I am working on an application using the Rigado BMD-350 development board. It uses the nRF52832. Development is being done in Segger Embedded Studio with nRF_SDK_17.1.0.
I started the project using the ble_app_template example. Quite a bit has changed.
I have one VS UUID with one characteristic (for testing, I'll add more later).
I had problems advertising and increased the NRF_SDH_BLE_VS_UUID_COUNT to 16 and adjusted RAM start and size per the debug messages.
Now I can advertise but when I try to connect (using BlueSee on the desktop), I get a NRF_ERROR_NO_MEM error. The error position is in the following error handler function:
/**@brief Function for handling errors from the Connection Parameters module. * * @param[in] nrf_error Error code containing information about what went wrong. */ static void app_conn_params_error_handler(uint32_t nrf_error) { APP_ERROR_HANDLER(nrf_error); }
This error handler is passed to ble_conn_params_init() in the error_handler member of the ble_conn_params_init_t structure.
I have a function that wraps APP_ERROR_CHECK to print any non-zero error codes and all returns of library code are checked. I'm not seeing any error from a function return.
Is there something in sdk_config.h that I need to adjust?
Thanks!
