Unable to flash custom nRF5340 board with nRF5340DK
I am developing firmware for a custom board using the nRF5340. I have found that I am unable to flash the custom board when using the nRF5340DK as the JTAG device. I am able to flash successfully if I use a SEGGER JLink.
Some pertinent specs are:
  • Windows 11 PC
  • nRF Connect for Desktop v4.1.2
  • Programmer v3.0.9
  • nRF Command Line Tools 10.22.0
  • SEGGER JLink v7.88i
Here is a copy/paste of the log in the Programmer application when I try to flash using the nRF5340DK.
2023-06-27T17:13:40.567Z DEBUG Application data folder: C:\Users\USER\AppData\Roaming\nrfconnect\pc-nrfconnect-programmer
2023-06-27T17:13:40.661Z DEBUG App pc-nrfconnect-programmer v3.0.9 local
2023-06-27T17:13:40.661Z DEBUG App path: C:\Users\USER\.nrfconnect-apps\node_modules\pc-nrfconnect-programmer
2023-06-27T17:13:40.661Z DEBUG nRFConnect 4.1.2, required by the app is (>=4.0.0)
2023-06-27T17:13:40.661Z DEBUG nRFConnect path: C:\Users\USER\AppData\Local\Programs\nrfconnect\resources\app.asar
2023-06-27T17:13:40.662Z DEBUG HomeDir: C:\Users\USER
2023-06-27T17:13:40.662Z DEBUG TmpDir: C:\Users\USER\AppData\Local\Temp
2023-06-27T17:13:41.237Z INFO Installed JLink version does not match the provided version (V7.80c)
2023-06-27T17:13:41.324Z INFO Using nrf-device-lib-js version: 0.6.12
2023-06-27T17:13:41.325Z INFO Using nrf-device-lib version: 0.15.3
2023-06-27T17:13:41.325Z INFO Using nrfjprog DLL version: 10.19.1
2023-06-27T17:13:41.325Z INFO Using JLink version: JLink_V7.88i
2023-06-27T17:13:41.552Z INFO Getting serialport options from persistent store 001050039906.pc-nrfconnect-programmer
2023-06-27T17:13:45.706Z INFO Using @nordicsemiconductor/nrf-device-lib-js to communicate with target via JLink
2023-06-27T17:13:45.706Z INFO JLink OB firmware version J-Link OB-nRF5340-NordicSemi compiled Nov  7 2022 16:22:01
2023-06-27T17:13:45.707Z INFO Device family
2023-06-27T17:13:45.707Z INFO Device version
2023-06-27T17:13:45.707Z INFO Board version PCA10095
2023-06-27T17:13:45.707Z INFO Loading readback protection status for Application core
2023-06-27T17:13:46.041Z ERROR Failed to load readback protection status: async task failure for id: 1162544486 msg: [jlink] UNKNOWN_DEVICE (Origin: "Error when running  operation: protection-get")
2023-06-27T17:13:46.522Z DEBUG Google Analytics for category pc-nrfconnect-programmer has initialized
I then try to recover the device from the command line using nrfjprog and get this output:
C:\Users\USER>nrfjprog -f NRF53 --recover
Recovering device. This operation might take 30s.
[error] [SeggerBackend] - Encountered unexpected debug port ID 4, expected 6
[error] [  nRF53] - Failed while checking eraseprotect status.
ERROR: Recover failed. Please make sure that the correct device family is given
ERROR: and try again.
NOTE: For additional output, try running again with logging enabled (--log).
NOTE: Any generated log error messages will be displayed.
This error happens immediately. There are no additional messages if I add the --log option. I also get the same output if I run it with the --coprocessor CP_NETWORK option.
I found the following link and tried its suggestions for installing the 32-bit SEGGER drivers alongside the 64-bit drivers, but this did not solve my problem.
 RE: nRF Programmer cannot recognize nRF5340-DK (SEGGER JLink driver is newer than nRF Connect for Desktop version)
I have tried separately installing and using both the 32-bit and 64-bit versions of the nRF Command Line Tools, but the results are the same.
Since I have seen other forum posts mention this, I should also mention that VDD for our board is 1.8V.
Would anybody be able to help look into this particular error? I would be happy to supply any other required information.
Thanks
    The problem is that the custom PCB is running 1.8V while the DK is running 3,3V.
    What you can try to do is the following:
    • Connect a usb to both J2 and NRF_USB
    • Switch from "VDD POWER" to "USB SOURCE" on SW9
    • Power up the DK
    • Enjoy 1.8V debugging
    If not I would put a level shifter between the DK and the custom PCB
    Regards
    Runar
  • Hi Runar,
    Thank you for your response. We tried the steps you outlined, but were still unsuccessful. We will be trying a level translator next.
  • Hi Runar,
    We revisited the steps you outlined and were successful with flashing our board. I am unsure where we went wrong previously, but the following specific sequence of steps works for us every time:
    • Start with the nRF5340DK board unpowered and unconnected to anything.
    • Set the nRF POWER SOURCE switch on the DK board to USB.
    • Connect our custom board to the Debug Out connection.
    • Power on our custom board.
    • Plug a USB cable into nRF USB connection and set the DK's POWER switch to ON.
    • Plug a USB cable into the J2 USB connector.
    From there the DK board was recognized as a JTAG device, and we were able to erase and flash our board as normal.
    Thanks for your help!
