nrf_fstorage_erase hardfault after use nordic flash loader
We use nrf52840 and SDK 17.0.2 with Softdevice S340
   We have a very strange problem and need help from Nordic. Below is my source code.
uint32_t bootloader_start_addr = 0xF2000;
static void power_manage(void)
#ifdef SOFTDEVICE_PRESENT
    (void) sd_app_evt_wait();
#else
    __WFE();
void wait_for_flash_ready(nrf_fstorage_t const * p_fstorage)
    /* While fstorage is busy, sleep and wait for an event. */
    while (nrf_fstorage_is_busy(p_fstorage))
        power_manage();
static void fstorage_evt_handler(nrf_fstorage_evt_t * p_evt)
    if (p_evt->result != NRF_SUCCESS)
        return;
    switch (p_evt->id)
        case NRF_FSTORAGE_EVT_WRITE_RESULT:
        } break;
        case NRF_FSTORAGE_EVT_ERASE_RESULT:
        } break;
NRF_FSTORAGE_DEF(nrf_fstorage_t fstorage) =
    /* Set a handler for fstorage events. */
    .evt_handler = fstorage_evt_handler,
    /* These below are the boundaries of the flash space assigned to this instance of fstorage.
     * You must set these manually, even at runtime, before nrf_fstorage_init() is called.
     * The function nrf5_flash_end_addr_get() can be used to retrieve the last address on the
     * last page of flash available to write data. */
    .start_addr = 0x31000,
    .end_addr   = 0xFFFFF,
void update_bootloader_func()
    volatile uint8_t iap_update_flag = 0;
    uint32_t err_code = 0;
    uint8_t i = 0;
    uint32_t data = 0xF2000;
    nrf_fstorage_api_t * p_fs_api;
    p_fs_api = &nrf_fstorage_sd;
    err_code = nrf_fstorage_init(&fstorage, p_fs_api, NULL);
    nrf_fstorage_erase(&fstorage,bootloader_start_addr,1,NULL);
    wait_for_flash_ready(&fstorage);
    ret_code_t err_code;
    uint32_t temp = 0;
    update_bootloader_func();
    while(1);
I don't have any Bootloader and My application flash range is 0x31000 - 0xF1ffff
After I build and download by IAR. Everything is OK. I can erase internal flash 1 block form 0xF2000
But If I click option -> Debugger -> Use flash loader and Override default .board file
I go to run the same source code. Erase action will cause Hardfault in below function
/* Erase flash page(s). */
static uint32_t erase_execute(nrf_fstorage_sd_op_t const * p_op)
return sd_flash_page_erase(p_op->erase.page + p_op->erase.progress);
Why? We don't have any idea how to debug this problem. Can you help me to try this problem using my source code?
Thank you.
John.
