Unit testing using ncs and Unity/CMock
Hi Nordic Devzone,
I started developing a product around nrf52840 and nrf Connect SDK. It was my first time using Zephyr and the SDK, so after a few weeks of getting into it, I started to write some firmware, and I would now like to implement unit tests. I started following the instructions on this page : https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/test_and_optimize/testing_unity_cmock.html
I tried the example_test fine, but I am a bit stuck on how best to do it on my files. I started on some of my simplest files, ui.h/ui.c :
ui.h:
#ifndef UI_H_
#define UI_H_
#include <zephyr/kernel.h>
#include <zephyr/device.h>
#include <zephyr/drivers/pwm.h>
#define STEP_SIZE PWM_USEC(2000)
#define UI_COLOR_MAX 10000
#define UI_LED_INTENSITY_LOW 200
typedef struct
    uint16_t red;   /* Intensity 0-UI_COLOR_MAX */
    uint16_t green; /* Intensity 0-UI_COLOR_MAX */
    uint16_t blue;  /* Intensity 0-UI_COLOR_MAX */
} ui_rgb_t;
uint8_t ui_init();
uint8_t ui_set_rgb_on(ui_rgb_t *color);
uint8_t ui_set_rgb_off();
#endif /* UI_H_ */
ui.c :
#include <include/ui.h>
LOG_MODULE_REGISTER(UI, LOG_LEVEL_DBG);
static const struct pwm_dt_spec red_pwm_led =
    PWM_DT_SPEC_GET(DT_ALIAS(pwmled1red));
static const struct pwm_dt_spec green_pwm_led =
    PWM_DT_SPEC_GET(DT_ALIAS(pwmled0green));
static const struct pwm_dt_spec blue_pwm_led =
    PWM_DT_SPEC_GET(DT_ALIAS(pwmled2blue));
ui_rgb_t off = {0, 0, 0};
    int ret;
    uint32_t r, g, b;
    if (color->red >= UI_COLOR_MAX)
        color->red = UI_COLOR_MAX;
    if (color->green >= UI_COLOR_MAX)
        color->green = UI_COLOR_MAX;
    if (color->blue >= UI_COLOR_MAX)
        color->blue = UI_COLOR_MAX;
    r = red_pwm_led.period / UI_COLOR_MAX * color->red;
    ret = pwm_set_pulse_dt(&red_pwm_led, r);
    if (ret != 0)
        LOG_ERR("Error %d: red write failed.", ret);
        LOG_HEXDUMP_ERR(color, sizeof(ui_rgb_t), "Error while writing color :");
        return 0;
    g = green_pwm_led.period / UI_COLOR_MAX * color->green;
    ret = pwm_set_pulse_dt(&green_pwm_led, g);
    if (ret != 0)
        LOG_ERR("Error %d: green write failed.", ret);
        return 0;
    b = blue_pwm_led.period / UI_COLOR_MAX * color->blue;
    ret = pwm_set_pulse_dt(&blue_pwm_led, b);
    if (ret != 0)
        LOG_ERR("Error %d: blue write failed.", ret);
        return 0;
    return 1;
    ui_rgb_t off;
    off.red = 0;
    off.green = 0;
    off.blue = 0;
    return ui_set_rgb_on(&off);
uint8_t ui_init()
    if (!device_is_ready(red_pwm_led.dev) ||
        !device_is_ready(green_pwm_led.dev) ||
        !device_is_ready(blue_pwm_led.dev))
        LOG_ERR("Error: one or more PWM devices not ready");
        return 0;
    return 1;
I wanted first to test the ui_init function, so I started writing this ui_test.c file based on example_test.c :
 * Copyright (c) 2019 Nordic Semiconductor ASA
#include <unity.h>
#include <ui.h>
#include <stdbool.h>
#include "device/cmock_device.h"
#include "pwm/cmock_pwm.h"
void setUp(void)
void test_ui_init(void)
	int err;
	__cmock_device_is_ready_ExpectAndReturn(red_pwm_led.dev, 0);
	__cmock_device_is_ready_ExpectAndReturn(green_pwm_led.dev, 0);
	__cmock_device_is_ready_ExpectAndReturn(blue_pwm_led.dev, 0);
	//__cmock_foo_execute_ExpectAndReturn(0);
	err = ui_init(NULL);
	TEST_ASSERT_EQUAL(1, err);
/* It is required to be added to each test. That is because unity's
 * main may return nonzero, while zephyr's main currently must
 * return 0 in all cases (other values are reserved).
extern int unity_main(void);
	(void)unity_main();
	return 0;
I mocked the device_is_ready function by adding
cmock_handle($ENV{ZEPHYR_BASE}/include/zephyr/device.h device)
to the CMakeLists.txt file, and then I wanted to use
function. I wondered what to use as the "device" argument, and figured I'd declare the leds the same way I did when using my board. However, obviously, the native_posix board does not have such leds so it doesn't work.
Is my general approach correct ? Do you have any tips on testing such functions that use hardware-related functions ?
Thanks in advance.
Nicolas Goualard
