QEMU with board qemu_x86 crashes in snprintf()- source code missing, hard to debug
Have a strange crash when calling snprintf (using qemu x86):
    •  I flash the ztest to the board, it works, but running qemu in windows x86, it crashes on that snprintf-line below.
      Use Nordic open connect sdk version (2.2).
      I see it's declared as: int snprintf (char __restrict, size_t, const charrestrict, ...) _ATTRIBUTE ((format (printf__, 3, 4)));
      Problem causing lines:
      int m_unique_id_sent = 124568;
      char unique_id_sent_buf[36];
      int len = snprintf(unique_id_sent_buf, sizeof(unique_id_sent_buf), "%d", m_unique_id_sent);
      I get a crash (in qemu, running a unit test I wrote, for a module I want to test).
      LOG (with decoded crash address pointers
      E: Double Fault E:
      EAX: 0x002c4200,
      EBX: 0x002c4200,
      ECX: 0x0025c22c,
      EDX: 0x0013b254
      E: ESI: 0x0013a9f0,
      EDI: 0x00120a8b,
      EBP: 0x0025c168,
      ESP: 0x0025bfe4
      E: EFLAGS: 0x00000206
      CS: 0x0008
      CR3: 0x002ca000
      E: call trace:
      E: EIP: 0x001065af
      E: 0x00105f88 (0x2c4200) - (zephyr: snprint) no debug info available. Will look at zephyr_final.map for this one (see below after crash log) (1st parameters is defined on stack as: char unique_id_sent_buf[36];
      E: 0x00116f9d (0x25c214) - (my code) rpc.c: 401 - calling snprintf(unique_id_sent_buf, sizeof(unique_id_sent_buf), "%d", m_unique_id_sent);
      E: 0x001172ed (0x25c4fc) - (my code) rpc.c : 532 // calling new function (4 parameters)
      E: 0x001173ce (0x25c4fc) - (my code) rpc.c : 583 // Inside function - calling other function (char * buf, int size)
      E: 0x00114014 (0x25c4fc) - (my code)..server_response.c: line 74 - calling function pointer to other module (all good)
      E: 0x00112ed5 (0x1173ac) - (my code) test_function: line 403 (all good)
      E: 0x001140d8 (0xaaaaaaaa) - ztest main.c // zassert_true(ztest_test_function(), "Error when testing test_function");
      E: 0x0011409e (0xaaaaaaaa) - ztest main.c // ZTEST(ocpp_client_tests, test_use_case_a1)
      E: >>> ZEPHYR FATAL ERROR 2: Stack overflow on CPU 0 E: Current thread: 0x149dc0 (main) E: Halting system
      I have defined stacks good for the emulator. Didn't help.
      CONFIG_HEAP_MEM_POOL_SIZE=128000
      CONFIG_MAIN_STACK_SIZE=128000
      CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=128000
      FAILED: zephyr/CMakeFiles/debugserver_qemu cmd.exe /C "cd /D C:\k\np\v2.2.0\ocpp-9160\apps\ocpp_client\tests_build_ocpp_qemu_x86_ZTEST && "C:\Program Files\qemu\qemu-system-i386.exe" -m 4 -cpu qevice isa-debug-exit,iobase=0xf4,iosize=0x04 -nographic -no-acpi -net none -pidfile qemu.pid -chardev stdio,id=con,mux=on -serial chardev:con -mon chardrnel C:/k/np/v2.2.0/ocpp-9160/apps/ocpp_client/tests/_build_ocpp_qemu_x86_ZTEST/zephyr/zephyr.elf" ninja: build stopped: subcommand failed. make[1]: [Makefile:37: debug_qemu_x86] Error 1 make[1]: Leaving directory 'C:/k/np/v2.2.0/ocpp-9160/apps/ocpp_client/tests' make: [Makefile:108: start_qemu_x86_gdb_sever] Error
      MAP FILE INSPECTION
      LOOKING AT the zephyr_final.map I find this: .
      text.
      snprintf 0x0000000000105f40 0xae   C:/k/np/toolchains/v2.2.0/opt/zephyr-sdk/x86_64-zephyr-elf/x86_64-zephyr-elf/lib/32/soft-float\libc.a(lib_a-snprintf.o)
      0x0000000000105f40 snprintf
      So it's somewhere inside the snprintf it crashes with fault or double fault. I'm not sure where to find the source code and map what c-code line this offset of 0x00105f88 maps to. Can someone give me some helpful advice on the above generally?
      Cheers,
      JOhan
