspBerry Pi 4.
https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/protocols/matter/getting_started/testing/thread_one_otbr.html
On nrf52840 dongle acts as RCP and plugged in Pi USB port.
During pairing ble-thread, Pi will cancel the pairing and then close bluetooth as the error "CHIP:DL: FAIL: NULL apEndpoint->mpAdapter in bluezObjectsSetup".
I tried manual and Docker installation both. However, both failed at same error. Did you know the reason and how to fix the problem?
1. Log at Pi side during pairing
[1687931169.237647][1315:1315] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_kvs
[1687931169.248875][1315:1315] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_facto                                                     ry.ini
[1687931169.253489][1315:1315] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_confi                                                     g.ini
[1687931169.254395][1315:1315] CHIP:DL: ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_count                                                     ers.ini
[1687931169.255890][1315:1315] CHIP:DL: writing settings to file (/tmp/chip_counters.ini-3YtrEi)
[1687931169.256691][1315:1315] CHIP:DL: renamed tmp file to file (/tmp/chip_counters.ini)
[1687931169.256771][1315:1315] CHIP:DL: NVS set: chip-counters/reboot-count = 111 (0x6F)
[1687931169.257735][1315:1315] CHIP:DL: Got Ethernet interface: eth0
[1687931169.258330][1315:1315] CHIP:DL: Found the primary Ethernet interface:eth0
[1687931169.258988][1315:1315] CHIP:DL: Got WiFi interface: wlan0
[1687931169.261450][1315:1315] CHIP:DL: Found the primary WiFi interface:wlan0
[1687931169.261535][1315:1315] CHIP:IN: UDP::Init bind&listen port=0
[1687931169.261740][1315:1315] CHIP:IN: UDP::Init bound to port=59592
[1687931169.261777][1315:1315] CHIP:IN: UDP::Init bind&listen port=0
[1687931169.261913][1315:1315] CHIP:IN: UDP::Init bound to port=40377
[1687931169.261945][1315:1315] CHIP:IN: BLEBase::Init - setting/overriding transport
[1687931169.261975][1315:1315] CHIP:IN: TransportMgr initialized
[1687931169.262057][1315:1315] CHIP:FP: Initializing FabricTable from persistent storage
[1687931169.274604][1315:1315] CHIP:TS: Last Known Good Time: 2023-06-01T08:25:29
[1687931169.275397][1315:1315] CHIP:FP: Fabric index 0x1 was retrieved from storage. Compressed Fabric                                                     Id 0xBC3EE8D1A58AE9C3, FabricId 0x0000000000000001, NodeId 0x000000000001B669, VendorId 0xFFF1
[1687931169.292241][1315:1315] CHIP:ZCL: Using ZAP configuration...
[1687931169.301564][1315:1315] CHIP:DL: Avahi client registered
[1687931169.307652][1315:1315] CHIP:CTL: System State Initialized...
[1687931169.310056][1315:1315] CHIP:CTL: Stopping commissioning discovery over DNS-SD
[1687931169.310146][1315:1315] CHIP:CTL: Setting attestation nonce to random value
[1687931169.310184][1315:1315] CHIP:CTL: Setting CSR nonce to random value
[1687931169.310510][1315:1317] CHIP:DL: CHIP task running
[1687931169.310720][1315:1317] CHIP:DL: HandlePlatformSpecificBLEEvent 32784
[1687931169.312046][1315:1317] CHIP:CTL: Stopping commissioning discovery over DNS-SD
[1687931169.312113][1315:1317] CHIP:CTL: Setting attestation nonce to random value
[1687931169.312153][1315:1317] CHIP:CTL: Setting CSR nonce to random value
[1687931169.329436][1315:1317] CHIP:CTL: Generating NOC
[1687931169.345395][1315:1317] CHIP:FP: Validating NOC chain
[1687931169.392253][1315:1317] CHIP:FP: NOC chain validation successful
[1687931169.392296][1315:1317] CHIP:FP: Updated fabric at index: 0x1, Node ID: 0x000000000001B669
[1687931169.392321][1315:1317] CHIP:TS: Last Known Good Time: 2023-06-01T08:25:29
[1687931169.392339][1315:1317] CHIP:TS: New proposed Last Known Good Time: 2021-01-01T00:00:00
[1687931169.392356][1315:1317] CHIP:TS: Retaining current Last Known Good Time
[1687931170.108098][1315:1317] CHIP:FP: Metadata for Fabric 0x1 persisted to storage.
[1687931170.138714][1315:1317] CHIP:TS: Committing Last Known Good Time to storage: 2023-06-01T08:25:2                                                     9
[1687931170.169755][1315:1317] CHIP:CTL: Joined the fabric at index 1. Fabric ID is 0x0000000000000001                                                      (Compressed Fabric ID: BC3EE8D1A58AE9C3)
[1687931170.355982][1315:1317] CHIP:CTL: Setting thread operational dataset from parameters
[1687931170.356067][1315:1317] CHIP:CTL: Setting attestation nonce to random value
[1687931170.356148][1315:1317] CHIP:CTL: Setting CSR nonce to random value
[1687931170.356216][1315:1317] CHIP:CTL: Commission called for node ID 0x00000000000004D2
[1687931170.356279][1315:1317] CHIP:DL: Long dispatch time: 1045 ms, for event type 2
[1687931170.365204][1315:1316] CHIP:DL: TRACE: Bus acquired for name C-0523
[1687931170.588803][1315:1316] CHIP:DL: FAIL: NULL apEndpoint->mpAdapter in bluezObjectsSetup
[1687931170.588933][1315:1317] CHIP:DL: PlatformBlueZInit init success
[1687931170.588979][1315:1317] CHIP:DIS: Closing all BLE connections
[1687931170.589050][1315:1317] CHIP:BLE: No adapter available for new connection establishment
[1687931170.589079][1315:1317] CHIP:DL: Long dispatch time: 233 ms, for event type 2
[1687931186.671893][1315:1317] CHIP:DL: Avahi re-register required
[1687931186.681534][1315:1317] CHIP:DL: HandlePlatformSpecificBLEEvent 32785
[1687931186.681628][1315:1317] CHIP:DL: Avahi re-register required
[1687931186.683633][1315:1317] CHIP:DL: HandlePlatformSpecificBLEEvent 32785
[1687931188.193767][1315:1317] CHIP:DL: Avahi client registered
[1687931188.197259][1315:1317] CHIP:DL: HandlePlatformSpecificBLEEvent 32784
2. Log at DK board side during pairing. Actually, it kept advertizing onboarding information.
uart:~$ *** Booting Zephyr OS build v3.2.99-ncs2 ***
I: Init CHIP stack
I: 223 [DL]BLE address: CB:35:C4:EE:32:7E
I: 233 [DL]OpenThread started: OK
I: 236 [DL]Setting OpenThread device type to ROUTER
I: 241 [SVR]Server initializing...
I: 244 [TS]Last Known Good Time: 2023-05-10T16:19:04
I: 250 [DMG]AccessControl: initializing
I: 253 [DMG]Examples::AccessControlDelegate::Init
I: 258 [DMG]AccessControl: setting
I: 261 [DMG]DefaultAclStorage: initializing
I: 265 [DMG]DefaultAclStorage: 0 entries loaded
D: 269 [IN]UDP::Init bind&listen port=5540
E: 273 [IN]SO_REUSEPORT failed: 109
D: 276 [IN]UDP::Init bound to port=5540
D: 280 [IN]BLEBase::Init - setting/overriding transport
D: 285 [IN]TransportMgr initialized
I: 293 [ZCL]Using ZAP configuration...
I: 299 [DMG]AccessControlCluster: initializing
I: 303 [ZCL]Initiating Admin Commissioning cluster.
I: 308 [ZCL]On/Off set value: 1 0
I: 311 [ZCL]On/off already set to new value
I: 315 [ZCL]Cluster LevelControl: attribute CurrentLevel set to 254
D: 322 [IN]SecureSession[0x200034e8]: Allocated Type:1 LSID:36535
I: 328 [DIS]Updating services using commissioning mode 1
I: 333 [DIS]Advertise commission parameter vendorID=65521 productID=32773 discriminator=3840/15 cm=1
E: 342 [DIS]Failed to advertise commissionable node: 3
E: 347 [DIS]Failed to finalize service update: 1c
I: 352 [DIS]Updating services using commissioning mode 1
I: 357 [DIS]Advertise commission parameter vendorID=65521 productID=32773 discriminator=3840/15 cm=1
E: 366 [DIS]Failed to advertise commissionable node: 3
E: 371 [DIS]Failed to finalize service update: 1c
I: 376 [DIS]Delaying proxy of operational discovery: missing delegate
I: 382 [IN]CASE Server enabling CASE session setups
D: 387 [IN]SecureSession[0x200035a0]: Allocated Type:2 LSID:36536
I: 393 [SVR]Joining Multicast groups
I: 396 [SVR]Server Listening...
I: 399 [DL]Device Configuration:
I: 402 [DL]  Serial Number: 11223344556677889900
I: 406 [DL]  Vendor Id: 65521 (0xFFF1)
I: 410 [DL]  Product Id: 32773 (0x8005)
I: 413 [DL]  Hardware Version: 1
I: 416 [DL]  Setup Pin Code (0 for UNKNOWN/ERROR): 20202021
I: 422 [DL]  Setup Discriminator (0xFFFF for UNKNOWN/ERROR): 3840 (0xF00)
I: 428 [DL]  Manufacturing Date: 2022-02-02
I: 432 [DL]  Device Type: 65535 (0xFFFF)
I: 436 [SVR]SetupQRCode: [MT:6FCJ142C00KA0648G00]
I: 440 [SVR]Copy/paste the below URL in a browser to see the QR Code:
I: 446 [SVR]https://project-chip.github.io/connectedhomeip/qrcode.html?data=MT%3A6FCJ142C00KA0648G00
I: 455 [SVR]Manual pairing code: [34970112332]
I: 460 [DL]CHIP task running
I: 465 [DL]CHIPoBLE advertising started
I: 468 [ZCL]Cluster OnOff: attribute OnOff set to 0
I: 473 [ZCL]Cluster LevelControl: attribute CurrentLevel set to 254
I: 479 [DL]NFC Tag emulation started
I: BLE advertising is already enabled
I: 30468 [DL]CHIPoBLE advertising mode changed to slow
I: 30475 [DL]CHIPoBLE advertising started
