ZTest cmake error
Hi.  I am new to Ztest and cannot get the basic example to work.  I have taken the basic dev acadamy lesson 2 exercise 1 project and placed the test sample (samples/subsys/testsuite/integration) into the tests folder of the project as suggested in the framework guide (https://docs.zephyrproject.org/latest/develop/test/ztest.html) but get cmake errors when running twister.  It lists the tests fine:
C:\nordic\ncs-fund\v2.x.x\lesson2\fund_less2_exer2_solution>python C:\ncs\v2.3.0\zephyr\scripts\twister --list-tests -T C:\nordic\ncs-fund\v2.x.x\lesson2\fund_less2_exer2_solution\tests
ZEPHYR_BASE unset, using "C:\ncs\v2.3.0\zephyr"
Renaming output directory to C:\nordic\ncs-fund\v2.x.x\lesson2\fund_less2_exer2_solution\twister-out.4
INFO - Using Ninja..
INFO - Zephyr version: v3.2.99-ncs2
INFO - Using 'zephyr' toolchain.
- sample.testing.ztest.assert
1 total.
But when you try to run this is the build.log produced.  I assume the file it cannot fine is zephyr/ztest.h as it is red underlined in VSCode but cannot for the life of me figure out how to make this basic sample work!  I have tried modifying the test cases CMake file to include the \subsys\testsuite\ztest\include\zephyr\ folder where ztest.h is located but does not work. Thanks in advance.
-- Application: C:/nordic/ncs-fund/v2.x.x/lesson2/fund_less2_exer2_solution/tests
-- Using NCS Toolchain 2.3.0 for building. (C:/ncs/toolchains/v2.3.0/cmake)
-- Found Python3: C:/ncs/toolchains/v2.3.0/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter
-- Cache files will be written to: C:/ncs/v2.3.0/zephyr/.cache
-- Zephyr version: 3.2.99 (C:/ncs/v2.3.0/zephyr)
-- Board: native_posix
-- Found host-tools: zephyr 0.15.2 (C:/ncs/toolchains/v2.3.0/opt/zephyr-sdk)
-- Found toolchain: host (gcc/ld)
-- Found Dtc: C:/ncs/toolchains/v2.3.0/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
-- Found BOARD.dts: C:/ncs/v2.3.0/zephyr/boards/posix/native_posix/native_posix.dts
CMake Error at C:/ncs/v2.3.0/zephyr/cmake/modules/dts.cmake:191 (message):
command failed with return code: The system cannot find the file specified
C:/ncs/v2.3.0/zephyr/cmake/modules/zephyr_default.cmake:108 (include)
C:/ncs/v2.3.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include)
C:/ncs/v2.3.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
CMakeLists.txt:4 (find_package)
