QEMU with board qemu_x86 crashes in snprintf()- source code missing, hard to debug
Have a strange crash when calling snprintf (using qemu x86):
    •  I flash the ztest to the board, it works, but running qemu in windows x86, it crashes on that snprintf-line below.
      Use Nordic open connect sdk version (2.2).
      I see it's declared as: int snprintf (char __restrict, size_t, const charrestrict, ...) _ATTRIBUTE ((format (printf__, 3, 4)));
      Problem causing lines:
      int m_unique_id_sent = 124568;
      char unique_id_sent_buf[36];
      int len = snprintf(unique_id_sent_buf, sizeof(unique_id_sent_buf), "%d", m_unique_id_sent);
      I get a crash (in qemu, running a unit test I wrote, for a module I want to test).
      LOG (with decoded crash address pointers
      E: Double Fault E:
      EAX: 0x002c4200,
      EBX: 0x002c4200,
      ECX: 0x0025c22c,
      EDX: 0x0013b254
      E: ESI: 0x0013a9f0,
      EDI: 0x00120a8b,
      EBP: 0x0025c168,
      ESP: 0x0025bfe4
      E: EFLAGS: 0x00000206
      CS: 0x0008
      CR3: 0x002ca000
      E: call trace:
      E: EIP: 0x001065af
      E: 0x00105f88 (0x2c4200) - (zephyr: snprint) no debug info available. Will look at zephyr_final.map for this one (see below after crash log) (1st parameters is defined on stack as: char unique_id_sent_buf[36];
      E: 0x00116f9d (0x25c214) - (my code) rpc.c: 401 - calling snprintf(unique_id_sent_buf, sizeof(unique_id_sent_buf), "%d", m_unique_id_sent);
      E: 0x001172ed (0x25c4fc) - (my code) rpc.c : 532 // calling new function (4 parameters)
      E: 0x001173ce (0x25c4fc) - (my code) rpc.c : 583 // Inside function - calling other function (char * buf, int size)
      E: 0x00114014 (0x25c4fc) - (my code)..server_response.c: line 74 - calling function pointer to other module (all good)
      E: 0x00112ed5 (0x1173ac) - (my code) test_function: line 403 (all good)
      E: 0x001140d8 (0xaaaaaaaa) - ztest main.c // zassert_true(ztest_test_function(), "Error when testing test_function");
      E: 0x0011409e (0xaaaaaaaa) - ztest main.c // ZTEST(ocpp_client_tests, test_use_case_a1)
      E: >>> ZEPHYR FATAL ERROR 2: Stack overflow on CPU 0 E: Current thread: 0x149dc0 (main) E: Halting system
      I have defined stacks good for the emulator. Didn't help.
      CONFIG_HEAP_MEM_POOL_SIZE=128000
      CONFIG_MAIN_STACK_SIZE=128000
      CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=128000
      FAILED: zephyr/CMakeFiles/debugserver_qemu cmd.exe /C "cd /D C:\k\np\v2.2.0\ocpp-9160\apps\ocpp_client\tests_build_ocpp_qemu_x86_ZTEST && "C:\Program Files\qemu\qemu-system-i386.exe" -m 4 -cpu qevice isa-debug-exit,iobase=0xf4,iosize=0x04 -nographic -no-acpi -net none -pidfile qemu.pid -chardev stdio,id=con,mux=on -serial chardev:con -mon chardrnel C:/k/np/v2.2.0/ocpp-9160/apps/ocpp_client/tests/_build_ocpp_qemu_x86_ZTEST/zephyr/zephyr.elf" ninja: build stopped: subcommand failed. make[1]: [Makefile:37: debug_qemu_x86] Error 1 make[1]: Leaving directory 'C:/k/np/v2.2.0/ocpp-9160/apps/ocpp_client/tests' make: [Makefile:108: start_qemu_x86_gdb_sever] Error
      MAP FILE INSPECTION
      LOOKING AT the zephyr_final.map I find this: .
      text.
      snprintf 0x0000000000105f40 0xae   C:/k/np/toolchains/v2.2.0/opt/zephyr-sdk/x86_64-zephyr-elf/x86_64-zephyr-elf/lib/32/soft-float\libc.a(lib_a-snprintf.o)
      0x0000000000105f40 snprintf
      So it's somewhere inside the snprintf it crashes with fault or double fault. I'm not sure where to find the source code and map what c-code line this offset of 0x00105f88 maps to. Can someone give me some helpful advice on the above generally?
      Cheers,
      JOhan
    • Hi Johan,
      Do you use one of ther samples in  the nRF Connect SDK for this?
      If yes, can you give the command you use to build for qemu?
      Sigurd Hellesvik
    • We use our own project, no sample code.
      We use QEMU x86 to test our code, with controlled inputs and outputs.
      Our code has e few threads running for example, and hardware interfaces (simulated).
      build command is:
      west build --build-dir _build_xyz_qemu_x86_ZTEST -b qemu_x86 -t run
      .conf file for qemu x86 used contains this:
      CONFIG_ASSERT=y
      CONFIG_NEWLIB_LIBC=y
      CONFIG_EVENTS=y
      CONFIG_REBOOT=y
      CONFIG_DEBUG=y
      CONFIG_LOG=y
      CONFIG_LOG_BACKEND_RTT=n
      CONFIG_LOG_PRINTK=y
      CONFIG_LOG_BUFFER_SIZE=256
      # JSON
      CONFIG_JSON_LIBRARY=y
      #CONFIG_QEMU_ICOUNT=n
      #CONFIG_ENTROPY_GENERATOR=y
      #CONFIG_TEST_RANDOM_GENERATOR=y
      # Network
      CONFIG_NETWORKING=y
      CONFIG_NET_NATIVE=n
      CONFIG_NET_SOCKETS=y
      CONFIG_NET_SOCKETS_OFFLOAD=y
      CONFIG_NET_SOCKETS_POSIX_NAMES=y
      # mbed TLS and security
      CONFIG_MBEDTLS_PK_C=y
      CONFIG_MBEDTLS_RSA_C=y
      CONFIG_MBEDTLS_PKCS1_V15=y
      CONFIG_MBEDTLS_ENABLE_HEAP=y
      CONFIG_MBEDTLS_HEAP_SIZE=55936
      CONFIG_MBEDTLS_TLS_LIBRARY=y
      CONFIG_MBEDTLS_X509_LIBRARY=y
      CONFIG_NRF_SECURITY_ADVANCED=y
      CONFIG_NORDIC_SECURITY_BACKEND=y
      # You can enable mbed TLS debug with
      CONFIG_MBEDTLS_DEBUG_C=y
      CONFIG_MBEDTLS_SHA1_C=y
      # AT host library
      # CONFIG_AT_HOST_LIBRARY=y
      # Net related
      CONFIG_NET_SOCKETS_SOCKOPT_TLS=n
      CONFIG_NET_IPV4=y
      CONFIG_NET_IPV6=n
      CONFIG_DEBUG_OPTIMIZATIONS=n
      # Heap and stacks
      # Extended memory heap size needed for encoding nRF Cloud messages to JSON
      CONFIG_HEAP_MEM_POOL_SIZE=4096
      CONFIG_MAIN_STACK_SIZE=4096
      CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096
      CONFIG_NO_OPTIMIZATIONS=y
      # settings
      CONFIG_SETTINGS=y
      CONFIG_SETTINGS_RUNTIME=y
      CONFIG_STDOUT_CONSOLE=y
      CONFIG_FLASH=y
      CONFIG_FLASH_MAP=y
      CONFIG_NVS=y
      CONFIG_SETTINGS_NVS=y
      CONFIG_SHELL_CMDS_SELECT=y
      CONFIG_INIT_STACKS=y
      CONFIG_THREAD_STACK_INFO=y
      CONFIG_THREAD_MONITOR=y
      # ZTEST
      CONFIG_ZTEST=y
      CONFIG_ZTEST_NEW_API=y
      # ZTEST enable test shuffling for more testing
      #CONFIG_ZTEST_SHUFFLE=y
      #CONFIG_ZTEST_SHUFFLE_SUITE_REPEAT_COUNT=0
      #CONFIG_ZTEST_SHUFFLE_TEST_REPEAT_COUNT=0
      # ZTEST more log output
      CONFIG_ZTEST_VERBOSE_OUTPUT=y
      CONFIG_ZTEST_VERBOSE_SUMMARY=y
    • The zephyr-sdk compiled in toolchain 2.2.0 is:
      0.15.1
      Quite old.
      Latest is: Zephyr SDK 0.16.1
    • Perhaps we need to switch to Connect SDK 2.4.0, if that is using the latest Zephyr SDK 0.16.1, possibly.
      I see Connect SDK 2.4.0 uses 0.16.0, so quite new.
