MQTT publish POLLERR error
I'm using nrf9160 MQTT at commands to send real-time data to the cloud. I run into the issue where the MQTT publish may fail (frequency varies around 1 out of 500 publishes). One thread suggests the MQTT fails if the message is too long, however, I don't think this is my case. Any suggestions on how to debug this issue?
Thanks!
Ye-Sheng
The debug message from the modem
This is the working one:
00> [00:18:17.373,504] <inf> slm_at_host: Enter datamode
00> [00:18:17.550,323] <inf> slm_at_host: time limit reached
00> [00:18:17.550,384] <inf> slm_at_host: Raw send 1479
00> [00:18:17.550,415] <dbg> net_mqtt: mqtt_publish: (0x2001b2b8): [CID 0x2001b5cc]:[State 0x06]: >> Topic size 0x00000015, Data size 0x000005c7
00> [00:18:17.550,476] <dbg> net_mqtt_enc: pack_utf8_str: (0x2001b2b8): >> str_size:00000017 cur:0x2001f163, end:0x2001f35e
00> [00:18:17.550,506] <dbg> net_mqtt_enc: pack_uint16: (0x2001b2b8): >> val:0015 cur:0x2001f163, end:0x2001f35e
00> [00:18:17.550,506] <dbg> net_mqtt_enc: mqtt_encode_fixed_header: (0x2001b2b8): << msg type:0x30 length:0x000005de
00> [00:18:17.550,537] <dbg> net_mqtt_enc: packet_length_encode: (0x2001b2b8): >> length:0x000005de cur:(nil), end:(nil)
00> [00:18:17.550,537] <dbg> net_mqtt_enc: mqtt_encode_fixed_header: (0x2001b2b8): Fixed header length = 03
00> [00:18:17.550,537] <dbg> net_mqtt_enc: pack_uint8: (0x2001b2b8): >> val:30 cur:0x2001f160, end:0x2001f35e
00> [00:18:17.550,567] <dbg> net_mqtt_enc: packet_length_encode: (0x2001b2b8): >> length:0x000005de cur:0x2001f161, end:0x2001f35e
00> [00:18:17.550,567] <dbg> net_mqtt: client_write_msg: (0x2001b2b8): [0x2001b5cc]: Transport writing message.
00> [00:18:17.554,443] <dbg> net_mqtt: client_write_msg: (0x2001b2b8): [0x2001b5cc]: Transport write complete.
00> [00:18:17.554,473] <dbg> net_mqtt: mqtt_publish: (0x2001b2b8): [CID 0x2001b5cc]:[State 0x06]: << result 0x00000000
00> [00:18:17.554,504] <inf> slm_mqtt: datamode send: 0
00> [00:18:18.542,633] <inf> slm_at_host: time limit reached
00> [00:18:18.542,724] <inf> slm_at_host: Raw send 1478
00> [00:18:18.542,724] <dbg> net_mqtt: mqtt_publish: (0x2001b2b8): [CID 0x2001b5cc]:[State 0x06]: >> Topic size 0x00000015, Data size 0x000005c6
00> [00:18:18.542,785] <dbg> net_mqtt_enc: pack_utf8_str: (0x2001b2b8): >> str_size:00000017 cur:0x2001f163, end:0x2001f35e
00> [00:18:18.542,816] <dbg> net_mqtt_enc: pack_uint16: (0x2001b2b8): >> val:0015 cur:0x2001f163, end:0x2001f35e
00> [00:18:18.542,816] <dbg> net_mqtt_enc: mqtt_encode_fixed_header: (0x2001b2b8): << msg type:0x30 length:0x000005dd
00> [00:18:18.542,846] <dbg> net_mqtt_enc: packet_length_encode: (0x2001b2b8): >> length:0x000005dd cur:(nil), end:(nil)
00> [00:18:18.542,846] <dbg> net_mqtt_enc: mqtt_encode_fixed_header: (0x2001b2b8): Fixed header length = 03
00> [00:18:18.542,846] <dbg> net_mqtt_enc: pack_uint8: (0x2001b2b8): >> val:30 cur:0x2001f160, end:0x2001f35e
00> [00:18:18.542,877] <dbg> net_mqtt_enc: packet_length_encode: (0x2001b2b8): >> length:0x000005dd cur:0x2001f161, end:0x2001f35e
00> [00:18:18.542,877] <dbg> net_mqtt: client_write_msg: (0x2001b2b8): [0x2001b5cc]: Transport writing message.
00> [00:18:18.546,844] <dbg> net_mqtt: client_write_msg: (0x2001b2b8): [0x2001b5cc]: Transport write complete.
00> [00:18:18.546,875] <dbg> net_mqtt: mqtt_publish: (0x2001b2b8): [CID 0x2001b5cc]:[State 0x06]: << result 0x00000000
00> [00:18:18.546,875] <inf> slm_mqtt: datamode send: 0
00> [00:18:18.546,905] <inf> slm_at_host: datamode off pending
00> [00:18:18.557,098] <inf> slm_at_host: Exit datamode
This is the failed one.
00> [00:18:19.397,705] <inf> slm_at_host: Enter datamode
00> [00:18:19.573,089] <inf> slm_at_host: time limit reached
00> [00:18:19.573,150] <inf> slm_at_host: Raw send 1466
00> [00:18:19.573,150] <dbg> net_mqtt: mqtt_publish: (0x2001b2b8): [CID 0x2001b5cc]:[State 0x06]: >> Topic size 0x00000015, Data size 0x000005ba
00> [00:18:19.573,272] <dbg> net_mqtt_enc: pack_utf8_str: (0x2001b2b8): >> str_size:00000017 cur:0x2001f163, end:0x2001f35e
00> [00:18:19.573,303] <dbg> net_mqtt_enc: pack_uint16: (0x2001b2b8): >> val:0015 cur:0x2001f163, end:0x2001f35e
00> [00:18:19.573,303] <dbg> net_mqtt_enc: mqtt_encode_fixed_header: (0x2001b2b8): << msg type:0x30 length:0x000005d1
00> [00:18:19.573,333] <dbg> net_mqtt_enc: packet_length_encode: (0x2001b2b8): >> length:0x000005d1 cur:(nil), end:(nil)
00> [00:18:19.573,333] <dbg> net_mqtt_enc: mqtt_encode_fixed_header: (0x2001b2b8): Fixed header length = 03
00> [00:18:19.573,333] <dbg> net_mqtt_enc: pack_uint8: (0x2001b2b8): >> val:30 cur:0x2001f160, end:0x2001f35e
00> [00:18:19.573,364] <dbg> net_mqtt_enc: packet_length_encode: (0x2001b2b8): >> length:0x000005d1 cur:0x2001f161, end:0x2001f35e
00> [00:18:19.573,364] <dbg> net_mqtt: client_write_msg: (0x2001b2b8): [0x2001b5cc]: Transport writing message.
00> [00:18:19.577,117] <dbg> net_mqtt: client_write_msg: (0x2001b2b8): [0x2001b5cc]: Transport write complete.
00> [00:18:19.577,148] <dbg> net_mqtt: mqtt_publish: (0x2001b2b8): [CID 0x2001b5cc]:[State 0x06]: << result 0x00000000
00> [00:18:19.577,148] <inf> slm_mqtt: datamode send: 0
00> [00:18:20.137,756] <err> slm_mqtt: POLLERR
00> [00:18:20.137,786] <inf> net_mqtt_sock_tls: Closing socket 0
00> [00:18:20.139,099] <inf> slm_mqtt: MQTT thread terminated
00> [00:18:20.176,391] <inf> slm_at_host: time limit reached
00> [00:18:20.176,452] <inf> slm_at_host: Raw send 11
00> [00:18:20.176,483] <dbg> net_mqtt: mqtt_publish: (0x2001b2b8): [CID 0x2001b5cc]:[State 0x00]: >> Topic size 0x00000015, Data size 0x0000000b
00> [00:18:20.176,544] <dbg> net_mqtt: mqtt_publish: (0x2001b2b8): [CID 0x2001b5cc]:[State 0x00]: << result 0xffffff80
00> [00:18:20.176,574] <inf> slm_mqtt: datamode send: -128
00> [00:18:20.176,574] <wrn> slm_at_host: Raw send failed, 11 dropped
00> [00:18:20.176,605] <inf> slm_at_host: datamode off pending
00> [00:18:20.186,767] <inf> slm_at_host: Exit datamode
