I am implementing GPS on our custom board using modem firmware v1.3.5 (SDK v2.4.0).
From the documentation I understand that the modem stores information about satellites and constellations in non-volatile memory (derived from https://developer.nordicsemi.com/nRF_Connect_SDK/doc/2.4.0/nrfxlib/nrf_modem/doc/gnss_interface.html#deleting-gnss-data-stored-in-nv-memory)
What is unclear to me is when the information is stored, what exact information is stored and how I should/can enable the modem to use it. I tested acquiring a GPS fix, which worked and took about 11 minutes. I expected that after a system reset the modem would find a GPS fix more quickly, but it still took another 11 minutes to find a fix again.
My questions are:
- Do I have to configure something to enable the modem to store GPS data in NV memory?
- Can it be verified that the data has been stored?
- Do I have to manually set parameters for the modem to be able to use the data stored in NV memory?
I have to assume that the system is going to places that have GPS reception, but no LTE coverage. Therefore I do not want to lean on A-GPS, but verify that the system can perform hot or warm starts and measure the system performance in standalone conditions.
Bonus question:
Although our nrf91 SoC is switched off entirely for the most part other parts of the system keep track of the current time, so I can use that information to inject into the A-GPS interface. Is there some utility make it easy to convert a UTC timestamp into a nrf_modem_gnss_agps_data_utc struct?
