Controlling zigbee light bulb using UART
Hello everyone!!
So I have create a working zigbee light switch using nrf52840 dongle. Now my next step is that instead of using button present in the dongle I have to control it using laptop keys(to be precise using UART). Here is the main.c file code of zigbee nrf52840 dongle(Ignore the FOTA lines as I am not using ble):
* Copyright (c) 2020 Nordic Semiconductor ASA
/** @file
* @brief Dimmer switch for HA profile implementation.
#include <zephyr/kernel.h>
#include <zephyr/device.h>
#include <dk_buttons_and_leds.h>
#include <ram_pwrdn.h>
#include <zboss_api.h>
#include <zboss_api_addons.h>
#include <zigbee/zigbee_app_utils.h>
#include <zigbee/zigbee_error_handler.h>
#include <zb_nrf_platform.h>
#include "zb_mem_config_custom.h"
#include "zb_dimmer_switch.h"
#if CONFIG_ZIGBEE_FOTA
#include <zigbee/zigbee_fota.h>
#include <zephyr/sys/reboot.h>
#include <zephyr/dfu/mcuboot.h>
/* LED indicating OTA Client Activity. */
#define OTA_ACTIVITY_LED DK_LED3
#endif /* CONFIG_ZIGBEE_FOTA */
#if CONFIG_BT_NUS
#include "nus_cmd.h"
/* LED which indicates that Central is connected. */
#define NUS_STATUS_LED DK_LED4
/* UART command that will turn on found light bulb(s). */
#define COMMAND_ON "n"
/**< UART command that will turn off found light bulb(s). */
#define COMMAND_OFF "f"
/**< UART command that will turn toggle found light bulb(s). */
#define COMMAND_TOGGLE "t"
/**< UART command that will increase brightness of found light bulb(s). */
#define COMMAND_INCREASE "i"
/**< UART command that will decrease brightness of found light bulb(s). */
#define COMMAND_DECREASE "d"
#endif /* CONFIG_BT_NUS */
/* Source endpoint used to control light bulb. */
#define LIGHT_SWITCH_ENDPOINT 1
/* Delay between the light switch startup and light bulb finding procedure. */
#define MATCH_DESC_REQ_START_DELAY K_SECONDS(2)
/* Timeout for finding procedure. */
#define MATCH_DESC_REQ_TIMEOUT K_SECONDS(5)
/* Find only non-sleepy device. */
#define MATCH_DESC_REQ_ROLE ZB_NWK_BROADCAST_RX_ON_WHEN_IDLE
/* Do not erase NVRAM to save the network parameters after device reboot or
* power-off. NOTE: If this option is set to ZB_TRUE then do full device erase
* for all network devices before running other samples.
#define ERASE_PERSISTENT_CONFIG ZB_FALSE
/* LED indicating that light switch successfully joind Zigbee network. */
#define ZIGBEE_NETWORK_STATE_LED DK_LED1
/* LED used for device identification. */
#define IDENTIFY_LED ZIGBEE_NETWORK_STATE_LED
/* LED indicating that light witch found a light bulb to control. */
#define BULB_FOUND_LED DK_LED2
/* Button ID used to switch on the light bulb. */
#define BUTTON DK_BTN1_MSK
// /* Button ID used to switch off the light bulb. */
// #define BUTTON_OFF DK_BTN1_MSK
/* Dim step size - increases/decreses current level (range 0x000 - 0xfe). */
#define DIMM_STEP 15
/* Button ID used to enable sleepy behavior. */
// #define BUTTON_SLEEPY DK_BTN3_MSK
/* Button to start Factory Reset */
// #define FACTORY_RESET_BUTTON DK_BTN4_MSK
/* Button used to enter the Identify mode. */
// #define IDENTIFY_MODE_BUTTON DK_BTN4_MSK
/* Transition time for a single step operation in 0.1 sec units.
* 0xFFFF - immediate change.
#define DIMM_TRANSACTION_TIME 2
bool count=false;
/* Time after which the button state is checked again to detect button hold,
* the dimm command is sent again.
#define BUTTON_LONG_POLL_TMO K_MSEC(500)
#if !defined ZB_ED_ROLE
#error Define ZB_ED_ROLE to compile light switch (End Device) source code.
LOG_MODULE_REGISTER(app, LOG_LEVEL_INF);
struct bulb_context {
zb_uint8_t endpoint;
zb_uint16_t short_addr;
struct k_timer find_alarm;
struct buttons_context {
uint32_t state;
atomic_t long_poll;
struct k_timer alarm;
struct zb_device_ctx {
zb_zcl_basic_attrs_t basic_attr;
zb_zcl_identify_attrs_t identify_attr;
static struct bulb_context bulb_ctx;
static struct buttons_context buttons_ctx;
static struct zb_device_ctx dev_ctx;
/* Declare attribute list for Basic cluster (server). */
ZB_ZCL_DECLARE_BASIC_SERVER_ATTRIB_LIST(
basic_server_attr_list,
&dev_ctx.basic_attr.zcl_version,
&dev_ctx.basic_attr.power_source);
/* Declare attribute list for Identify cluster (client). */
ZB_ZCL_DECLARE_IDENTIFY_CLIENT_ATTRIB_LIST(
identify_client_attr_list);
/* Declare attribute list for Identify cluster (server). */
ZB_ZCL_DECLARE_IDENTIFY_SERVER_ATTRIB_LIST(
identify_server_attr_list,
&dev_ctx.identify_attr.identify_time);
/* Declare attribute list for Scenes cluster (client). */
ZB_ZCL_DECLARE_SCENES_CLIENT_ATTRIB_LIST(
scenes_client_attr_list);
/* Declare attribute list for Groups cluster (client). */
ZB_ZCL_DECLARE_GROUPS_CLIENT_ATTRIB_LIST(
groups_client_attr_list);
/* Declare attribute list for On/Off cluster (client). */
ZB_ZCL_DECLARE_ON_OFF_CLIENT_ATTRIB_LIST(
on_off_client_attr_list);
/* Declare attribute list for Level control cluster (client). */
ZB_ZCL_DECLARE_LEVEL_CONTROL_CLIENT_ATTRIB_LIST(
level_control_client_attr_list);
/* Declare cluster list for Dimmer Switch device. */
ZB_DECLARE_DIMMER_SWITCH_CLUSTER_LIST(
dimmer_switch_clusters,
identify_client_attr_list,
scenes_client_attr_list,
groups_client_attr_list,
on_off_client_attr_list,
/* Declare endpoint for Dimmer Switch device. */
ZB_DECLARE_DIMMER_SWITCH_EP(
dimmer_switch_ep,
LIGHT_SWITCH_ENDPOINT,
dimmer_switch_clusters);
/* Declare application's device context (list of registered endpoints)
* for Dimmer Switch device.
#ifndef CONFIG_ZIGBEE_FOTA
ZBOSS_DECLARE_DEVICE_CTX_1_EP(dimmer_switch_ctx, dimmer_switch_ep);
#else
#if LIGHT_SWITCH_ENDPOINT == CONFIG_ZIGBEE_FOTA_ENDPOINT
#error "Light switch and Zigbee OTA endpoints should be different."
extern zb_af_endpoint_desc_t zigbee_fota_client_ep;
ZBOSS_DECLARE_DEVICE_CTX_2_EP(dimmer_switch_ctx,
zigbee_fota_client_ep,
dimmer_switch_ep);
/* Forward declarations. */
static void light_switch_button_handler(struct k_timer *timer);
static void find_light_bulb_alarm(struct k_timer *timer);
static void find_light_bulb(zb_bufid_t bufid);
static void light_switch_send_on_off(zb_bufid_t bufid, zb_uint16_t on_off);
/**@brief Starts identifying the device.
* @param bufid Unused parameter, required by ZBOSS scheduler API.
static void start_identifying(zb_bufid_t bufid)
ZVUNUSED(bufid);
if (ZB_JOINED()) {
/* Check if endpoint is in identifying mode,
* if not, put desired endpoint in identifying mode.
if (dev_ctx.identify_attr.identify_time ==
ZB_ZCL_IDENTIFY_IDENTIFY_TIME_DEFAULT_VALUE) {
zb_ret_t zb_err_code = zb_bdb_finding_binding_target(LIGHT_SWITCH_ENDPOINT);
if (zb_err_code == RET_OK) {
LOG_INF("Enter identify mode");
} else if (zb_err_code == RET_INVALID_STATE) {
LOG_WRN("RET_INVALID_STATE - Cannot enter identify mode");
} else {
ZB_ERROR_CHECK(zb_err_code);
} else {
LOG_INF("Cancel identify mode");
zb_bdb_finding_binding_target_cancel();
} else {
LOG_WRN("Device not in a network - cannot enter identify mode");
/**@brief Callback for button events.
* @param[in] button_state Bitmask containing buttons state.
* @param[in] has_changed Bitmask containing buttons that has
* changed their state.
static void button_handler(uint32_t button_state, uint32_t has_changed)
zb_uint16_t cmd_id;
zb_ret_t zb_err_code;
/* Inform default signal handler about user input at the device. */
user_input_indicate();
check_factory_reset_button(button_state, has_changed);
if (bulb_ctx.short_addr == 0xFFFF) {
LOG_DBG("No bulb found yet.");
return;
switch (has_changed) {
case BUTTON:
if(count==true){
LOG_DBG("ON - button changed");
cmd_id = ZB_ZCL_CMD_ON_OFF_ON_ID;
{LOG_DBG("OFF - button changed");
cmd_id = ZB_ZCL_CMD_ON_OFF_OFF_ID;}
if(count==true)count=false;
else count=true;
printk("The value of count in Has_Changed is %d\n\r",count);
// case IDENTIFY_MODE_BUTTON:
// if (IDENTIFY_MODE_BUTTON & button_state) {
// /* Button changed its state to pressed */
// } else {
// /* Button changed its state to released */
// if (was_factory_reset_done()) {
// /* The long press was for Factory Reset */
// LOG_DBG("After Factory Reset - ignore button release");
// } else {
// /* Button released before Factory Reset */
// /* Start identification mode */
// ZB_SCHEDULE_APP_CALLBACK(start_identifying, 0);
return;
LOG_DBG("Unhandled button");
return;
switch (button_state) {
case BUTTON:
if(count==false){
LOG_DBG("Button pressed");
buttons_ctx.state = button_state;
// count=0;
/* Alarm can be scheduled only once. Next alarm only resets
* counting.
k_timer_start(&buttons_ctx.alarm, BUTTON_LONG_POLL_TMO,
K_NO_WAIT);}
else {;}
printk("The value of count in button_State is %d\n\r",count);
else count=true;
case 0:
LOG_DBG("Button released");
k_timer_stop(&buttons_ctx.alarm);
if (atomic_set(&buttons_ctx.long_poll, ZB_FALSE) == ZB_FALSE) {
/* Allocate output buffer and send on/off command. */
zb_err_code = zb_buf_get_out_delayed_ext(
light_switch_send_on_off, cmd_id, 0);
/**@brief Function for initializing LEDs and Buttons. */
static void configure_gpio(void)
int err;
err = dk_buttons_init(button_handler);
if (err) {
LOG_ERR("Cannot init buttons (err: %d)", err);
err = dk_leds_init();
if (err) {
LOG_ERR("Cannot init LEDs (err: %d)", err);
static void alarm_timers_init(void)
k_timer_init(&buttons_ctx.alarm, light_switch_button_handler, NULL);
k_timer_init(&bulb_ctx.find_alarm, find_light_bulb_alarm, NULL);
/**@brief Function for initializing all clusters attributes. */
static void app_clusters_attr_init(void)
/* Basic cluster attributes data. */
dev_ctx.basic_attr.zcl_version = ZB_ZCL_VERSION;
dev_ctx.basic_attr.power_source = ZB_ZCL_BASIC_POWER_SOURCE_UNKNOWN;
/* Identify cluster attributes data. */
dev_ctx.identify_attr.identify_time = ZB_ZCL_IDENTIFY_IDENTIFY_TIME_DEFAULT_VALUE;
/**@brief Function to toggle the identify LED.
static void toggle_identify_led(zb_bufid_t bufid)
static int blink_status;
dk_set_led(IDENTIFY_LED, (++blink_status) % 2);
ZB_SCHEDULE_APP_ALARM(toggle_identify_led, bufid, ZB_MILLISECONDS_TO_BEACON_INTERVAL(100));
/**@brief Function to handle identify notification events on the first endpoint.
static void identify_cb(zb_bufid_t bufid)
if (bufid) {
/* Schedule a self-scheduling function that will toggle the LED. */
ZB_SCHEDULE_APP_CALLBACK(toggle_identify_led, bufid);
} else {
/* Cancel the toggling function alarm and turn off LED. */
zb_err_code = ZB_SCHEDULE_APP_ALARM_CANCEL(toggle_identify_led, ZB_ALARM_ANY_PARAM);
ZVUNUSED(zb_err_code);
/* Update network status/idenitfication LED. */
if (ZB_JOINED()) {
dk_set_led_on(ZIGBEE_NETWORK_STATE_LED);
} else {
dk_set_led_off(ZIGBEE_NETWORK_STATE_LED);
/**@brief Function for sending ON/OFF requests to the light bulb.
* @param[in] bufid Non-zero reference to Zigbee stack buffer that will be
* used to construct on/off request.
* @param[in] cmd_id ZCL command id.
static void light_switch_send_on_off(zb_bufid_t bufid, zb_uint16_t cmd_id)
LOG_INF("Send ON/OFF command: %d", cmd_id);
ZB_ZCL_ON_OFF_SEND_REQ(bufid,
bulb_ctx.short_addr,
ZB_APS_ADDR_MODE_16_ENDP_PRESENT,
bulb_ctx.endpoint,
ZB_AF_HA_PROFILE_ID,
ZB_ZCL_DISABLE_DEFAULT_RESPONSE,
cmd_id,
NULL);
/**@brief Function for sending step requests to the light bulb.
* will be used to construct step request.
static void light_switch_send_step(zb_bufid_t bufid, zb_uint16_t cmd_id)
LOG_INF("Send step level command: %d", cmd_id);
ZB_ZCL_LEVEL_CONTROL_SEND_STEP_REQ(bufid,
bulb_ctx.endpoint,
NULL,
cmd_id,
DIMM_STEP,
DIMM_TRANSACTION_TIME);
/**@brief Callback function receiving finding procedure results.
* @param[in] bufid Reference to Zigbee stack buffer used to pass
* received data.
static void find_light_bulb_cb(zb_bufid_t bufid)
/* Get the beginning of the response. */
zb_zdo_match_desc_resp_t *resp =
(zb_zdo_match_desc_resp_t *) zb_buf_begin(bufid);
/* Get the pointer to the parameters buffer, which stores APS layer
* response.
zb_apsde_data_indication_t *ind = ZB_BUF_GET_PARAM(bufid,
zb_apsde_data_indication_t);
zb_uint8_t *match_ep;
if ((resp->status == ZB_ZDP_STATUS_SUCCESS) &&
(resp->match_len > 0) &&
(bulb_ctx.short_addr == 0xFFFF)) {
/* Match EP list follows right after response header. */
match_ep = (zb_uint8_t *)(resp + 1);
/* We are searching for exact cluster, so only 1 EP
* may be found.
bulb_ctx.endpoint = *match_ep;
bulb_ctx.short_addr = ind->src_addr;
LOG_INF("Found bulb addr: %d ep: %d",
bulb_ctx.endpoint);
k_timer_stop(&bulb_ctx.find_alarm);
dk_set_led_on(BULB_FOUND_LED);
} else {
LOG_INF("Bulb not found, try again");
if (bufid) {
zb_buf_free(bufid);
/**@brief Find bulb allarm handler.
* @param[in] timer Address of timer.
ZB_ERROR_CHECK(zb_buf_get_out_delayed(find_light_bulb));
/**@brief Function for sending ON/OFF and Level Control find request.
* @param[in] bufid Reference to Zigbee stack buffer that will be used to
* construct find request.
zb_zdo_match_desc_param_t *req;
zb_uint8_t tsn = ZB_ZDO_INVALID_TSN;
/* Initialize pointers inside buffer and reserve space for
* zb_zdo_match_desc_param_t request.
req = zb_buf_initial_alloc(bufid,
sizeof(zb_zdo_match_desc_param_t) + (1) * sizeof(zb_uint16_t));
req->nwk_addr = MATCH_DESC_REQ_ROLE;
req->addr_of_interest = MATCH_DESC_REQ_ROLE;
req->profile_id = ZB_AF_HA_PROFILE_ID;
/* We are searching for 2 clusters: On/Off and Level Control Server. */
req->num_in_clusters = 2;
req->num_out_clusters = 0;
req->cluster_list[0] = ZB_ZCL_CLUSTER_ID_ON_OFF;
req->cluster_list[1] = ZB_ZCL_CLUSTER_ID_LEVEL_CONTROL;
/* Set 0xFFFF to reset short address in order to parse
* only one response.
bulb_ctx.short_addr = 0xFFFF;
tsn = zb_zdo_match_desc_req(bufid, find_light_bulb_cb);
/* Free buffer if failed to send a request. */
if (tsn == ZB_ZDO_INVALID_TSN) {
zb_buf_free(bufid);
LOG_ERR("Failed to send Match Descriptor request");
/**@brief Callback for detecting button press duration.
printk("The value of count in light_switch_button_handler is %d\n\r",count);
zb_uint16_t cmd_id;
if (dk_get_buttons() & buttons_ctx.state) {
atomic_set(&buttons_ctx.long_poll, ZB_TRUE);
if (buttons_ctx.state == BUTTON && count==true) {
cmd_id = ZB_ZCL_LEVEL_CONTROL_STEP_MODE_UP;
} else {
cmd_id = ZB_ZCL_LEVEL_CONTROL_STEP_MODE_DOWN;
/* Allocate output buffer and send step command. */
zb_err_code = zb_buf_get_out_delayed_ext(light_switch_send_step,
cmd_id,
0);
if (!zb_err_code) {
LOG_WRN("Buffer is full");
K_NO_WAIT);
} else {
atomic_set(&buttons_ctx.long_poll, ZB_FALSE);
#ifdef CONFIG_ZIGBEE_FOTA
static void confirm_image(void)
if (!boot_is_img_confirmed()) {
int ret = boot_write_img_confirmed();
if (ret) {
LOG_ERR("Couldn't confirm image: %d", ret);
} else {
LOG_INF("Marked image as OK");
static void ota_evt_handler(const struct zigbee_fota_evt *evt)
switch (evt->id) {
case ZIGBEE_FOTA_EVT_PROGRESS:
dk_set_led(OTA_ACTIVITY_LED, evt->dl.progress % 2);
case ZIGBEE_FOTA_EVT_FINISHED:
LOG_INF("Reboot application.");
/* Power on unused sections of RAM to allow MCUboot to use it. */
if (IS_ENABLED(CONFIG_RAM_POWER_DOWN_LIBRARY)) {
power_up_unused_ram();
sys_reboot(SYS_REBOOT_COLD);
case ZIGBEE_FOTA_EVT_ERROR:
LOG_ERR("OTA image transfer failed.");
/**@brief Callback function for handling ZCL commands.
* used to pass received data.
static void zcl_device_cb(zb_bufid_t bufid)
zb_zcl_device_callback_param_t *device_cb_param =
ZB_BUF_GET_PARAM(bufid, zb_zcl_device_callback_param_t);
if (device_cb_param->device_cb_id == ZB_ZCL_OTA_UPGRADE_VALUE_CB_ID) {
zigbee_fota_zcl_cb(bufid);
} else {
device_cb_param->status = RET_NOT_IMPLEMENTED;
/**@brief Zigbee stack event handler.
* @param[in] bufid Reference to the Zigbee stack buffer
* used to pass signal.
void zboss_signal_handler(zb_bufid_t bufid)
zb_zdo_app_signal_hdr_t *sig_hndler = NULL;
zb_zdo_app_signal_type_t sig = zb_get_app_signal(bufid, &sig_hndler);
zb_ret_t status = ZB_GET_APP_SIGNAL_STATUS(bufid);
/* Update network status LED. */
zigbee_led_status_update(bufid, ZIGBEE_NETWORK_STATE_LED);
/* Pass signal to the OTA client implementation. */
zigbee_fota_signal_handler(bufid);
switch (sig) {
case ZB_BDB_SIGNAL_DEVICE_REBOOT:
/* fall-through */
case ZB_BDB_SIGNAL_STEERING:
/* Call default signal handler. */
ZB_ERROR_CHECK(zigbee_default_signal_handler(bufid));
if (status == RET_OK) {
/* Check the light device address. */
k_timer_start(&bulb_ctx.find_alarm,
MATCH_DESC_REQ_START_DELAY,
MATCH_DESC_REQ_TIMEOUT);
case ZB_ZDO_SIGNAL_LEAVE:
/* If device leaves the network, reset bulb short_addr. */
zb_zdo_signal_leave_params_t *leave_params =
ZB_ZDO_SIGNAL_GET_PARAMS(sig_hndler, zb_zdo_signal_leave_params_t);
if (leave_params->leave_type == ZB_NWK_LEAVE_TYPE_RESET) {
if (bufid) {
zb_buf_free(bufid);
#if CONFIG_BT_NUS
static void turn_on_cmd(struct k_work *item)
ARG_UNUSED(item);
zb_buf_get_out_delayed_ext(light_switch_send_on_off,
ZB_ZCL_CMD_ON_OFF_ON_ID, 0);
static void turn_off_cmd(struct k_work *item)
ARG_UNUSED(item);
ZB_ZCL_CMD_ON_OFF_OFF_ID, 0);
static void toggle_cmd(struct k_work *item)
ARG_UNUSED(item);
ZB_ZCL_CMD_ON_OFF_TOGGLE_ID, 0);
static void increase_cmd(struct k_work *item)
ARG_UNUSED(item);
ZB_ZCL_LEVEL_CONTROL_STEP_MODE_UP, 0);
static void decrease_cmd(struct k_work *item)
ARG_UNUSED(item);
ZB_ZCL_LEVEL_CONTROL_STEP_MODE_DOWN, 0);
static void on_nus_connect(struct k_work *item)
ARG_UNUSED(item);
dk_set_led_on(NUS_STATUS_LED);
static void on_nus_disconnect(struct k_work *item)
ARG_UNUSED(item);
dk_set_led_off(NUS_STATUS_LED);
static struct nus_entry commands[] = {
NUS_COMMAND(COMMAND_ON, turn_on_cmd),
NUS_COMMAND(COMMAND_OFF, turn_off_cmd),
NUS_COMMAND(COMMAND_TOGGLE, toggle_cmd),
NUS_COMMAND(COMMAND_INCREASE, increase_cmd),
NUS_COMMAND(COMMAND_DECREASE, decrease_cmd),
NUS_COMMAND(NULL, NULL),
LOG_INF("Starting ZBOSS Light Switch example");
/* Initialize. */
configure_gpio();
alarm_timers_init();
// register_factory_reset_button(FACTORY_RESET_BUTTON);
zigbee_erase_persistent_storage(ERASE_PERSISTENT_CONFIG);
zb_set_ed_timeout(ED_AGING_TIMEOUT_64MIN);
zb_set_keepalive_timeout(ZB_MILLISECONDS_TO_BEACON_INTERVAL(3000));
/* Set default bulb short_addr. */
/* If "sleepy button" is defined, check its state during Zigbee
* initialization and enable sleepy behavior at device if defined button
* is pressed.
#if defined BUTTON_SLEEPY
if (dk_get_buttons() & BUTTON_SLEEPY) {
zigbee_configure_sleepy_behavior(true);
/* Power off unused sections of RAM to lower device power consumption. */
power_down_unused_ram();
/* Initialize Zigbee FOTA download service. */
zigbee_fota_init(ota_evt_handler);
/* Mark the current firmware as valid. */
confirm_image();
/* Register callback for handling ZCL commands. */
ZB_ZCL_REGISTER_DEVICE_CB(zcl_device_cb);
/* Register dimmer switch device context (endpoints). */
ZB_AF_REGISTER_DEVICE_CTX(&dimmer_switch_ctx);
app_clusters_attr_init();
/* Register handlers to identify notifications */
ZB_AF_SET_IDENTIFY_NOTIFICATION_HANDLER(LIGHT_SWITCH_ENDPOINT, identify_cb);
ZB_AF_SET_IDENTIFY_NOTIFICATION_HANDLER(CONFIG_ZIGBEE_FOTA_ENDPOINT, identify_cb);
/* Start Zigbee default thread. */
zigbee_enable();
#if CONFIG_BT_NUS
/* Initialize NUS command service. */
nus_cmd_init(on_nus_connect, on_nus_disconnect, commands);
LOG_INF("ZBOSS Light Switch example started");
while (1) {
k_sleep(K_FOREVER);
Can anyone help me to modify this code so that I can control zigbee light bulbs using UART
  • Hello Coder and thank you for your patience.
    Summer can be a bit hectic on DevZone, so there might unfortunately be some delays in the responses here. Though we will get to you eventually.
    Great! I don't have the time to do it for you unfortunately. Though I'll definitely try to help.
    I would recommend you to have a look at our peripheral uart sample, and use the uart functionality from that along with this configuration
    Though I should mention that for development you should rather use a development kit. A dongle can be practical at times, though without the onboard debugger you'll have a hard time developing. Do you have a DK?
    Elfving
