nrfjprog failures
I'm working on custom test software for use in production programming/testing of my product containing a nRF9160. I'm using the nrfjprog executable, but with problems, every second call to nrfjprog --program is failing:
D:\[path here]\nrfjprog\nrfjprog
--ini D:\[path here]\nrfjprog\nrfjprog.ini
-f NRF91
-c 4000
-s [serial here]
--program D:\[path here]\temp_files\74e8207a-5983-41e5-b1e6-45eaa2d0f0fb.hex
--sectorerase
--verify
--log
[error] [ Client] - Encountered error -102: Command program_file executed for 188 milliseconds with result -102
[error] [ nRF91] - The write access failed, but no cause could be determined.
[error] [ nRF91] - It may be due to an unaligned access, accessing a nonexistent memory, or a communication issue.
[error] [ nRF91] - Failed while performing 'Write' operation on target address 0x00000000. -102: An unknown error.
[error] [ nRF91] - Failed while reading device information.
[error] [ Worker] - An unknown error. ERROR: JLinkARM DLL reported an error. Try again. If error condition ERROR: persists, run the same command again with argument --log, contact Nordic ERROR: Semiconductor and provide the generated log.log file to them.
The log file is attached.
nrfjprog v10.22.1
JLINK v7.80c
nrf connect system report:
# nRFConnect System Report - 2023-07-17T12-26-40.066Z
- System:     Acer Aspire TC-885
- BIOS:       American Megatrends Inc ACRSYS - 1072009
- CPU:        1 x Intel Core™ i7-8700 3.2 GHz 12 cores (6 physical)
- Memory:     5.3 GB free of 15.9 GB total
- Filesystem: C: (NTFS) 930.9 GB 47.6% used
- OS:         Microsoft Windows 10 Home (10.0.19045) Windows x64
- Versions
    - kernel: 10.0.19045
    - git: 2.30.0.windows.1
    - node: 16.17.1
    - python: 3.11.0
    - python3: 3.10.11
    - nrf-device-lib-js: 0.6.12
    - nrf-device-lib: 0.15.3
    - nrfjprog DLL: 10.19.1
    - JLink: JLink_V7.80c
- Connected devices:
    - CAFEBABE : COM24
    - 000600105884 Unknown: undefined
    - {34C052A1-08B6-5809-881E-95820D434537} : COM21
    - FTXP9XD7 : COM10
    - {921BE77D-DA9D-11ED-A25F-94C69193D3EE} : COM7, COM8
6712.log.log
