Using ESB to sync time between multiple devices with accuracy < 1ms
Hello
I am building an application where multiple devices needs to keep the time in sync, wirelessly, with error of less that 1ms.
On a test that I performed using the ESB protocol, I found that the latency of the data between a transmitter and a receiver was always <1ms.
The idea is that, using the ESB protocol, a primary transmitter will send a timestamp to multiple receivers. Using the small delay of the transmitted data, the receivers will be able to sync their clocks with accuracy of <1ms which is the latency of the transmitted data.
Is it possible to use ESB for such an application? Or any other suggestions that this application can be possible?
