Getting the Trigger Source for a interrupt inside a Signle Callback Function
I am new to Nordic Semiconductors and Zephyr destribution.
I am trying to create a single callback function for multiple external interrupts from same port for a code library development.
Here is my code in IO.c library class:
ErrorCode configurePinInterrupt(PinList pin,button_event_handler_t buttonHandlerFn,gpio_flags_t interruptFlags){
    int ret = 0;
    uint8_t index = getPinIndex(pin);
    pressedButtonHandler = buttonHandlerFn;
    ret = gpio_pin_interrupt_configure_dt(&PinInfos[index].pinSpec,interruptFlags);
    if(ret!=0){
        setGPIO(LED1,HIGH);
        return GPIO_Pin_Set_Error;
    gpio_init_callback(&intrcallBackStruct,interruptCallbackFn,BIT(PinInfos[index].pinSpec.pin));
    ret = gpio_add_callback(PinInfos[index].pinSpec.port,&intrcallBackStruct);
    if(ret!=0){
        setGPIO(LED1,HIGH);
    return NO_ERROR;
static K_WORK_DELAYABLE_DEFINE (interruptDebouncing,buttonPressDebouncingHandler);
void interruptCallbackFn(const struct device *dev,struct gpio_callback *cb,uint32_t pins){
    currentPressedPin = Enable3V3;
    k_work_reschedule(&interruptDebouncing,K_MSEC(15));
void buttonPressDebouncingHandler(struct k_work buttonInterruptWork){
    ARG_UNUSED(buttonInterruptWork);
    int value = gpio_pin_get_dt(&PinInfos[getPinIndex(currentPressedPin)].pinSpec)?Button_Is_Pressed:Button_Is_Released;
    switch (value)
        case Button_Is_Pressed:
            setGPIO(LED2,LOW);
        case Button_Is_Released:
            pressedButtonHandler(currentPressedPin);
I need to find the pin number of the pin/pin spec inside "interruptCallbackFn" to differentiate between multiple external interrupt events.
Then I can pass that value to the main.c via pressedButtonHandler method.
Is there a way this can be done?
To make it easy:
1. A user can call the function "configurePinInterrupt" from main.c to configure interrupts for individual pins as below.
configurePinInterrupt(Enable3V3,enable3V3ButtonPressed,GPIO_INT_EDGE_RISING);
2. Then following method is invoked by the IO.c class, whenever an interrupt is generated.
void enable3V3ButtonPressed(PinList pin){
	switch (pin)
		case Enable3V3:
			setGPIO(LED2,HIGH);
Is there any possibility to achieve this functionality only using single callback function inside IO.c ?
