MQTT publish POLLERR error
I'm using nrf9160 MQTT at commands to send real-time data to the cloud. I run into the issue where the MQTT publish may fail (frequency varies around 1 out of 500 publishes). One thread suggests the MQTT fails if the message is too long, however, I don't think this is my case. Any suggestions on how to debug this issue?
Thanks!
Ye-Sheng
The debug message from the modem
This is the working one:
00> [00:18:17.373,504] <inf> slm_at_host: Enter datamode
00> [00:18:17.550,323] <inf> slm_at_host: time limit reached
00> [00:18:17.550,384] <inf> slm_at_host: Raw send 1479
00> [00:18:17.550,415] <dbg> net_mqtt: mqtt_publish: (0x2001b2b8): [CID 0x2001b5cc]:[State 0x06]: >> Topic size 0x00000015, Data size 0x000005c7
00> [00:18:17.550,476] <dbg> net_mqtt_enc: pack_utf8_str: (0x2001b2b8): >> str_size:00000017 cur:0x2001f163, end:0x2001f35e
00> [00:18:17.550,506] <dbg> net_mqtt_enc: pack_uint16: (0x2001b2b8): >> val:0015 cur:0x2001f163, end:0x2001f35e
00> [00:18:17.550,506] <dbg> net_mqtt_enc: mqtt_encode_fixed_header: (0x2001b2b8): << msg type:0x30 length:0x000005de
00> [00:18:17.550,537] <dbg> net_mqtt_enc: packet_length_encode: (0x2001b2b8): >> length:0x000005de cur:(nil), end:(nil)
00> [00:18:17.550,537] <dbg> net_mqtt_enc: mqtt_encode_fixed_header: (0x2001b2b8): Fixed header length = 03
00> [00:18:17.550,537] <dbg> net_mqtt_enc: pack_uint8: (0x2001b2b8): >> val:30 cur:0x2001f160, end:0x2001f35e
00> [00:18:17.550,567] <dbg> net_mqtt_enc: packet_length_encode: (0x2001b2b8): >> length:0x000005de cur:0x2001f161, end:0x2001f35e
00> [00:18:17.550,567] <dbg> net_mqtt: client_write_msg: (0x2001b2b8): [0x2001b5cc]: Transport writing message.
00> [00:18:17.554,443] <dbg> net_mqtt: client_write_msg: (0x2001b2b8): [0x2001b5cc]: Transport write complete.
00> [00:18:17.554,473] <dbg> net_mqtt: mqtt_publish: (0x2001b2b8): [CID 0x2001b5cc]:[State 0x06]: << result 0x00000000
00> [00:18:17.554,504] <inf> slm_mqtt: datamode send: 0
00> [00:18:18.542,633] <inf> slm_at_host: time limit reached
00> [00:18:18.542,724] <inf> slm_at_host: Raw send 1478
00> [00:18:18.542,724] <dbg> net_mqtt: mqtt_publish: (0x2001b2b8): [CID 0x2001b5cc]:[State 0x06]: >> Topic size 0x00000015, Data size 0x000005c6
00> [00:18:18.542,785] <dbg> net_mqtt_enc: pack_utf8_str: (0x2001b2b8): >> str_size:00000017 cur:0x2001f163, end:0x2001f35e
00> [00:18:18.542,816] <dbg> net_mqtt_enc: pack_uint16: (0x2001b2b8): >> val:0015 cur:0x2001f163, end:0x2001f35e
00> [00:18:18.542,816] <dbg> net_mqtt_enc: mqtt_encode_fixed_header: (0x2001b2b8): << msg type:0x30 length:0x000005dd
00> [00:18:18.542,846] <dbg> net_mqtt_enc: packet_length_encode: (0x2001b2b8): >> length:0x000005dd cur:(nil), end:(nil)
00> [00:18:18.542,846] <dbg> net_mqtt_enc: mqtt_encode_fixed_header: (0x2001b2b8): Fixed header length = 03
00> [00:18:18.542,846] <dbg> net_mqtt_enc: pack_uint8: (0x2001b2b8): >> val:30 cur:0x2001f160, end:0x2001f35e
00> [00:18:18.542,877] <dbg> net_mqtt_enc: packet_length_encode: (0x2001b2b8): >> length:0x000005dd cur:0x2001f161, end:0x2001f35e
00> [00:18:18.542,877] <dbg> net_mqtt: client_write_msg: (0x2001b2b8): [0x2001b5cc]: Transport writing message.
00> [00:18:18.546,844] <dbg> net_mqtt: client_write_msg: (0x2001b2b8): [0x2001b5cc]: Transport write complete.
00> [00:18:18.546,875] <dbg> net_mqtt: mqtt_publish: (0x2001b2b8): [CID 0x2001b5cc]:[State 0x06]: << result 0x00000000
00> [00:18:18.546,875] <inf> slm_mqtt: datamode send: 0
00> [00:18:18.546,905] <inf> slm_at_host: datamode off pending
00> [00:18:18.557,098] <inf> slm_at_host: Exit datamode
This is the failed one.
00> [00:18:19.397,705] <inf> slm_at_host: Enter datamode
00> [00:18:19.573,089] <inf> slm_at_host: time limit reached
00> [00:18:19.573,150] <inf> slm_at_host: Raw send 1466
00> [00:18:19.573,150] <dbg> net_mqtt: mqtt_publish: (0x2001b2b8): [CID 0x2001b5cc]:[State 0x06]: >> Topic size 0x00000015, Data size 0x000005ba
00> [00:18:19.573,272] <dbg> net_mqtt_enc: pack_utf8_str: (0x2001b2b8): >> str_size:00000017 cur:0x2001f163, end:0x2001f35e
00> [00:18:19.573,303] <dbg> net_mqtt_enc: pack_uint16: (0x2001b2b8): >> val:0015 cur:0x2001f163, end:0x2001f35e
00> [00:18:19.573,303] <dbg> net_mqtt_enc: mqtt_encode_fixed_header: (0x2001b2b8): << msg type:0x30 length:0x000005d1
00> [00:18:19.573,333] <dbg> net_mqtt_enc: packet_length_encode: (0x2001b2b8): >> length:0x000005d1 cur:(nil), end:(nil)
00> [00:18:19.573,333] <dbg> net_mqtt_enc: mqtt_encode_fixed_header: (0x2001b2b8): Fixed header length = 03
00> [00:18:19.573,333] <dbg> net_mqtt_enc: pack_uint8: (0x2001b2b8): >> val:30 cur:0x2001f160, end:0x2001f35e
00> [00:18:19.573,364] <dbg> net_mqtt_enc: packet_length_encode: (0x2001b2b8): >> length:0x000005d1 cur:0x2001f161, end:0x2001f35e
00> [00:18:19.573,364] <dbg> net_mqtt: client_write_msg: (0x2001b2b8): [0x2001b5cc]: Transport writing message.
00> [00:18:19.577,117] <dbg> net_mqtt: client_write_msg: (0x2001b2b8): [0x2001b5cc]: Transport write complete.
00> [00:18:19.577,148] <dbg> net_mqtt: mqtt_publish: (0x2001b2b8): [CID 0x2001b5cc]:[State 0x06]: << result 0x00000000
00> [00:18:19.577,148] <inf> slm_mqtt: datamode send: 0
00> [00:18:20.137,756] <err> slm_mqtt: POLLERR
00> [00:18:20.137,786] <inf> net_mqtt_sock_tls: Closing socket 0
00> [00:18:20.139,099] <inf> slm_mqtt: MQTT thread terminated
00> [00:18:20.176,391] <inf> slm_at_host: time limit reached
00> [00:18:20.176,452] <inf> slm_at_host: Raw send 11
00> [00:18:20.176,483] <dbg> net_mqtt: mqtt_publish: (0x2001b2b8): [CID 0x2001b5cc]:[State 0x00]: >> Topic size 0x00000015, Data size 0x0000000b
00> [00:18:20.176,544] <dbg> net_mqtt: mqtt_publish: (0x2001b2b8): [CID 0x2001b5cc]:[State 0x00]: << result 0xffffff80
00> [00:18:20.176,574] <inf> slm_mqtt: datamode send: -128
00> [00:18:20.176,574] <wrn> slm_at_host: Raw send failed, 11 dropped
00> [00:18:20.176,605] <inf> slm_at_host: datamode off pending
00> [00:18:20.186,767] <inf> slm_at_host: Exit datamode
  • Hi Charlie,
    Thanks for the suggestion, I'll dig into the log on the server side. In the meantime, I happened to capture one failure with modem log enable.
    00> [00:02:43.936,004] <inf> nrf_modem: Close reason RPC_IP_ERR_NET_DOWN
    I'm not sure how to interpret this message. Does it suggest that the LTE was disconnected by the tower? Also, you're right, the 11 byte was not intended. Our server shouldn't reject any incomplete message. But I'll take a look.
    Ye-Sheng
    00> [00:02:43.348,815] <inf> slm_at_host: Enter datamode
    00> [00:02:43.521,392] <inf> slm_at_host: time limit reached
    00> [00:02:43.521,453] <inf> slm_at_host: Raw send 1435
    00> [00:02:43.521,484] <dbg> net_mqtt: mqtt_publish: (0x20014b38): [CID 0x20014e38]:[State 0x06]: >> Topic size 0x00000015, Data size 0x0000059b
    00> [00:02:43.521,575] <dbg> net_mqtt_enc: pack_utf8_str: (0x20014b38): >> str_size:00000017 cur:0x20019920, end:0x20019b1b
    00> [00:02:43.521,606] <dbg> net_mqtt_enc: pack_uint16: (0x20014b38): >> val:0015 cur:0x20019920, end:0x20019b1b
    00> [00:02:43.521,606] <dbg> net_mqtt_enc: mqtt_encode_fixed_header: (0x20014b38): << msg type:0x30 length:0x000005b2
    00> [00:02:43.521,636] <dbg> net_mqtt_enc: packet_length_encode: (0x20014b38): >> length:0x000005b2 cur:(nil), end:(nil)
    00> [00:02:43.521,636] <dbg> net_mqtt_enc: mqtt_encode_fixed_header: (0x20014b38): Fixed header length = 03
    00> [00:02:43.521,667] <dbg> net_mqtt_enc: pack_uint8: (0x20014b38): >> val:30 cur:0x2001991d, end:0x20019b1b
    00> [00:02:43.521,667] <dbg> net_mqtt_enc: packet_length_encode: (0x20014b38): >> length:0x000005b2 cur:0x2001991e, end:0x20019b1b
    00> [00:02:43.521,697] <dbg> net_mqtt: client_write_msg: (0x20014b38): [0x20014e38]: Transport writing message.
    00> [00:02:43.521,759] <inf> nrf_modem: send() fd 0x0, len 26, blocking
    00> [00:02:43.522,430] <inf> nrf_modem: RPC_IP_SEND_RES fd 0x0, result RPC_IP_ERR_OK
    00> [00:02:43.522,552] <inf> nrf_modem: send() fd 0x0, 26 bytes sent
    00> [00:02:43.522,583] <inf> nrf_modem: send() fd 0x0, len 1435, blocking
    00> [00:02:43.525,177] <inf> nrf_modem: RPC_IP_SEND_RES fd 0x0, result RPC_IP_ERR_OK
    00> [00:02:43.525,329] <inf> nrf_modem: send() fd 0x0, 1435 bytes sent
    00> [00:02:43.525,360] <dbg> net_mqtt: client_write_msg: (0x20014b38): [0x20014e38]: Transport write complete.
    00> [00:02:43.525,390] <dbg> net_mqtt: mqtt_publish: (0x20014b38): [CID 0x20014e38]:[State 0x06]: << result 0x00000000
    00> [00:02:43.525,390] <inf> slm_mqtt: datamode send: 0
    00> [00:02:43.935,974] <inf> nrf_modem: RPC_IP_CLOSED_NTF fd 0x0
    00> [00:02:43.936,096] <err> slm_mqtt: POLLERR
    00> [00:02:43.936,096] <inf> net_mqtt_sock_tls: Closing socket 0
    00> [00:02:43.936,126] <inf> nrf_modem: close() fd 0x0
    00> [00:02:43.937,194] <inf> nrf_modem: RPC_IP_CLOSE_RES fd 0x0, result RPC_IP_ERR_OK
    00> [00:02:43.937,377] <inf> slm_mqtt: MQTT thread terminated
    00> [00:02:43.974,700] <inf> slm_at_host: time limit reached
    00> [00:02:43.974,761] <inf> slm_at_host: Raw send 11
    00> [00:02:43.974,792] <dbg> net_mqtt: mqtt_publish: (0x20014b38): [CID 0x20014e38]:[State 0x00]: >> Topic size 0x00000015, Data size 0x0000000b
    00> [00:02:43.974,884] <dbg> net_mqtt: mqtt_publish: (0x20014b38): [CID 0x20014e38]:[State 0x00]: << result 0xffffff80
    00> [00:02:43.974,914] <inf> slm_mqtt: datamode send: -128
    00> [00:02:43.974,945] <wrn> slm_at_host: Raw send failed, 11 dropped
    00> [00:02:43.975,585] <inf> slm_at_host: Exit datamode
  • Hi Ye-Sheng,
    Yes, it indicates that the device has lost LTE connection, but this can be a totally normal event since we did not see failure happen in the modem trace.
    This can happen when the device “moves” from one cell to another or on the edge of cells. Have you tested on other places?
    Charlie
  • How were you able to solve this problem, could please share some insights? I am having exactly the same problem, described in this ticket (Case ID: 328895).
