west debug FATAL ERROR required program JLink.exe not found
Procedure to reproduce this issue is as follows.
1. Unzipping minimal_log.zip
2. cd minimal_log
3. west build -b nrf5340dk_nrf5340_cpuapp
4. west debug
west log messages are as follows.
D:\ncs\v2.3.0\nrf\samples\minimal_log>west build -b nrf5340dk_nrf5340_cpuapp
[181/181] Linking C executable zephyr\zephyr.elf
Memory region Used Size Region Size %age Used
FLASH: 36640 B 1 MB 3.49%
RAM: 9808 B 448 KB 2.14%
IDT_LIST: 0 GB 2 KB 0.00%
D:\ncs\v2.3.0\nrf\samples\minimal_log>west debug
-- west debug: rebuilding
ninja: no work to do.
-- west debug: using runner jlink
FATAL ERROR: required program JLink.exe not found; install it or add its location to PATH
  • D:\ncs\v2.3.0\nrf\samples\minimal_log>west build -b nrf5340dk_nrf5340_cpuapp
    -- Application: D:/ncs/v2.3.0/nrf/samples/minimal_log
    -- Using NCS Toolchain 2.3.0 for building. (D:/ncs/toolchains/v2.3.0/cmake)
    -- Found Python3: D:/ncs/toolchains/v2.3.0/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter
    -- Cache files will be written to: D:/ncs/v2.3.0/zephyr/.cache
    -- Zephyr version: 3.2.99 (D:/ncs/v2.3.0/zephyr)
    -- Board: nrf5340dk_nrf5340_cpuapp
    -- Found host-tools: zephyr 0.15.2 (D:/ncs/toolchains/v2.3.0/opt/zephyr-sdk)
    -- Found toolchain: zephyr 0.15.2 (D:/ncs/toolchains/v2.3.0/opt/zephyr-sdk)
    -- Found Dtc: D:/ncs/toolchains/v2.3.0/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
    -- Found BOARD.dts: D:/ncs/v2.3.0/nrf/boards/arm/mdbt53db_nrf5340/nrf5340dk_nrf5340_cpuapp.dts
    -- Generated zephyr.dts: D:/ncs/v2.3.0/nrf/samples/minimal_log/build/zephyr/zephyr.dts
    -- Generated devicetree_generated.h: D:/ncs/v2.3.0/nrf/samples/minimal_log/build/zephyr/include/generated/devicetree_generated.h
    -- Including generated dts.cmake file: D:/ncs/v2.3.0/nrf/samples/minimal_log/build/zephyr/dts.cmake
    Parsing D:/ncs/v2.3.0/zephyr/Kconfig
    Loaded configuration 'D:/ncs/v2.3.0/nrf/boards/arm/mdbt53db_nrf5340/nrf5340dk_nrf5340_cpuapp_defconfig'
    Merged configuration 'D:/ncs/v2.3.0/nrf/samples/minimal_log/prj.conf'
    Configuration saved to 'D:/ncs/v2.3.0/nrf/samples/minimal_log/build/zephyr/.config'
    Kconfig header saved to 'D:/ncs/v2.3.0/nrf/samples/minimal_log/build/zephyr/include/generated/autoconf.h'
    -- The C compiler identification is GNU 12.1.0
    -- The CXX compiler identification is GNU 12.1.0
    -- Found assembler: D:/ncs/toolchains/v2.3.0/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc.exe
    -- Configuring done
    -- Generating done
    -- Build files have been written to: D:/ncs/v2.3.0/nrf/samples/minimal_log/build
    [1/181] Generating include/generated/version.h
    -- Zephyr version: 3.2.99 (D:/ncs/v2.3.0/zephyr), build: v3.2.99-ncs2
    [171/181] Linking C executable zephyr\zephyr_pre0.elf
    [175/181] Linking C executable zephyr\zephyr_pre1.elf
    For debugging, I suggest that you use Our VS Code extension.
    You should still be able to use "west debug", but if the VS Code extension solves the issue for you, then lets not dig down into debugging
    Sigurd Hellesvik
  • Let's look into what is wrong here then.
    How did you install the nRF Connect SDK?
    Can you program nRF Chips? If yes, how do you do this?
