Hi all!
I'm using an nRF52832 with SDK 15.2 to bitbang an FPGA image into an ice40 Ultra FPGA by Lattice.
To do this i'm following the relative documentation of the FPGA that gives the directives to configure this ice40 Ultra.
(Documentation available here https://www.latticesemi.com/Products/FPGAandCPLD/iCE40Ultra . The necessary os in the document "iCE40 Programming and Configuration", in the paragraph "SPI Slave Configuration Process" )
In this documentation there is a pseudocode that I report here:
// iCE40 Configuration Pseudo-code
void Config_iCE40 (type, file)
// Open Hex File early to avoid clock delay later
file_pointer = fopen(file);// Open bin file
// Reset the iCE40 Device
Set_Port(SPI_SS_B, false);// Set SPI_SS_B low
Set_Port(CRESET, false);// Set CRESET low
Set_Port(SPI_CLK, true);// Set SPI_CLK high
nSec_Delay(200);// Delay 200 nsec
Set_Port(CRESET, true);// Set CRESET high
if (type == L1K or L4K)
uSec_Delay(800);// Delay 800 usec if L1K,L4K
else if (type == L8K)
uSec_Delay(1200);// Delay 1200 usec for L8K
Set_Port(SPI_SS_B, true);// Set SPI_SS_B high
Send_Clocks (8);// Send 8 clocks
// Send data from bin file
Send_File(file_pointer);// Send bin file
Send_Clocks (100);// Send 100 clocks
// Verify successful configuration
if (Get_Port(CDONE))
Return PASS;// PASS if CDONE is true
Return FAIL;// FAIL if CDONE is false
// Clock Generation 10MHz
void Send_Clocks(num_clocks)
for {i = 0; i < num_clocks; i++}
Set_Port(SPI_CLOCK, false);// Set SPI_CLK low
nSec_Delay(50);// Delay 50 nsec
26
Set_Port(SPI_CLOCK, true);// Set SPI_CLK high
// Send Data from file
void Send_File(file_pointer)
byte = getc(file_pointer);// Read first byte from file
while (byte != EOF)
Send_Byte (byte);// Send data byte
byte = getc(file_pointer);// read next byte from file
As written in the documentation, the binary file has to be sended serially on the MOSI, most significant bit first, on falling edge of SPI Clock and without interruption (With the SPI clock between 1MHz and 25 MHz).
To do that i thought to use nRF_delay functions but the minimum delay in this way is 1 us.
In order to configure this FPGA i should use a delay of maximum some ns instead. For exemple to have an SPI clock of 10MHz i need a delay of 50ns in the function sendclock to compose the falling and rising edge of my clock (and the same in the function that will send data).
How can I implement some kind of delay in my code?
Have anyone have dealt with this ice40 Ultra FPGA and know a smart way to configure the FPGA through an nRF52832?
Thanks to those who light 'and will respond.
