HI ,
I need dma support for the uart protocol but I can't seem to locate any examples of it being used with an uart. Can anyone give support on this?
regards ,
Goudam
HI ,
regards ,
Goudam
You can only set a callback if the UART driver is configured in async mode, otherwise the function will return an error.
Try adding "CONFIG_UART_ASYNC_API=y" to your prj.conf.
Already this one is added in prj.conf file.
I found the issue in the driver code, where the macro UARTE_ANY_ASYNC was not enabled, so that user space API uart_callback_set(uart, uart_cb, NULL) will not able to set the callback. I also checked with the nrf52840dk board, which has the same code and has the macro UARTE_ANY_ASYNC enabled, but the xiao_ble board does not enabled.
The UARTE_ANY_ASYNC symbol depends on the CONFIG_UART_x_ASYNC Kconfigs.
How to enable this macro because if i enable this in prj.conf file i got some errors . In windows how to use west build commands for change kconfig file
error: UART_0_NRF_UARTE (defined at drivers/serial/Kconfig.nrfx:38) is assigned in a configuration file, but is not directly user-configurable (has no prompt). It gets its value indirectly from other symbols. See http://docs.zephyrproject.org/latest/kconfig.html#CONFIG_UART_0_NRF_UARTE and/or look up UART_0_NRF_UARTE in the menuconfig/guiconfig interface. The Application Development Primer, Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful too. CMake Error at C:/ncs/v2.4.0/zephyr/cmake/modules/kconfig.cmake:339 (message): command failed with return code: 1 Call Stack (most recent call first): C:/ncs/v2.4.0/nrf/cmake/modules/kconfig.cmake:29 (include) C:/ncs/v2.4.0/zephyr/cmake/modules/zephyr_default.cmake:115 (include) C:/ncs/v2.4.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include) C:/ncs/v2.4.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:97 (include_boilerplate) CMakeLists.txt:8 (find_package) -- Configuring incomplete, errors occurred! See also "D:/Projects/GE/Bluetooth_nRF2840/workspace/central_uart/build/CMakeFiles/CMakeOutput.log". See also "D:/Projects/GE/Bluetooth_nRF2840/workspace/central_uart/build/CMakeFiles/CMakeError.log". FAILED: build.ninja C:\ncs\toolchains\31f4403e35\opt\bin\cmake.exe --regenerate-during-build -SD:\Projects\GE\Bluetooth_nRF2840\workspace\central_uart -BD:\Projects\GE\Bluetooth_nRF2840\workspace\central_uart\build ninja: error: rebuilding 'build.ninja': subcommand failed FATAL ERROR: command exited with status 1: 'C:\ncs\toolchains\31f4403e35\opt\bin\cmake.EXE' --build 'd:\Projects\GE\Bluetooth_nRF2840\workspace\central_uart\build'
Try:
CONFIG_UART_ASYNC_API=y CONFIG_UART_0_INTERRUPT_DRIVEN=n CONFIG_UART_0_ASYNC=y
