We use nrf52840 and SDK 17.0.2 with Softdevice S340
We have a very strange problem and need help from Nordic. Below is my source code.
uint32_t bootloader_start_addr = 0xF2000; static void power_manage(void) { #ifdef SOFTDEVICE_PRESENT (void) sd_app_evt_wait(); #else __WFE(); #endif } void wait_for_flash_ready(nrf_fstorage_t const * p_fstorage) { /* While fstorage is busy, sleep and wait for an event. */ while (nrf_fstorage_is_busy(p_fstorage)) { power_manage(); } } static void fstorage_evt_handler(nrf_fstorage_evt_t * p_evt) { if (p_evt->result != NRF_SUCCESS) { return; } switch (p_evt->id) { case NRF_FSTORAGE_EVT_WRITE_RESULT: { } break; case NRF_FSTORAGE_EVT_ERASE_RESULT: { } break; default: break; } } NRF_FSTORAGE_DEF(nrf_fstorage_t fstorage) = { /* Set a handler for fstorage events. */ .evt_handler = fstorage_evt_handler, /* These below are the boundaries of the flash space assigned to this instance of fstorage. * You must set these manually, even at runtime, before nrf_fstorage_init() is called. * The function nrf5_flash_end_addr_get() can be used to retrieve the last address on the * last page of flash available to write data. */ .start_addr = 0x31000, .end_addr = 0xFFFFF, }; void update_bootloader_func() { volatile uint8_t iap_update_flag = 0; uint32_t err_code = 0; uint8_t i = 0; uint32_t data = 0xF2000; nrf_fstorage_api_t * p_fs_api; p_fs_api = &nrf_fstorage_sd; err_code = nrf_fstorage_init(&fstorage, p_fs_api, NULL); APP_ERROR_CHECK(err_code); nrf_fstorage_erase(&fstorage,bootloader_start_addr,1,NULL); wait_for_flash_ready(&fstorage); } int main(void) { ret_code_t err_code; uint32_t temp = 0; update_bootloader_func(); while(1); }
I don't have any Bootloader and My application flash range is 0x31000 - 0xF1ffff
After I build and download by IAR. Everything is OK. I can erase internal flash 1 block form 0xF2000
But If I click option -> Debugger -> Use flash loader and Override default .board file
I go to run the same source code. Erase action will cause Hardfault in below function
/* Erase flash page(s). */
static uint32_t erase_execute(nrf_fstorage_sd_op_t const * p_op)
return sd_flash_page_erase(p_op->erase.page + p_op->erase.progress);
Why? We don't have any idea how to debug this problem. Can you help me to try this problem using my source code?
Thank you.
John.
