Zephyr ITS on settings/nvs, data does not persist through reset
I'm working on an application using ITS.  Since I'm currently having difficulty getting non-minimal TFM to work on the nrf9160, I have temporarily switched to not use TF-M with the 9160.
I'm using NCS 2.3.0 with Zephyr ITS with Settings/NVS underneath.
Here are the conf settings:
ONFIG_PSA_NATIVE_ITS=y
CONFIG_PSA_CRYPTO_DRIVER_OBERON=n
CONFIG_PSA_CRYPTO_DRIVER_CC3XX=y
CONFIG_NVS=y
CONFIG_SETTINGS=y
(I can provide complete project build privately)
I am finding 2 issues:
1) The data saved in the first call to psa_its_set  is not the same when I read it back with psa_its_get.  All the operations succeed, but the data is changed.  I have bypassed the issue by always calling psa_its_get immediately after psa_its_set and if the data doesn't match I retry the operation.
2) I'm finding after a reset that the data is no saved.  During the boot-up I see the following messages:
[00:00:00.258,544] <inf> fs_nvs: No GC Done marker found: restarting gc
[00:00:00.434,448] <inf> fs_nvs: 2 Sectors of 4096 bytes
[00:00:00.434,478] <inf> fs_nvs: alloc wra: 0, fe8
[00:00:00.434,478] <inf> fs_nvs: data wra: 0, 0
Is there some sort of NVS initialization that is necessary to make the zephyr ITS on Settings/NVS work?
    Unfortunately, due to the summer vacation period we are currently understaffed, so delayed replies must be expected. I am sorry about any inconvenience this might cause.
    Michal
    I will continue to help in this case.
    Are you sure that you want to use ITS and not Protected Storage?
    Give  Persistent storage of keys and data using the nRF Connect SDK a read and let me know if your questions still apply. (I have not read your question in depth yet, so I might have missed things)
    Sigurd Hellesvik
  • Since this application is very concerned with the security of this data, the preference was to apply as much protection to the keys and data as possible.  Ideally it would be stored internally in the KMU and only accessed by an ARoT secure partition from TF-M.  Unfortunately I was not able to use the cc3xx libraries from within an ARoT so the second best choice was to store the data in an ARoT secure partition using ITS, which is working for nrf5340 on NCS v2.3.0.  Alas, this also requires non-minimal TF-M which I have been unable to fit into nrf9160 along with mcuboot/NSIB.
    The client wants to move forward, so they requested I temporarily proceed on v2.3.0 without TF-M for the nrf9160.  Since the code was already written for ITS and PSA Crypto, and since encrypted internal storage is more secure than encrypted external storage, I went down the path of using ITS without TF-M.  which is an available configuration.  Also, the PSA crypto library expects to use ITS.
    I can look into switching the code between Protected Storage and Internal Trusted Storage for the nrf9160 non-TF-M implementation, but it is further degrading the security which is the second highest priority.  (The higher priority now being time-to-market)  I will have to forego use of persistent keys since PSA Crypto persistent keys are also stored  ITS.
    Alternatively is it possible to use Nordic's customized/encrypted ITS without TF-M?
    Also it does seem like there are bugs in the Zephyr implementation of ITS, its seems like it should be reported upstream?  Maybe it should be deprecated if is not supported?
    PSA Protected Storage uses ITS, so you can still use ITS for PSA Crypto persistent keys.
    Talking to our crypto team, they say that users are adviced to use PSA Protected Storage instead of ITS, also from the SPE.
    No, ITS is just available for TF-M.
    How small have you managed to get TF-M?
    Don't you need TF-M for non_secure to operate the modem?
  • Your answer is confusing..
    are you saying TF-M is REQUIRED for nrf9160?  That seems strange.  I assume there are examples of using nrf9160 modem without TF-M.  When running without TF-M in the build the application is in the secure domain so it should be able to access the modem without problems.  To be clear, I have adapted my application so that when I build for nrf9160, I build nrf9160dk_nrf9160 instead of nrf9160dk_nrf9160_ns so it completely removes TF-M.
    Also BTW, Zephyr does include an implementation of ITS separate from TF-M, however it seems to be incomplete/buggy.
