I am using NRF52833 DK which is integrated with 4x4 Antenna array to implement AOA for asset tracking. I want to use same setup to implement distance calculation using RSSI. I have tried the same setup and same antenna switching configuration and the result is not accurate for RSSI. What is reason for it? Do antenna switching affects the RSSI value? or Is there any configuration or setup that needs to be changed?
