Hi,I want to use my phone connect to NRF51822 by BLE, and used NRF24LE1 connect NRF51822 by GAZELL/ESB.That is to say, i want to use the device work with gazell/esb protocol and BLE alternatively! I add the function in the example(nRF51_SDK_8.1.0_b6ed55f\examples\ble_peripheral\ble_app_hids_keyboard\pca10028\s110\arm4).That is the code what i add in the example:
static nrf_radio_request_t m_timeslot_request;
static uint32_t m_slot_length = 10000;
static nrf_radio_signal_callback_return_param_t signal_callback_return_param;
static volatile bool m_esb_initialized = false;
#define PIPE_NUMBER 0
#define TX_PAYLOAD_LENGTH 1
static uint8_t my_tx_payload[TX_PAYLOAD_LENGTH];
static uint8_t my_rx_payload[NRF_ESB_CONST_MAX_PAYLOAD_LENGTH];
static void m_configure_earliest_timeslot(void)
m_timeslot_request.request_type = NRF_RADIO_REQ_TYPE_EARLIEST;
m_timeslot_request.params.earliest.hfclk = NRF_RADIO_HFCLK_CFG_DEFAULT;
m_timeslot_request.params.earliest.priority = NRF_RADIO_PRIORITY_NORMAL;
m_timeslot_request.params.earliest.length_us = m_slot_length;
m_timeslot_request.params.earliest.timeout_us = 1000000;
static void m_configure_normal_timeslot(void)
m_timeslot_request.request_type = NRF_RADIO_REQ_TYPE_NORMAL;
m_timeslot_request.params.normal.hfclk = NRF_RADIO_HFCLK_CFG_DEFAULT;
m_timeslot_request.params.normal.priority = NRF_RADIO_PRIORITY_NORMAL;
m_timeslot_request.params.normal.length_us = m_slot_length;
m_timeslot_request.params.normal.distance_us = 200000;
static void timeslot_on_start(void)
bool res;
signal_callback_return_param.params.request.p_next = NULL;
signal_callback_return_param.callback_action = NRF_RADIO_SIGNAL_CALLBACK_ACTION_NONE;
if (!m_esb_initialized )
res = nrf_esb_init(NRF_ESB_MODE_PTX);
printf("%d\r\n", res)
nrf_esb_enable();
(void)nrf_esb_add_packet_to_tx_fifo(PIPE_NUMBER, my_tx_payload, TX_PAYLOAD_LENGTH, NRF_ESB_PACKET_USE_ACK);
m_esb_initialized = true;
NRF_TIMER0->INTENSET = TIMER_INTENSET_COMPARE0_Msk;
NRF_TIMER0->CC[0] = m_slot_length - 1000;
NVIC_EnableIRQ(TIMER0_IRQn);
static void m_on_multitimer(void)
NRF_TIMER0->EVENTS_COMPARE[0] = 0;
NRF_TIMER0->TASKS_STOP = 1;
m_configure_normal_timeslot();
signal_callback_return_param.params.request.p_next = &m_timeslot_request;
signal_callback_return_param.callback_action = NRF_RADIO_SIGNAL_CALLBACK_ACTION_REQUEST_AND_END;
void timeslot_sys_event_handler(uint32_t sys_evt)
uint32_t err_code;
printf("sys_evt = %d\r\n", sys_evt);
switch (sys_evt)
case NRF_EVT_RADIO_SIGNAL_CALLBACK_INVALID_RETURN:
}break;
case NRF_EVT_RADIO_SESSION_IDLE:
}break;
case NRF_EVT_RADIO_SESSION_CLOSED:
}break;
case NRF_EVT_RADIO_BLOCKED:
case NRF_EVT_RADIO_CANCELED:
m_configure_earliest_timeslot();
err_code = sd_radio_request(&m_timeslot_request);
}break;
default:break;
nrf_radio_signal_callback_return_param_t * m_radio_callback(uint8_t signal_type)
printf("signal_type = %d\r\n", signal_type);
switch(signal_type)
case NRF_RADIO_CALLBACK_SIGNAL_TYPE_START:
timeslot_on_start();
}break;
case NRF_RADIO_CALLBACK_SIGNAL_TYPE_TIMER0:
m_on_multitimer();
}break;
case NRF_RADIO_CALLBACK_SIGNAL_TYPE_RADIO:
}break;
default:break;
return (&signal_callback_return_param);
uint32_t radio_timeslots_start(void)
uint32_t err_code;
err_code = sd_radio_session_open(m_radio_callback);
if(err_code != NRF_SUCCESS)
return err_code;
(void)sd_radio_session_close();
return err_code;
return NRF_SUCCESS;
void nrf_esb_tx_success(uint32_t tx_pipe, int32_t rssi)
static uint32_t success_times = 0;
success_times++;
printf("%d %d\r\n", success_times, rssi);
my_tx_payload[0]++;
void nrf_esb_tx_failed(uint32_t tx_pipe)
static uint32_t failed_times = 0;
failed_times++;
printf("%d\r\n", failed_times);
my_tx_payload[0]++;
void nrf_esb_rx_data_ready(uint32_t rx_pipe, int32_t rssi)
uint32_t my_rx_payload_length;
(void)nrf_esb_fetch_packet_from_rx_fifo(PIPE_NUMBER, my_rx_payload, &my_rx_payload_length);
if (my_rx_payload_length > 0)
printf("%d %d\r\n", rssi, my_rx_payload[0]);
void nrf_esb_disabled(void)
printf("disable\r\n");
But do not printf anything about the four callback functions. The printf as follows:
signal_type = 0
Start
signal_type = 1
sys_evt = 2
signal_type = 0
signal_type = 1
signal_type = 0
signal_type = 1
signal_type = 0
signal_type = 1
sys_evt = 4
signal_type = 0
signal_type = 1
signal_type = 0
signal_type = 1
signal_type = 0
signal_type = 1
signal_type = 0
signal_type = 1
signal_type = 0
So the four callback functions not be executed, why? What's wrong with the project?Thank you in advance!
