Hey, Varshil here,
I got an error while build the Light Bulb example code of Matter SDK.
When I am builds that code without any changes at that time builds successfully work.
But I added Matter temperature Sensor (0x0302) and in that add On Off cluster and generate in ZAP Generated folder of Light Bulb with the help of ZAP-Tool.
I got a Below Error.
------> Below is the logs of Terminal when I am building Light Bulb Example code.
In file included from C:\ncs\v2.4.0\modules\lib\matter\src\app\util\config.h:31, from C:\ncs\v2.4.0\modules\lib\matter\src\app\util\af.h:23, from C:\ncs\v2.4.0\modules\lib\matter\src\app\util\common.h:21, from C:\ncs\v2.4.0\modules\lib\matter\src\app\util\attribute-storage.cpp:18: c:\ncs\v2.4.0\nrf\samples\matter\DHT11_Matter_Varshil\src\zap-generated\endpoint_config.h:217:29: error: exponent has no digits 217 | #define ATTRIBUTE_MAX_SIZE (16ERROR: DeviceTypeList, invalid size, arrayERROR: ServerList, invalid size, arrayERROR: ClientList, invalid size, arrayERROR: PartsList, invalid size, array422224222242) | ^~~~~~~ C:\ncs\v2.4.0\modules\lib\matter\src\app\util\attribute-storage.cpp:50:6: note: in expansion of macro 'ATTRIBUTE_MAX_SIZE' 50 | #if (ATTRIBUTE_MAX_SIZE == 0) | ^~~~~~~~~~~~~~~~~~ c:\ncs\v2.4.0\nrf\samples\matter\DHT11_Matter_Varshil\src\zap-generated\endpoint_config.h:217:36: error: ':' without preceding '?' 217 | #define ATTRIBUTE_MAX_SIZE (16ERROR: DeviceTypeList, invalid size, arrayERROR: ServerList, invalid size, arrayERROR: ClientList, invalid size, arrayERROR: PartsList, invalid size, array422224222242) | ^ C:\ncs\v2.4.0\modules\lib\matter\src\app\util\attribute-storage.cpp:50:6: note: in expansion of macro 'ATTRIBUTE_MAX_SIZE' 50 | #if (ATTRIBUTE_MAX_SIZE == 0) | ^~~~~~~~~~~~~~~~~~ c:\ncs\v2.4.0\nrf\samples\matter\DHT11_Matter_Varshil\src\zap-generated\endpoint_config.h:217:29: error: exponent has no digits 217 | #define ATTRIBUTE_MAX_SIZE (16ERROR: DeviceTypeList, invalid size, arrayERROR: ServerList, invalid size, arrayERROR: ClientList, invalid size, arrayERROR: PartsList, invalid size, array422224222242) | ^~~~~~~ C:\ncs\v2.4.0\modules\lib\matter\src\app\util\attribute-storage.cpp:53:31: note: in expansion of macro 'ATTRIBUTE_MAX_SIZE' 53 | #define ACTUAL_ATTRIBUTE_SIZE ATTRIBUTE_MAX_SIZE | ^~~~~~~~~~~~~~~~~~ C:\ncs\v2.4.0\modules\lib\matter\src\app\util\attribute-storage.cpp:56:23: note: in expansion of macro 'ACTUAL_ATTRIBUTE_SIZE' 56 | uint8_t attributeData[ACTUAL_ATTRIBUTE_SIZE]; | ^~~~~~~~~~~~~~~~~~~~~ c:\ncs\v2.4.0\nrf\samples\matter\DHT11_Matter_Varshil\src\zap-generated\endpoint_config.h:160:22: error: exponent has no digits 160 | .clusterSize = 0ERROR: DeviceTypeList, invalid size, arrayERROR: ServerList, invalid size, arrayERROR: ClientList, invalid size, arrayERROR: PartsList, invalid size, array42, \ | ^~~~~~ C:\ncs\v2.4.0\modules\lib\matter\src\app\util\attribute-storage.cpp:104:54: note: in expansion of macro 'GENERATED_CLUSTERS' 104 | constexpr const EmberAfCluster generatedClusters[] = GENERATED_CLUSTERS; | ^~~~~~~~~~~~~~~~~~ c:\ncs\v2.4.0\nrf\samples\matter\DHT11_Matter_Varshil\src\zap-generated\endpoint_config.h:202:30: error: exponent has no digits 202 | { ZAP_CLUSTER_INDEX(0), 5, 160ERROR: DeviceTypeList, invalid size, arrayERROR: ServerList, invalid size, arrayERROR: ClientList, invalid size, arrayERROR: PartsList, invalid size, array421212 }, \ | ^~~~~~~~ C:\ncs\v2.4.0\modules\lib\matter\src\app\util\attribute-storage.cpp:107:71: note: in expansion of macro 'GENERATED_ENDPOINT_TYPES' 107 | constexpr const EmberAfEndpointType generatedEmberAfEndpointTypes[] = GENERATED_ENDPOINT_TYPES; | ^~~~~~~~~~~~~~~~~~~~~~~~ c:\ncs\v2.4.0\nrf\samples\matter\DHT11_Matter_Varshil\src\zap-generated\endpoint_config.h:217:36: error: expected ')' before ':' token 217 | #define ATTRIBUTE_MAX_SIZE (16ERROR: DeviceTypeList, invalid size, arrayERROR: ServerList, invalid size, arrayERROR: ClientList, invalid size, arrayERROR: PartsList, invalid size, array422224222242) | ~ ^ C:\ncs\v2.4.0\modules\lib\matter\src\app\util\attribute-storage.cpp:53:31: note: in expansion of macro 'ATTRIBUTE_MAX_SIZE' 53 | #define ACTUAL_ATTRIBUTE_SIZE ATTRIBUTE_MAX_SIZE | ^~~~~~~~~~~~~~~~~~ C:\ncs\v2.4.0\modules\lib\matter\src\app\util\attribute-storage.cpp:56:23: note: in expansion of macro 'ACTUAL_ATTRIBUTE_SIZE' 56 | uint8_t attributeData[ACTUAL_ATTRIBUTE_SIZE]; | ^~~~~~~~~~~~~~~~~~~~~ C:\ncs\v2.4.0\modules\lib\matter\src\app\util\attribute-storage.cpp:56:45: error: expected ']' before ';' token 56 | uint8_t attributeData[ACTUAL_ATTRIBUTE_SIZE]; | ^ | ] c:\ncs\v2.4.0\nrf\samples\matter\DHT11_Matter_Varshil\src\zap-generated\endpoint_config.h:65:45: error: 'DeviceTypeList' was not declared in this scope; did you mean 'chip::app::Clusters::Descriptor::Attributes::DeviceTypeList'? 65 | { ZAP_EMPTY_DEFAULT(), 0x00000000, ERROR: DeviceTypeList, invalid size, array, ZAP_TYPE(ARRAY), 0 }, /* DeviceTypeList */ \ | ^~~~~~~~~~~~~~ C:\ncs\v2.4.0\modules\lib\matter\src\app\util\attribute-storage.cpp:101:66: note: in expansion of macro 'GENERATED_ATTRIBUTES' 101 | constexpr const EmberAfAttributeMetadata generatedAttributes[] = GENERATED_ATTRIBUTES; | ^~~~~~~~~~~~~~~~~~~~ c:\ncs\v2.4.0\nrf\samples\matter\DHT11_Matter_Varshil\src\zap-generated\endpoint_config.h:65:45: note: maximum limit of 1000 namespaces searched for 'DeviceTypeList' 65 | { ZAP_EMPTY_DEFAULT(), 0x00000000, ERROR: DeviceTypeList, invalid size, array, ZAP_TYPE(ARRAY), 0 }, /* DeviceTypeList */ \ | ^~~~~~~~~~~~~~ C:\ncs\v2.4.0\modules\lib\matter\src\app\util\attribute-storage.cpp:101:66: note: in expansion of macro 'GENERATED_ATTRIBUTES' 101 | constexpr const EmberAfAttributeMetadata generatedAttributes[] = GENERATED_ATTRIBUTES; | ^~~~~~~~~~~~~~~~~~~~ In file included from C:\ncs\v2.4.0\modules\lib\matter\zzz_generated\app-common\app-common\zap-generated\cluster-objects.h:23, from C:\ncs\v2.4.0\modules\lib\matter\src\include\platform\ConfigurationManager.h:34, from C:\ncs\v2.4.0\modules\lib\matter\src\include\platform\CHIPDeviceLayer.h:27, from C:\ncs\v2.4.0\modules\lib\matter\src\app\util\attribute-storage.h:26, from C:\ncs\v2.4.0\modules\lib\matter\src\app\util\common.h:22: C:\ncs\v2.4.0\modules\lib\matter\zzz_generated\app-common\app-common\zap-generated\ids\Attributes.h:457:11: note: 'chip::app::Clusters::Descriptor::Attributes::DeviceTypeList' declared here 457 | namespace DeviceTypeList { | ^~~~~~~~~~~~~~ c:\ncs\v2.4.0\nrf\samples\matter\DHT11_Matter_Varshil\src\zap-generated\endpoint_config.h:65:61: error: 'invalid' was not declared in this scope 65 | { ZAP_EMPTY_DEFAULT(), 0x00000000, ERROR: DeviceTypeList, invalid size, array, ZAP_TYPE(ARRAY), 0 }, /* DeviceTypeList */ \ | ^~~~~~~ C:\ncs\v2.4.0\modules\lib\matter\src\app\util\attribute-storage.cpp:101:66: note: in expansion of macro 'GENERATED_ATTRIBUTES' 101 | constexpr const EmberAfAttributeMetadata generatedAttributes[] = GENERATED_ATTRIBUTES; | ^~~~~~~~~~~~~~~~~~~~ c:\ncs\v2.4.0\nrf\samples\matter\DHT11_Matter_Varshil\src\zap-generated\endpoint_config.h:65:61: note: maximum limit of 1000 namespaces searched for 'invalid' 65 | { ZAP_EMPTY_DEFAULT(), 0x00000000, ERROR: DeviceTypeList, invalid size, array, ZAP_TYPE(ARRAY), 0 }, /* DeviceTypeList */ \ | ^~~~~~~ C:\ncs\v2.4.0\modules\lib\matter\src\app\util\attribute-storage.cpp:101:66: note: in expansion of macro 'GENERATED_ATTRIBUTES' 101 | constexpr const EmberAfAttributeMetadata generatedAttributes[] = GENERATED_ATTRIBUTES; | ^~~~~~~~~~~~~~~~~~~~ c:\ncs\v2.4.0\nrf\samples\matter\DHT11_Matter_Varshil\src\zap-generated\endpoint_config.h:65:69: error: expected '}' before 'size' 65 | { ZAP_EMPTY_DEFAULT(), 0x00000000, ERROR: DeviceTypeList, invalid size, array, ZAP_TYPE(ARRAY), 0 }, /* DeviceTypeList */ \ | ~ ^~~~ C:\ncs\v2.4.0\modules\lib\matter\src\app\util\attribute-storage.cpp:101:66: note: in expansion of macro 'GENERATED_ATTRIBUTES' 101 | constexpr const EmberAfAttributeMetadata generatedAttributes[] = GENERATED_ATTRIBUTES; | ^~~~~~~~~~~~~~~~~~~~ c:\ncs\v2.4.0\nrf\samples\matter\DHT11_Matter_Varshil\src\zap-generated\endpoint_config.h:65:69: error: expected '}' before 'size' 65 | { ZAP_EMPTY_DEFAULT(), 0x00000000, ERROR: DeviceTypeList, invalid size, array, ZAP_TYPE(ARRAY), 0 }, /* DeviceTypeList */ \ | ^~~~ C:\ncs\v2.4.0\modules\lib\matter\src\app\util\attribute-storage.cpp:101:66: note: in expansion of macro 'GENERATED_ATTRIBUTES' 101 | constexpr const EmberAfAttributeMetadata generatedAttributes[] = GENERATED_ATTRIBUTES; | ^~~~~~~~~~~~~~~~~~~~ c:\ncs\v2.4.0\nrf\samples\matter\DHT11_Matter_Varshil\src\zap-generated\endpoint_config.h:51:30: note: to match this '{' 51 | #define GENERATED_ATTRIBUTES { \ | ^ C:\ncs\v2.4.0\modules\lib\matter\src\app\util\attribute-storage.cpp:101:66: note: in expansion of macro 'GENERATED_ATTRIBUTES' 101 | constexpr const EmberAfAttributeMetadata generatedAttributes[] = GENERATED_ATTRIBUTES; | ^~~~~~~~~~~~~~~~~~~~ c:\ncs\v2.4.0\nrf\samples\matter\DHT11_Matter_Varshil\src\zap-generated\endpoint_config.h:65:69: error: 'const EmberAfAttributeMetadata' has no non-static data member named 'ERROR' 65 | { ZAP_EMPTY_DEFAULT(), 0x00000000, ERROR: DeviceTypeList, invalid size, array, ZAP_TYPE(ARRAY), 0 }, /* DeviceTypeList */ \ | ^~~~ C:\ncs\v2.4.0\modules\lib\matter\src\app\util\attribute-storage.cpp:101:66: note: in expansion of macro 'GENERATED_ATTRIBUTES' 101 | constexpr const EmberAfAttributeMetadata generatedAttributes[] = GENERATED_ATTRIBUTES; | ^~~~~~~~~~~~~~~~~~~~ c:\ncs\v2.4.0\nrf\samples\matter\DHT11_Matter_Varshil\src\zap-generated\endpoint_config.h:65:102: error: expected unqualified-id before ',' token 65 | { ZAP_EMPTY_DEFAULT(), 0x00000000, ERROR: DeviceTypeList, invalid size, array, ZAP_TYPE(ARRAY), 0 }, /* DeviceTypeList */ \ | ^ C:\ncs\v2.4.0\modules\lib\matter\src\app\util\attribute-storage.cpp:101:66: note: in expansion of macro 'GENERATED_ATTRIBUTES' 101 | constexpr const EmberAfAttributeMetadata generatedAttributes[] = GENERATED_ATTRIBUTES; | ^~~~~~~~~~~~~~~~~~~~ c:\ncs\v2.4.0\nrf\samples\matter\DHT11_Matter_Varshil\src\zap-generated\endpoint_config.h:66:3: error: expected unqualified-id before '{' token 66 | { ZAP_EMPTY_DEFAULT(), 0x00000001, ERROR: ServerList, invalid size, array, ZAP_TYPE(ARRAY), 0 }, /* ServerList */ \ | ^ C:\ncs\v2.4.0\modules\lib\matter\src\app\util\attribute-storage.cpp:101:66: note: in expansion of macro 'GENERATED_ATTRIBUTES' 101 | constexpr const EmberAfAttributeMetadata generatedAttributes[] = GENERATED_ATTRIBUTES; | ^~~~~~~~~~~~~~~~~~~~ c:\ncs\v2.4.0\nrf\samples\matter\DHT11_Matter_Varshil\src\zap-generated\endpoint_config.h:66:98: error: expected unqualified-id before ',' token 66 | { ZAP_EMPTY_DEFAULT(), 0x00000001, ERROR: ServerList, invalid size, array, ZAP_TYPE(ARRAY), 0 }, /* ServerList */ \ | ^ C:\ncs\v2.4.0\modules\lib\matter\src\app\util\attribute-storage.cpp:101:66: note: in expansion of macro 'GENERATED_ATTRIBUTES' 101 | constexpr const EmberAfAttributeMetadata generatedAttributes[] = GENERATED_ATTRIBUTES; | ^~~~~~~~~~~~~~~~~~~~ c:\ncs\v2.4.0\nrf\samples\matter\DHT11_Matter_Varshil\src\zap-generated\endpoint_config.h:67:3: error: expected unqualified-id before '{' token 67 | { ZAP_EMPTY_DEFAULT(), 0x00000002, ERROR: ClientList, invalid size, array, ZAP_TYPE(ARRAY), 0 }, /* ClientList */ \ | ^ C:\ncs\v2.4.0\modules\lib\matter\src\app\util\attribute-storage.cpp:101:66: note: in expansion of macro 'GENERATED_ATTRIBUTES' 101 | constexpr const EmberAfAttributeMetadata generatedAttributes[] = GENERATED_ATTRIBUTES; | ^~~~~~~~~~~~~~~~~~~~ c:\ncs\v2.4.0\nrf\samples\matter\DHT11_Matter_Varshil\src\zap-generated\endpoint_config.h:67:98: error: expected unqualified-id before ',' token 67 | { ZAP_EMPTY_DEFAULT(), 0x00000002, ERROR: ClientList, invalid size, array, ZAP_TYPE(ARRAY), 0 }, /* ClientList */ \ | ^ C:\ncs\v2.4.0\modules\lib\matter\src\app\util\attribute-storage.cpp:101:66: note: in expansion of macro 'GENERATED_ATTRIBUTES' 101 | constexpr const EmberAfAttributeMetadata generatedAttributes[] = GENERATED_ATTRIBUTES; | ^~~~~~~~~~~~~~~~~~~~ c:\ncs\v2.4.0\nrf\samples\matter\DHT11_Matter_Varshil\src\zap-generated\endpoint_config.h:68:3: error: expected unqualified-id before '{' token 68 | { ZAP_EMPTY_DEFAULT(), 0x00000003, ERROR: PartsList, invalid size, array, ZAP_TYPE(ARRAY), 0 }, /* PartsList */ \ | ^ C:\ncs\v2.4.0\modules\lib\matter\src\app\util\attribute-storage.cpp:101:66: note: in expansion of macro 'GENERATED_ATTRIBUTES' 101 | constexpr const EmberAfAttributeMetadata generatedAttributes[] = GENERATED_ATTRIBUTES; | ^~~~~~~~~~~~~~~~~~~~ c:\ncs\v2.4.0\nrf\samples\matter\DHT11_Matter_Varshil\src\zap-generated\endpoint_config.h:68:97: error: expected unqualified-id before ',' token 68 | { ZAP_EMPTY_DEFAULT(), 0x00000003, ERROR: PartsList, invalid size, array, ZAP_TYPE(ARRAY), 0 }, /* PartsList */ \ | ^ C:\ncs\v2.4.0\modules\lib\matter\src\app\util\attribute-storage.cpp:101:66: note: in expansion of macro 'GENERATED_ATTRIBUTES' 101 | constexpr const EmberAfAttributeMetadata generatedAttributes[] = GENERATED_ATTRIBUTES; | ^~~~~~~~~~~~~~~~~~~~ c:\ncs\v2.4.0\nrf\samples\matter\DHT11_Matter_Varshil\src\zap-generated\endpoint_config.h:69:3: error: expected unqualified-id before '{' token 69 | { ZAP_SIMPLE_DEFAULT(0), 0x0000FFFC, 4, ZAP_TYPE(BITMAP32), 0 }, /* FeatureMap */ \ | ^ C:\ncs\v2.4.0\modules\lib\matter\src\app\util\attribute-storage.cpp:101:66: note: in expansion of macro 'GENERATED_ATTRIBUTES' 101 | constexpr const EmberAfAttributeMetadata generatedAttributes[] = GENERATED_ATTRIBUTES; | ^~~~~~~~~~~~~~~~~~~~ c:\ncs\v2.4.0\nrf\samples\matter\DHT11_Matter_Varshil\src\zap-generated\endpoint_config.h:69:66: error: expected unqualified-id before ',' token 69 | { ZAP_SIMPLE_DEFAULT(0), 0x0000FFFC, 4, ZAP_TYPE(BITMAP32), 0 }, /* FeatureMap */ \ | ^ C:\ncs\v2.4.0\modules\lib\matter\src\app\util\attribute-storage.cpp:101:66: note: in expansion of macro 'GENERATED_ATTRIBUTES' 101 | constexpr const EmberAfAttributeMetadata generatedAttributes[] = GENERATED_ATTRIBUTES; | ^~~~~~~~~~~~~~~~~~~~ c:\ncs\v2.4.0\nrf\samples\matter\DHT11_Matter_Varshil\src\zap-generated\endpoint_config.h:70:3: error: expected unqualified-id before '{' token 70 | { ZAP_SIMPLE_DEFAULT(1), 0x0000FFFD, 2, ZAP_TYPE(INT16U), 0 }, /* ClusterRevision */ \ | ^ C:\ncs\v2.4.0\modules\lib\matter\src\app\util\attribute-storage.cpp:101:66: note: in expansion of macro 'GENERATED_ATTRIBUTES' 101 | constexpr const EmberAfAttributeMetadata generatedAttributes[] = GENERATED_ATTRIBUTES; | ^~~~~~~~~~~~~~~~~~~~ c:\ncs\v2.4.0\nrf\samples\matter\DHT11_Matter_Varshil\src\zap-generated\endpoint_config.h:70:64: error: expected unqualified-id before ',' token 70 | { ZAP_SIMPLE_DEFAULT(1), 0x0000FFFD, 2, ZAP_TYPE(INT16U), 0 }, /* ClusterRevision */ \ | ^ C:\ncs\v2.4.0\modules\lib\matter\src\app\util\attribute-storage.cpp:101:66: note: in expansion of macro 'GENERATED_ATTRIBUTES' 101 | constexpr const EmberAfAttributeMetadata generatedAttributes[] = GENERATED_ATTRIBUTES; | ^~~~~~~~~~~~~~~~~~~~ c:\ncs\v2.4.0\nrf\samples\matter\DHT11_Matter_Varshil\src\zap-generated\endpoint_config.h:73:3: error: expected unqualified-id before '{' token 73 | { ZAP_EMPTY_DEFAULT(), 0x00000000, 2, ZAP_TYPE(INT16S), ZAP_ATTRIBUTE_MASK(NULLABLE) }, /* MeasuredValue */ \ | ^ C:\ncs\v2.4.0\modules\lib\matter\src\app\util\attribute-storage.cpp:101:66: note: in expansion of macro 'GENERATED_ATTRIBUTES' 101 | constexpr const EmberAfAttributeMetadata generatedAttributes[] = GENERATED_ATTRIBUTES; | ^~~~~~~~~~~~~~~~~~~~ c:\ncs\v2.4.0\nrf\samples\matter\DHT11_Matter_Varshil\src\zap-generated\endpoint_config.h:73:89: error: expected unqualified-id before ',' token 73 | { ZAP_EMPTY_DEFAULT(), 0x00000000, 2, ZAP_TYPE(INT16S), ZAP_ATTRIBUTE_MASK(NULLABLE) }, /* MeasuredValue */ \ | ^ C:\ncs\v2.4.0\modules\lib\matter\src\app\util\attribute-storage.cpp:101:66: note: in expansion of macro 'GENERATED_ATTRIBUTES' 101 | constexpr const EmberAfAttributeMetadata generatedAttributes[] = GENERATED_ATTRIBUTES; | ^~~~~~~~~~~~~~~~~~~~ c:\ncs\v2.4.0\nrf\samples\matter\DHT11_Matter_Varshil\src\zap-generated\endpoint_config.h:74:3: error: expected unqualified-id before '{' token 74 | { ZAP_SIMPLE_DEFAULT(0x8000), 0x00000001, 2, ZAP_TYPE(INT16S), ZAP_ATTRIBUTE_MASK(NULLABLE) }, /* MinMeasuredValue */ \ | ^ C:\ncs\v2.4.0\modules\lib\matter\src\app\util\attribute-storage.cpp:101:66: note: in expansion of macro 'GENERATED_ATTRIBUTES' 101 | constexpr const EmberAfAttributeMetadata generatedAttributes[] = GENERATED_ATTRIBUTES; | ^~~~~~~~~~~~~~~~~~~~ c:\ncs\v2.4.0\nrf\samples\matter\DHT11_Matter_Varshil\src\zap-generated\endpoint_config.h:74:96: error: expected unqualified-id before ',' token 74 | { ZAP_SIMPLE_DEFAULT(0x8000), 0x00000001, 2, ZAP_TYPE(INT16S), ZAP_ATTRIBUTE_MASK(NULLABLE) }, /* MinMeasuredValue */ \ | ^ C:\ncs\v2.4.0\modules\lib\matter\src\app\util\attribute-storage.cpp:101:66: note: in expansion of macro 'GENERATED_ATTRIBUTES' 101 | constexpr const EmberAfAttributeMetadata generatedAttributes[] = GENERATED_ATTRIBUTES; | ^~~~~~~~~~~~~~~~~~~~ c:\ncs\v2.4.0\nrf\samples\matter\DHT11_Matter_Varshil\src\zap-generated\endpoint_config.h:75:3: error: expected unqualified-id before '{' token 75 | { ZAP_SIMPLE_DEFAULT(0x8000), 0x00000002, 2, ZAP_TYPE(INT16S), ZAP_ATTRIBUTE_MASK(NULLABLE) }, /* MaxMeasuredValue */ \ | ^ C:\ncs\v2.4.0\modules\lib\matter\src\app\util\attribute-storage.cpp:101:66: note: in expansion of macro 'GENERATED_ATTRIBUTES' 101 | constexpr const EmberAfAttributeMetadata generatedAttributes[] = GENERATED_ATTRIBUTES; | ^~~~~~~~~~~~~~~~~~~~ c:\ncs\v2.4.0\nrf\samples\matter\DHT11_Matter_Varshil\src\zap-generated\endpoint_config.h:75:96: error: expected unqualified-id before ',' token 75 | { ZAP_SIMPLE_DEFAULT(0x8000), 0x00000002, 2, ZAP_TYPE(INT16S), ZAP_ATTRIBUTE_MASK(NULLABLE) }, /* MaxMeasuredValue */ \ | ^ C:\ncs\v2.4.0\modules\lib\matter\src\app\util\attribute-storage.cpp:101:66: note: in expansion of macro 'GENERATED_ATTRIBUTES' 101 | constexpr const EmberAfAttributeMetadata generatedAttributes[] = GENERATED_ATTRIBUTES; | ^~~~~~~~~~~~~~~~~~~~ c:\ncs\v2.4.0\nrf\samples\matter\DHT11_Matter_Varshil\src\zap-generated\endpoint_config.h:76:3: error: expected unqualified-id before '{' token 76 | { ZAP_SIMPLE_DEFAULT(0), 0x0000FFFC, 4, ZAP_TYPE(BITMAP32), 0 }, /* FeatureMap */ \ | ^ C:\ncs\v2.4.0\modules\lib\matter\src\app\util\attribute-storage.cpp:101:66: note: in expansion of macro 'GENERATED_ATTRIBUTES' 101 | constexpr const EmberAfAttributeMetadata generatedAttributes[] = GENERATED_ATTRIBUTES; | ^~~~~~~~~~~~~~~~~~~~ c:\ncs\v2.4.0\nrf\samples\matter\DHT11_Matter_Varshil\src\zap-generated\endpoint_config.h:76:66: error: expected unqualified-id before ',' token 76 | { ZAP_SIMPLE_DEFAULT(0), 0x0000FFFC, 4, ZAP_TYPE(BITMAP32), 0 }, /* FeatureMap */ \ | ^ C:\ncs\v2.4.0\modules\lib\matter\src\app\util\attribute-storage.cpp:101:66: note: in expansion of macro 'GENERATED_ATTRIBUTES' 101 | constexpr const EmberAfAttributeMetadata generatedAttributes[] = GENERATED_ATTRIBUTES; | ^~~~~~~~~~~~~~~~~~~~ c:\ncs\v2.4.0\nrf\samples\matter\DHT11_Matter_Varshil\src\zap-generated\endpoint_config.h:77:3: error: expected unqualified-id before '{' token 77 | { ZAP_SIMPLE_DEFAULT(1), 0x0000FFFD, 2, ZAP_TYPE(INT16U), 0 }, /* ClusterRevision */ \ | ^ C:\ncs\v2.4.0\modules\lib\matter\src\app\util\attribute-storage.cpp:101:66: note: in expansion of macro 'GENERATED_ATTRIBUTES' 101 | constexpr const EmberAfAttributeMetadata generatedAttributes[] = GENERATED_ATTRIBUTES; | ^~~~~~~~~~~~~~~~~~~~ c:\ncs\v2.4.0\nrf\samples\matter\DHT11_Matter_Varshil\src\zap-generated\endpoint_config.h:77:64: error: expected unqualified-id before ',' token 77 | { ZAP_SIMPLE_DEFAULT(1), 0x0000FFFD, 2, ZAP_TYPE(INT16U), 0 }, /* ClusterRevision */ \ | ^ C:\ncs\v2.4.0\modules\lib\matter\src\app\util\attribute-storage.cpp:101:66: note: in expansion of macro 'GENERATED_ATTRIBUTES' 101 | constexpr const EmberAfAttributeMetadata generatedAttributes[] = GENERATED_ATTRIBUTES; | ^~~~~~~~~~~~~~~~~~~~ c:\ncs\v2.4.0\nrf\samples\matter\DHT11_Matter_Varshil\src\zap-generated\endpoint_config.h:80:3: error: expected unqualified-id before '{' token 80 | { ZAP_EMPTY_DEFAULT(), 0x00000000, 2, ZAP_TYPE(INT16U), ZAP_ATTRIBUTE_MASK(NULLABLE) }, /* MeasuredValue */ \ | ^ C:\ncs\v2.4.0\modules\lib\matter\src\app\util\attribute-storage.cpp:101:66: note: in expansion of macro 'GENERATED_ATTRIBUTES' 101 | constexpr const EmberAfAttributeMetadata generatedAttributes[] = GENERATED_ATTRIBUTES; | ^~~~~~~~~~~~~~~~~~~~ c:\ncs\v2.4.0\nrf\samples\matter\DHT11_Matter_Varshil\src\zap-generated\endpoint_config.h:80:89: error: expected unqualified-id before ',' token 80 | { ZAP_EMPTY_DEFAULT(), 0x00000000, 2, ZAP_TYPE(INT16U), ZAP_ATTRIBUTE_MASK(NULLABLE) }, /* MeasuredValue */ \ | ^ C:\ncs\v2.4.0\modules\lib\matter\src\app\util\attribute-storage.cpp:101:66: note: in expansion of macro 'GENERATED_ATTRIBUTES' 101 | constexpr const EmberAfAttributeMetadata generatedAttributes[] = GENERATED_ATTRIBUTES; | ^~~~~~~~~~~~~~~~~~~~ c:\ncs\v2.4.0\nrf\samples\matter\DHT11_Matter_Varshil\src\zap-generated\endpoint_config.h:81:3: error: expected unqualified-id before '{' token 81 | { ZAP_EMPTY_DEFAULT(), 0x00000001, 2, ZAP_TYPE(INT16U), ZAP_ATTRIBUTE_MASK(NULLABLE) }, /* MinMeasuredValue */ \ | ^ C:\ncs\v2.4.0\modules\lib\matter\src\app\util\attribute-storage.cpp:101:66: note: in expansion of macro 'GENERATED_ATTRIBUTES' 101 | constexpr const EmberAfAttributeMetadata generatedAttributes[] = GENERATED_ATTRIBUTES; | ^~~~~~~~~~~~~~~~~~~~ c:\ncs\v2.4.0\nrf\samples\matter\DHT11_Matter_Varshil\src\zap-generated\endpoint_config.h:81:89: error: expected unqualified-id before ',' token 81 | { ZAP_EMPTY_DEFAULT(), 0x00000001, 2, ZAP_TYPE(INT16U), ZAP_ATTRIBUTE_MASK(NULLABLE) }, /* MinMeasuredValue */ \ | ^ C:\ncs\v2.4.0\modules\lib\matter\src\app\util\attribute-storage.cpp:101:66: note: in expansion of macro 'GENERATED_ATTRIBUTES' 101 | constexpr const EmberAfAttributeMetadata generatedAttributes[] = GENERATED_ATTRIBUTES; | ^~~~~~~~~~~~~~~~~~~~ c:\ncs\v2.4.0\nrf\samples\matter\DHT11_Matter_Varshil\src\zap-generated\endpoint_config.h:82:3: error: expected unqualified-id before '{' token 82 | { ZAP_EMPTY_DEFAULT(), 0x00000002, 2, ZAP_TYPE(INT16U), ZAP_ATTRIBUTE_MASK(NULLABLE) }, /* MaxMeasuredValue */ \ | ^ C:\ncs\v2.4.0\modules\lib\matter\src\app\util\attribute-storage.cpp:101:66: note: in expansion of macro 'GENERATED_ATTRIBUTES' 101 | constexpr const EmberAfAttributeMetadata generatedAttributes[] = GENERATED_ATTRIBUTES; | ^~~~~~~~~~~~~~~~~~~~ c:\ncs\v2.4.0\nrf\samples\matter\DHT11_Matter_Varshil\src\zap-generated\endpoint_config.h:82:89: error: expected unqualified-id before ',' token 82 | { ZAP_EMPTY_DEFAULT(), 0x00000002, 2, ZAP_TYPE(INT16U), ZAP_ATTRIBUTE_MASK(NULLABLE) }, /* MaxMeasuredValue */ \ | ^ C:\ncs\v2.4.0\modules\lib\matter\src\app\util\attribute-storage.cpp:101:66: note: in expansion of macro 'GENERATED_ATTRIBUTES' 101 | constexpr const EmberAfAttributeMetadata generatedAttributes[] = GENERATED_ATTRIBUTES; | ^~~~~~~~~~~~~~~~~~~~ c:\ncs\v2.4.0\nrf\samples\matter\DHT11_Matter_Varshil\src\zap-generated\endpoint_config.h:83:3: error: expected unqualified-id before '{' token 83 | { ZAP_SIMPLE_DEFAULT(0), 0x0000FFFC, 4, ZAP_TYPE(BITMAP32), 0 }, /* FeatureMap */ \ | ^ C:\ncs\v2.4.0\modules\lib\matter\src\app\util\attribute-storage.cpp:101:66: note: in expansion of macro 'GENERATED_ATTRIBUTES' 101 | constexpr const EmberAfAttributeMetadata generatedAttributes[] = GENERATED_ATTRIBUTES; | ^~~~~~~~~~~~~~~~~~~~ c:\ncs\v2.4.0\nrf\samples\matter\DHT11_Matter_Varshil\src\zap-generated\endpoint_config.h:83:66: error: expected unqualified-id before ',' token 83 | { ZAP_SIMPLE_DEFAULT(0), 0x0000FFFC, 4, ZAP_TYPE(BITMAP32), 0 }, /* FeatureMap */ \ | ^ C:\ncs\v2.4.0\modules\lib\matter\src\app\util\attribute-storage.cpp:101:66: note: in expansion of macro 'GENERATED_ATTRIBUTES' 101 | constexpr const EmberAfAttributeMetadata generatedAttributes[] = GENERATED_ATTRIBUTES; | ^~~~~~~~~~~~~~~~~~~~ c:\ncs\v2.4.0\nrf\samples\matter\DHT11_Matter_Varshil\src\zap-generated\endpoint_config.h:84:3: error: expected unqualified-id before '{' token 84 | { ZAP_SIMPLE_DEFAULT(3), 0x0000FFFD, 2, ZAP_TYPE(INT16U), 0 }, /* ClusterRevision */ \ | ^ C:\ncs\v2.4.0\modules\lib\matter\src\app\util\attribute-storage.cpp:101:66: note: in expansion of macro 'GENERATED_ATTRIBUTES' 101 | constexpr const EmberAfAttributeMetadata generatedAttributes[] = GENERATED_ATTRIBUTES; | ^~~~~~~~~~~~~~~~~~~~ c:\ncs\v2.4.0\nrf\samples\matter\DHT11_Matter_Varshil\src\zap-generated\endpoint_config.h:84:64: error: expected unqualified-id before ',' token 84 | { ZAP_SIMPLE_DEFAULT(3), 0x0000FFFD, 2, ZAP_TYPE(INT16U), 0 }, /* ClusterRevision */ \ | ^ C:\ncs\v2.4.0\modules\lib\matter\src\app\util\attribute-storage.cpp:101:66: note: in expansion of macro 'GENERATED_ATTRIBUTES' 101 | constexpr const EmberAfAttributeMetadata generatedAttributes[] = GENERATED_ATTRIBUTES; | ^~~~~~~~~~~~~~~~~~~~ c:\ncs\v2.4.0\nrf\samples\matter\DHT11_Matter_Varshil\src\zap-generated\endpoint_config.h:85:1: error: expected unqualified-id before '}' token 85 | } | ^ C:\ncs\v2.4.0\modules\lib\matter\src\app\util\attribute-storage.cpp:101:66: note: in expansion of macro 'GENERATED_ATTRIBUTES' 101 | constexpr const EmberAfAttributeMetadata generatedAttributes[] = GENERATED_ATTRIBUTES; | ^~~~~~~~~~~~~~~~~~~~ c:\ncs\v2.4.0\nrf\samples\matter\DHT11_Matter_Varshil\src\zap-generated\endpoint_config.h:85:1: error: expected declaration before '}' token 85 | } | ^ C:\ncs\v2.4.0\modules\lib\matter\src\app\util\attribute-storage.cpp:101:66: note: in expansion of macro 'GENERATED_ATTRIBUTES' 101 | constexpr const EmberAfAttributeMetadata generatedAttributes[] = GENERATED_ATTRIBUTES; | ^~~~~~~~~~~~~~~~~~~~ c:\ncs\v2.4.0\nrf\samples\matter\DHT11_Matter_Varshil\src\zap-generated\endpoint_config.h:160:28: error: expected '}' before ':' token 160 | .clusterSize = 0ERROR: DeviceTypeList, invalid size, arrayERROR: ServerList, invalid size, arrayERROR: ClientList, invalid size, arrayERROR: PartsList, invalid size, array42, \ | ^ C:\ncs\v2.4.0\modules\lib\matter\src\app\util\attribute-storage.cpp:104:54: note: in expansion of macro 'GENERATED_CLUSTERS' 104 | constexpr const EmberAfCluster generatedClusters[] = GENERATED_CLUSTERS; | ^~~~~~~~~~~~~~~~~~ c:\ncs\v2.4.0\nrf\samples\matter\DHT11_Matter_Varshil\src\zap-generated\endpoint_config.h:155:3: note: to match this '{' 155 | { \ | ^ C:\ncs\v2.4.0\modules\lib\matter\src\app\util\attribute-storage.cpp:104:54: note: in expansion of macro 'GENERATED_CLUSTERS' 104 | constexpr const EmberAfCluster generatedClusters[] = GENERATED_CLUSTERS; | ^~~~~~~~~~~~~~~~~~ c:\ncs\v2.4.0\nrf\samples\matter\DHT11_Matter_Varshil\src\zap-generated\endpoint_config.h:160:28: error: expected '}' before ':' token 160 | .clusterSize = 0ERROR: DeviceTypeList, invalid size, arrayERROR: ServerList, invalid size, arrayERROR: ClientList, invalid size, arrayERROR: PartsList, invalid size, array42, \ | ^ C:\ncs\v2.4.0\modules\lib\matter\src\app\util\attribute-storage.cpp:104:54: note: in expansion of macro 'GENERATED_CLUSTERS' 104 | constexpr const EmberAfCluster generatedClusters[] = GENERATED_CLUSTERS; | ^~~~~~~~~~~~~~~~~~ c:\ncs\v2.4.0\nrf\samples\matter\DHT11_Matter_Varshil\src\zap-generated\endpoint_config.h:128:28: note: to match this '{' 128 | #define GENERATED_CLUSTERS { \ | ^ C:\ncs\v2.4.0\modules\lib\matter\src\app\util\attribute-storage.cpp:104:54: note: in expansion of macro 'GENERATED_CLUSTERS' 104 | constexpr const EmberAfCluster generatedClusters[] = GENERATED_CLUSTERS; | ^~~~~~~~~~~~~~~~~~ c:\ncs\v2.4.0\nrf\samples\matter\DHT11_Matter_Varshil\src\zap-generated\endpoint_config.h:167:5: error: expected declaration before '}' token 167 | },\ | ^ C:\ncs\v2.4.0\modules\lib\matter\src\app\util\attribute-storage.cpp:104:54: note: in expansion of macro 'GENERATED_CLUSTERS' 104 | constexpr const EmberAfCluster generatedClusters[] = GENERATED_CLUSTERS; | ^~~~~~~~~~~~~~~~~~ c:\ncs\v2.4.0\nrf\samples\matter\DHT11_Matter_Varshil\src\zap-generated\endpoint_config.h:167:6: error: expected unqualified-id before ',' token 167 | },\ | ^~ 168 | { \ | c:\ncs\v2.4.0\nrf\samples\matter\DHT11_Matter_Varshil\src\zap-generated\endpoint_config.h:167:6: note: in definition of macro 'GENERATED_CLUSTERS' 167 | },\ | ^~ 168 | { \ | c:\ncs\v2.4.0\nrf\samples\matter\DHT11_Matter_Varshil\src\zap-generated\endpoint_config.h:168:3: error: expected unqualified-id before '{' token 168 | { \ | ^ C:\ncs\v2.4.0\modules\lib\matter\src\app\util\attribute-storage.cpp:104:54: note: in expansion of macro 'GENERATED_CLUSTERS' 104 | constexpr const EmberAfCluster generatedClusters[] = GENERATED_CLUSTERS; | ^~~~~~~~~~~~~~~~~~ c:\ncs\v2.4.0\nrf\samples\matter\DHT11_Matter_Varshil\src\zap-generated\endpoint_config.h:180:6: error: expected unqualified-id before ',' token 180 | },\ | ^~ 181 | { \ | c:\ncs\v2.4.0\nrf\samples\matter\DHT11_Matter_Varshil\src\zap-generated\endpoint_config.h:180:6: note: in definition of macro 'GENERATED_CLUSTERS' 180 | },\ | ^~ 181 | { \ | c:\ncs\v2.4.0\nrf\samples\matter\DHT11_Matter_Varshil\src\zap-generated\endpoint_config.h:181:3: error: expected unqualified-id before '{' token 181 | { \ | ^ C:\ncs\v2.4.0\modules\lib\matter\src\app\util\attribute-storage.cpp:104:54: note: in expansion of macro 'GENERATED_CLUSTERS' 104 | constexpr const EmberAfCluster generatedClusters[] = GENERATED_CLUSTERS; | ^~~~~~~~~~~~~~~~~~ c:\ncs\v2.4.0\nrf\samples\matter\DHT11_Matter_Varshil\src\zap-generated\endpoint_config.h:193:6: error: expected unqualified-id before ',' token 193 | },\ | ^~ 194 | } | c:\ncs\v2.4.0\nrf\samples\matter\DHT11_Matter_Varshil\src\zap-generated\endpoint_config.h:193:6: note: in definition of macro 'GENERATED_CLUSTERS' 193 | },\ | ^~ 194 | } | c:\ncs\v2.4.0\nrf\samples\matter\DHT11_Matter_Varshil\src\zap-generated\endpoint_config.h:194:1: error: expected unqualified-id before '}' token 194 | } | ^ C:\ncs\v2.4.0\modules\lib\matter\src\app\util\attribute-storage.cpp:104:54: note: in expansion of macro 'GENERATED_CLUSTERS' 104 | constexpr const EmberAfCluster generatedClusters[] = GENERATED_CLUSTERS; | ^~~~~~~~~~~~~~~~~~ c:\ncs\v2.4.0\nrf\samples\matter\DHT11_Matter_Varshil\src\zap-generated\endpoint_config.h:194:1: error: expected declaration before '}' token 194 | } | ^ C:\ncs\v2.4.0\modules\lib\matter\src\app\util\attribute-storage.cpp:104:54: note: in expansion of macro 'GENERATED_CLUSTERS' 104 | constexpr const EmberAfCluster generatedClusters[] = GENERATED_CLUSTERS; | ^~~~~~~~~~~~~~~~~~ c:\ncs\v2.4.0\nrf\samples\matter\DHT11_Matter_Varshil\src\zap-generated\endpoint_config.h:202:38: error: expected '}' before ':' token 202 | { ZAP_CLUSTER_INDEX(0), 5, 160ERROR: DeviceTypeList, invalid size, arrayERROR: ServerList, invalid size, arrayERROR: ClientList, invalid size, arrayERROR: PartsList, invalid size, array421212 }, \ | ~ ^ C:\ncs\v2.4.0\modules\lib\matter\src\app\util\attribute-storage.cpp:107:71: note: in expansion of macro 'GENERATED_ENDPOINT_TYPES' 107 | constexpr const EmberAfEndpointType generatedEmberAfEndpointTypes[] = GENERATED_ENDPOINT_TYPES; | ^~~~~~~~~~~~~~~~~~~~~~~~ c:\ncs\v2.4.0\nrf\samples\matter\DHT11_Matter_Varshil\src\zap-generated\endpoint_config.h:202:38: error: expected '}' before ':' token 202 | { ZAP_CLUSTER_INDEX(0), 5, 160ERROR: DeviceTypeList, invalid size, arrayERROR: ServerList, invalid size, arrayERROR: ClientList, invalid size, arrayERROR: PartsList, invalid size, array421212 }, \ | ^ C:\ncs\v2.4.0\modules\lib\matter\src\app\util\attribute-storage.cpp:107:71: note: in expansion of macro 'GENERATED_ENDPOINT_TYPES' 107 | constexpr const EmberAfEndpointType generatedEmberAfEndpointTypes[] = GENERATED_ENDPOINT_TYPES; | ^~~~~~~~~~~~~~~~~~~~~~~~ c:\ncs\v2.4.0\nrf\samples\matter\DHT11_Matter_Varshil\src\zap-generated\endpoint_config.h:201:34: note: to match this '{' 201 | #define GENERATED_ENDPOINT_TYPES { \ | ^ C:\ncs\v2.4.0\modules\lib\matter\src\app\util\attribute-storage.cpp:107:71: note: in expansion of macro 'GENERATED_ENDPOINT_TYPES' 107 | constexpr const EmberAfEndpointType generatedEmberAfEndpointTypes[] = GENERATED_ENDPOINT_TYPES; | ^~~~~~~~~~~~~~~~~~~~~~~~ c:\ncs\v2.4.0\nrf\samples\matter\DHT11_Matter_Varshil\src\zap-generated\endpoint_config.h:202:195: error: expected declaration before '}' token 202 | { ZAP_CLUSTER_INDEX(0), 5, 160ERROR: DeviceTypeList, invalid size, arrayERROR: ServerList, invalid size, arrayERROR: ClientList, invalid size, arrayERROR: PartsList, invalid size, array421212 }, \ | ^ C:\ncs\v2.4.0\modules\lib\matter\src\app\util\attribute-storage.cpp:107:71: note: in expansion of macro 'GENERATED_ENDPOINT_TYPES' 107 | constexpr const EmberAfEndpointType generatedEmberAfEndpointTypes[] = GENERATED_ENDPOINT_TYPES; | ^~~~~~~~~~~~~~~~~~~~~~~~ c:\ncs\v2.4.0\nrf\samples\matter\DHT11_Matter_Varshil\src\zap-generated\endpoint_config.h:202:196: error: expected unqualified-id before ',' token 202 | { ZAP_CLUSTER_INDEX(0), 5, 160ERROR: DeviceTypeList, invalid size, arrayERROR: ServerList, invalid size, arrayERROR: ClientList, invalid size, arrayERROR: PartsList, invalid size, array421212 }, \ | ^ C:\ncs\v2.4.0\modules\lib\matter\src\app\util\attribute-storage.cpp:107:71: note: in expansion of macro 'GENERATED_ENDPOINT_TYPES' 107 | constexpr const EmberAfEndpointType generatedEmberAfEndpointTypes[] = GENERATED_ENDPOINT_TYPES; | ^~~~~~~~~~~~~~~~~~~~~~~~ c:\ncs\v2.4.0\nrf\samples\matter\DHT11_Matter_Varshil\src\zap-generated\endpoint_config.h:203:1: error: expected unqualified-id before '}' token 203 | } | ^ C:\ncs\v2.4.0\modules\lib\matter\src\app\util\attribute-storage.cpp:107:71: note: in expansion of macro 'GENERATED_ENDPOINT_TYPES' 107 | constexpr const EmberAfEndpointType generatedEmberAfEndpointTypes[] = GENERATED_ENDPOINT_TYPES; | ^~~~~~~~~~~~~~~~~~~~~~~~ c:\ncs\v2.4.0\nrf\samples\matter\DHT11_Matter_Varshil\src\zap-generated\endpoint_config.h:203:1: error: expected declaration before '}' token 203 | } | ^ C:\ncs\v2.4.0\modules\lib\matter\src\app\util\attribute-storage.cpp:107:71: note: in expansion of macro 'GENERATED_ENDPOINT_TYPES' 107 | constexpr const EmberAfEndpointType generatedEmberAfEndpointTypes[] = GENERATED_ENDPOINT_TYPES; | ^~~~~~~~~~~~~~~~~~~~~~~~ C:\ncs\v2.4.0\modules\lib\matter\src\app\util\attribute-storage.cpp:122:1: error: expected declaration before '}' token 122 | } // anonymous namespace | ^ [698/742] Building CXX object CMakeFiles/app.dir/C_/ncs/v2.4.0/modules/lib/matter/src/app/util/attribute-table.cpp.obj [699/742] Building CXX object CMakeFiles/app.dir/C_/ncs/v2.4.0/modules/lib/matter/src/app/server/CommissioningWindowManager.cpp.obj [700/742] Building CXX object CMakeFiles/app.dir/C_/ncs/v2.4.0/modules/lib/matter/src/app/util/ember-print.cpp.obj [701/742] Building CXX object CMakeFiles/app.dir/C_/ncs/v2.4.0/modules/lib/matter/src/app/util/util.cpp.obj [702/742] Building CXX object CMakeFiles/app.dir/C_/ncs/v2.4.0/modules/lib/matter/src/app/util/DataModelHandler.cpp.obj [703/742] Building CXX object CMakeFiles/app.dir/C_/ncs/v2.4.0/modules/lib/matter/src/app/util/message.cpp.obj [704/742] Building CXX object CMakeFiles/app.dir/C_/ncs/v2.4.0/modules/lib/matter/src/app/util/generic-callback-stubs.cpp.obj [705/742] Building CXX object CMakeFiles/app.dir/C_/ncs/v2.4.0/modules/lib/matter/src/app/util/ember-compatibility-functions.cpp.obj [706/742] Building CXX object CMakeFiles/app.dir/C_/ncs/v2.4.0/modules/lib/matter/zzz_generated/app-common/app-common/zap-generated/attributes/Accessors.cpp.obj ninja: build stopped: subcommand failed. FATAL ERROR: command exited with status 1: 'C:\ncs\toolchains\31f4403e35\opt\bin\cmake.EXE' --build 'c:\ncs\v2.4.0\nrf\samples\matter\DHT11_Matter_Varshil\MatterFinalBuild'
Please urgently need to solve this issue and your little bit of help will be very appreciated.
Thank You,
Varshil
