nrfjprog failures
I'm working on custom test software for use in production programming/testing of my product containing a nRF9160. I'm using the nrfjprog executable, but with problems, every second call to nrfjprog --program is failing:
D:\[path here]\nrfjprog\nrfjprog
--ini D:\[path here]\nrfjprog\nrfjprog.ini
-f NRF91
-c 4000
-s [serial here]
--program D:\[path here]\temp_files\74e8207a-5983-41e5-b1e6-45eaa2d0f0fb.hex
--sectorerase
--verify
--log
[error] [ Client] - Encountered error -102: Command program_file executed for 188 milliseconds with result -102
[error] [ nRF91] - The write access failed, but no cause could be determined.
[error] [ nRF91] - It may be due to an unaligned access, accessing a nonexistent memory, or a communication issue.
[error] [ nRF91] - Failed while performing 'Write' operation on target address 0x00000000. -102: An unknown error.
[error] [ nRF91] - Failed while reading device information.
[error] [ Worker] - An unknown error. ERROR: JLinkARM DLL reported an error. Try again. If error condition ERROR: persists, run the same command again with argument --log, contact Nordic ERROR: Semiconductor and provide the generated log.log file to them.
The log file is attached.
nrfjprog v10.22.1
JLINK v7.80c
nrf connect system report:
# nRFConnect System Report - 2023-07-17T12-26-40.066Z
- System:     Acer Aspire TC-885
- BIOS:       American Megatrends Inc ACRSYS - 1072009
- CPU:        1 x Intel Core™ i7-8700 3.2 GHz 12 cores (6 physical)
- Memory:     5.3 GB free of 15.9 GB total
- Filesystem: C: (NTFS) 930.9 GB 47.6% used
- OS:         Microsoft Windows 10 Home (10.0.19045) Windows x64
- Versions
    - kernel: 10.0.19045
    - git: 2.30.0.windows.1
    - node: 16.17.1
    - python: 3.11.0
    - python3: 3.10.11
    - nrf-device-lib-js: 0.6.12
    - nrf-device-lib: 0.15.3
    - nrfjprog DLL: 10.19.1
    - JLink: JLink_V7.80c
- Connected devices:
    - CAFEBABE : COM24
    - 000600105884 Unknown: undefined
    - {34C052A1-08B6-5809-881E-95820D434537} : COM21
    - FTXP9XD7 : COM10
    - {921BE77D-DA9D-11ED-A25F-94C69193D3EE} : COM7, COM8
6712.log.log
  • Did you try upgrating the OB JLink firmware using Segger tools?
    Michal
  • Firmware is up to date:
    SEGGER J-Link Configuration V7.88j
    Logging started @ 2023-08-21 15:47
    Updating firmware of probe/ programmer 1 of 1 via USB (SN: 6001xxxx)...Not updated, probe/ programmer firmware is already up to date.
  • Thank you for checking.
    How are you connecting the DK by the way? Are you connecting the USB directly to your PC, or via a hub?
    There is no COM port connected to the DK when trying to flash for the first time, right?
    Michal
  • Not sure what you mean with 'DK', but if it is the debug probe, this is connected directly to the PC, no hubs.
    I've two situations with programming troubles:
    - The testboard situation, where the DUT is tested and programmed, here is also a USB<->UART connected. In this case NRFJPROG is called from my test software. In this case every second try succeeds.
    - Programming in development from VSCode. In this case programming always fails, only full erase works, not '--sectorerase'.
    I also tested without USB<->UART connected, no change. When i change the debug probe from a JLink plus to a Jlink base the error message in VSCode changes slightly.
    This is with the plus version:
    -- west flash: using runner nrfjprog
    -- runners.nrfjprog: Flashing file: D:\[PATH]\merged.hex
    [ #################### ]  13.455s | Erase file - Done erasing
    [error] [ Client] - Encountered error -102: Command program_file executed for 203 milliseconds with result -102
    NOTE: For additional output, try running again with logging enabled (--log).
    NOTE: Any generated log error messages will be displayed.
    FATAL ERROR: command exited with status 33: nrfjprog --program 'D:\[path]\merged.hex' --sectorerase --verify -f NRF91 --snr [serial]
    And with the base version:
    -- runners.nrfjprog: Flashing file: D:\[path]\merged.hex
    [error] [ Client] - Encountered error -102: Command erase_file executed for 217 milliseconds with result -102
    [error] [  nRF91] - Failed while performing 'Erase' operation on target address 0x00000000.
    -102: JLinkARM.dll WriteU32 returned error -1.
    [error] [  nRF91] - Failed while erasing device. -102: JLinkARM.dll WriteU32 returned error -1.
    [error] [ Worker] - JLinkARM.dll WriteU32 returned error -1.
    FATAL ERROR: command exited with status 33: nrfjprog --program 'D:\[PATH]\merged.hex' --sectorerase --verify -f NRF91 --snr [serial]
    With the plus version I am able to execute a sector erase in J-Flash without problems.
  • I am seeing this same problem with flashing the nRF5340 in VS Code without a full erase, but instead using --sectorerase.
    I am using:
    J-Link V7.92a (latest)
    nRF Command Line Tools 10.23.0 (latest)
    nrfjprog 10.23.0 (latest)
    When flashing from the latest version of VS Code with a full chip erase, it works perfectly:
    Flashing build to 69660205
    C:\Windows\system32\cmd.exe /d /s /c "west flash -d c:\ble\patriot\build --skip-rebuild --dev-id 69660205 --erase"
    -- runners.nrfjprog: mass erase requested
    -- runners.nrfjprog: Flashing file: c:\ble\patriot\build\zephyr\merged_domains.hex
    -- runners.nrfjprog: c:\ble\patriot\build\zephyr\merged_domains.hex targets both nRF53 coprocessors; splitting it into: c:\ble\patriot\build\zephyr\GENERATED_CP_NETWORK_merged_domains.hex and c:\ble\patriot\build\zephyr\GENERATED_CP_APPLICATION_merged_domains.hex
    [ #################### ] 0.354s | Erase file - Done erasing
    [ #################### ] 1.438s | Program file - Done programming
    [ #################### ] 1.643s | Verify file - Done verifying
    [ #################### ] 0.370s | Erase file - Done erasing
    [ #################### ] 4.304s | Program file - Done programming
    [ #################### ] 4.996s | Verify file - Done verifying
    Applying pin reset.
    -- runners.nrfjprog: Board with serial number 69660205 flashed successfully.
    Then if I attempt to flash it again immediately after without selecting a full chip erase, it fails to flash:
    C:\Windows\system32\cmd.exe /d /s /c "west flash -d c:\ble\patriot\build --skip-rebuild --dev-id 69660205"
    [ #################### ] 12.986s | Erase file - Done erasing
    [error] [ Client] - Encountered error -102: Command program_file executed for 72 milliseconds with result -102
    [error] [ nRF53] - Failed while detecting device memory block protection status!
    [error] [ nRF53] - Failed while reading device information.
    [error] [ Worker] - JLinkARM.dll Halt returned error 1.
    FATAL ERROR: command exited with status 33: nrfjprog --program 'c:\ble\patriot\build\zephyr\GENERATED_CP_NETWORK_merged_domains.hex' --sectorerase --verify -f NRF53 --coprocessor CP_NETWORK --snr 69660205
    If I try to flash it again with full chip erase, it still fails. The only thing that seems to allow it to be flashed again is doing an nrfjprog --recover or using the Programmer app from nRF Connect Desktop to fully erase the chip.
    [error] [ Client] - Encountered error -90: Command read_memory_descriptors executed for 15 milliseconds with result -90
    [error] [ Worker] - Can't read memory descriptors, ap-protection is enabled.
    [error] [ Client] - Encountered error -90: Command erase_file executed for 62 milliseconds with result -90
    [error] [ nRF53] - Failed while erasing device. -90: Access protection is enabled, can't read block protection state.
    [error] [ Worker] - Access protection is enabled, can't read block protection state.
    ERROR: The operation attempted is unavailable due to readback protection in
    ERROR: your device. Please use --recover to unlock the device.
    ERROR: runners.nrfjprog: Flashing failed because the target must be recovered.
    To fix, run "west flash --recover" instead.
    Note: your target is an nRF53; all flash memory for both the network and application cores will be erased prior to reflashing.
    FATAL ERROR: command exited with status 24: nrfjprog --program 'c:\ble\patriot\build\zephyr\GENERATED_CP_NETWORK_merged_domains.hex' --chiperase --verify -f NRF53 --coprocessor CP_NETWORK --snr 69660205
