NRF Timer doesn't start
In my application I need an interrupt every 8us that I use as basetime, so I add a nrf timer to my code in the following way:
in the prj.conf
CONFIG_NRFX_TIMER1=y
CONFIG_NRFX_TIMER2=y
In the application:
#include <nrfx_timer.h>
#include <irq.h>
static const nrfx_timer_t mIrTimer = NRFX_TIMER_INSTANCE(2);
static volatile uint64_t mIrTimerCounter = 0;
static void irTimerHandler (nrf_timer_event_t event_type, void *p_context)
    mIrTimerCounter += 8;
static bool startIrTimer (void)
    nrfx_err_t errCode;
    nrfx_timer_config_t tmrConfig = NRFX_TIMER_DEFAULT_CONFIG;
    tmrConfig.frequency           = NRF_TIMER_FREQ_125kHz;
    tmrConfig.mode                = NRF_TIMER_MODE_TIMER;
    tmrConfig.bit_width           = NRF_TIMER_BIT_WIDTH_32;
    //tmrConfig.interrupt_priority  = NRFX_TIMER_DEFAULT_CONFIG_IRQ_PRIORITY;
    errCode = nrfx_timer_init(&mIrTimer,&tmrConfig,irTimerHandler);
    if (errCode != NRFX_SUCCESS)
		return false;
    // Interrupt every 10us
    //nrfx_timer_extended_compare(&mIrTimer,NRF_TIMER_CC_CHANNEL1,10,NRF_TIMER_SHORT_COMPARE1_CLEAR_MASK, true);
	IRQ_CONNECT(TIMER2_IRQn,2,nrfx_timer_2_irq_handler, NULL,0);
    nrfx_timer_clear(&mIrTimer);
    nrfx_timer_enable(&mIrTimer);
    return true;
I call the function startIrTimer() and the function return without any error, but the callback is never called. Where is it the problem?
Best
Marco
  • you seems to have commented out the nrfx_timer_extended_compare which actually sets the CC register needed to trigger the event and the interrupt. Have you tried uncommenting the nrfx_timer_extended_compare part?
    Also you seem to be using 10 ticks hardcoded into the cc_value parameter in the nrfx_timer_extended_compare  function.
    Setting 10 in CC of Timer running at 125KHz speed will give you a timeout of 80uS not 8uS (or maybe 8uS is a typo?)
  • Hi Susheel,
    thanks for the reply. Yes, you are right, 8us is a typo.
    In the application I need an interrupt every 10us, so I changed the code in this way:
        nrfx_err_t errCode;
        tmrConfig.frequency           = NRF_TIMER_FREQ_1MHz;
        tmrConfig.bit_width           = NRF_TIMER_BIT_WIDTH_8;
    		return false;
        nrfx_timer_extended_compare(&mIrTimer, NRF_TIMER_CC_CHANNEL0, 10, NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK, true);
    	IRQ_CONNECT(TIMER2_IRQn,5,nrfx_timer_2_irq_handler, NULL,0);
        //nrfx_timer_clear(&mIrTimer);
        return true;
    Now the interrupt was triggered, but it seems to be ten times faster. How is it possible?
    Best
    Marco
  • instead of using 10 as hardcoded value in the nrfx_timer_extended_compare I suggest you use this code to get correct conversion.
    uint32_t desired_ticks = nrfx_timer_us_to_ticks(&mIrTimer, 10);
    nrfx_timer_extended_compare(&mIrTimer, NRF_TIMER_CC_CHANNEL0, desired_ticks, NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK, true);
  • Hi Susheel,
    thank, with your suggestion the base-time works but not perfecty: I mean that the interrupt some time was triggered after 6us and other times after 29us. What is it wrong?
    Best
    Marco
  • Hi Susheel,
    I am using a pin to toggle its output just to show when the interrupt was trigger.
    The output is the yellow line.
    Thanks
    Marco
