I am trying to make the UART0 for communicating with another chip and following https://academy.nordicsemi.com/topic/exercise-1-5/
I am using nrf5340 chip and not the DK,
When I use uart_dev = DEVICE_DT_GET(DT_NODELABEL(uart0)) I am getting undefined reference to `__device_dts_ord_110'
void test_uart(void)
//uart_dev = device_get_binding("uart@8000"); // Passing but not transmitting
uart_dev = DEVICE_DT_GET(DT_NODELABEL(uart0)); //giving undefined reference to `__device_dts_ord_110'
if (!device_is_ready(uart_dev)){
printk("device_get_binding UART0 failed\n");
uart_irq_callback_set(uart_dev, uart_cb);
uart_irq_rx_enable(uart_dev);
while (1)
uart_fifo_fill(uart_dev, "hello",6);
k_sleep(K_MSEC(1000));
CONFIG_GPIO=y
CONFIG_I2C=y
CONFIG_SPI=y
CONFIG_SPI=y
CONFIG_SPI_ASYNC=y
CONFIG_DEBUG_OPTIMIZATIONS=y
CONFIG_ADC=y
CONFIG_ADC_ASYNC=y
CONFIG_ADC_NRFX_SAADC=y
CONFIG_MAIN_STACK_SIZE=4096
CONFIG_FPU=y
CONFIG_CLOCK_CONTROL_NRF_K32SRC_500PPM=y
CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC_CALIBRATION=y
CONFIG_CLOCK_CONTROL_NRF_CALIBRATION_LF_ALWAYS_ON=y
CONFIG_CLOCK_CONTROL_NRF_K32SRC_XTAL=n
CONFIG_PM=y
CONFIG_PM_DEVICE=y
CONFIG_BOARD_ENABLE_CPUNET=y
CONFIG_SOC_ENABLE_LFXO=n
CONFIG_DEBUG_THREAD_INFO=y
CONFIG_SERIAL=n
CONFIG_LOG=n
CONFIG_ASSERT=y
CONFIG_ASSERT_NO_COND_INFO=y
CONFIG_ASSERT_NO_MSG_INFO=y
CONFIG_HW_STACK_PROTECTION=y
CONFIG_USE_SEGGER_RTT=y
CONFIG_CONSOLE=y
CONFIG_UART_CONSOLE=n
CONFIG_UART_ASYNC_API=y
#CONFIG_UART_0_NRF_FLOW_CONTROL=n
&gpio_fwd {
uart {
/delete-property/ gpios;
status = "disabled";
&uart0 {
/delete-property/ rts-pin;
/delete-property/ cts-pin;
Any clue how to fix this ?
Really fed-up of this device tree and early initialization of peripherals.
Any way to totally bypass all these and write the uart and all peripherals in the traditional way and use the zephyr just as an RTOS like freeRTOS ?
Because I really want to switch between uart ports by sharing same UART0 between two different port pins of the MCU on run time and not dependent on any power modes and all.
