Socket error: POLLHUP, Connection was closed by the AWS IoT broker
I'm trying to periodically send sensor data to the AWS server and followed the documentation here to connect and send data to the server. I use these configurations -
CONFIG_LTE_PSM_REQ_RPTAU="11000001" (320 hours)
CONFIG_LTE_PSM_REQ_RAT="00000001" (2 seconds)
CONFIG_MQTT_KEEPALIVE=1200 (20 min)
I have programmed the device to send data (QOS 0), poll the socket for 2 seconds and then sleeps for a specified interval of time (sleep_time). I see that if I have the sleep time anywhere between 1 to 328 seconds, the device works without any problem. If I increase the sleep time to say 358 seconds, the first message is sent properly but the second message receives a Socket error: POLLHUP, Connection was closed by the AWS IoT broker message. I've played with the CONFIG_MQTT_KEEPALIVE value but I cannot increase the data send interval above 328 seconds. Do you have any ideas how I could debug this? Thanks in advance!
Nikil
  • Hi!
     In what sense? Have you tried decreasing it? I believe a lot of brokers have the default keepalive time as 60 seconds.
    I think taking a modem trace is the best course of action here. That way we can see the actual TCP packets going back and forth.
    Heidi
  • Hi Heidi,
    Thanks for the quick reply! I have tried decreasing it and increasing it but I have to send messages with an interval < 5 min in all cases to not get that error. According to the AWS documentation here (Under protocols->Connection inactivity (keep-alive interval)) it is mentioned that I can request a keep alive interval of 30-1200 seconds. I will try to take a modem trace and send it to you for analysis, thanks!
    In case I cannot increase the data send interval (we would like to send data every 30 minutes) is the only solution to ping the AWS server frequently (every 5 minutes) and send data every 30 minutes? That would mean unnecessary power consumption every time we send a ping message. Is there any way I could avoid that?
    Nikil
  • I also found this post which seems to be describing the same problem
    We have a custom board and I'll try to collect the modem trace. These are the logs I get from MQTT -
    [00:18:31.920,135] <dbg> aws_iot.aws_iot_send: Publishing to topic: test/things/protobuf/publish/testing/
    [00:18:31.920,135] <dbg> net_mqtt.mqtt_publish: (0x20020ff8): [CID 0x20021df8]:[State 0x06]: >> Topic size 0x00000026, Data size 0x00000039
    [00:18:31.920,257] <dbg> net_mqtt_enc.pack_utf8_str: (0x20020ff8): >> str_size:00000028 cur:0x2002919a, end:0x2002957d
    [00:18:31.920,288] <dbg> net_mqtt_enc.pack_uint16: (0x20020ff8): >> val:0026 cur:0x2002919a, end:0x2002957d
    [00:18:31.920,288] <dbg> net_mqtt_enc.mqtt_encode_fixed_header: (0x20020ff8): << msg type:0x30 length:0x00000061
    [00:18:31.920,288] <dbg> net_mqtt_enc.packet_length_encode: (0x20020ff8): >> length:0x00000061 cur:0x00000000, end:0x00000000
    [00:18:31.920,318] <dbg> net_mqtt_enc.mqtt_encode_fixed_header: (0x20020ff8): Fixed header length = 02
    [00:18:31.920,318] <dbg> net_mqtt_enc.pack_uint8: (0x20020ff8): >> val:30 cur:0x20029198, end:0x2002957d
    [00:18:31.920,318] <dbg> net_mqtt_enc.packet_length_encode: (0x20020ff8): >> length:0x00000061 cur:0x20029199, end:0x2002957d
    [00:18:31.920,349] <dbg> net_mqtt.client_write_msg: (0x20020ff8): [0x20021df8]: Transport writing message.
    [00:18:31.920,410] <dbg> net_mqtt.client_write_msg: (0x20020ff8): Transport write failed, err_code = -104, closing connection
    [00:18:31.920,410] <dbg> net_mqtt_sock_tls.mqtt_client_tls_disconnect: (0x20020ff8): Closing socket 1
    [00:18:31.920,471] <dbg> aws_iot.mqtt_evt_handler: MQTT_EVT_DISCONNECT: result = -104
    [00:18:31.932,220] <dbg> net_mqtt.mqtt_publish: (0x20020ff8): [CID 0x20021df8]:[State 0x00]: << result 0xffffff98
    I see that MQTT disconnects with an error code of -104 ( ECONNRESET 104 /* Connection reset by peer */). Can we figure out why the connection is being reset? Thanks!
    Nikil
  • I debugged this further and it actually seems to be caused by a POLLHUP error. When I poll the socket after sending a message, I get a revents value of 0x11 on the file descriptor. This means that the POLLIN and POLLHUP flags were set. Since the POLLIN flag was set, I call the aws_iot_input function which finally leads to the recv function in mqtt_client_tls_read to return zero and I get disconnected from AWS.
