HI ,
I need dma support for the uart protocol but I can't seem to locate any examples of it being used with an uart. Can anyone give support on this?
regards ,
Goudam
HI ,
regards ,
Goudam
Which SDK are you using? Most of the UART examples we have use EasyDMA, but not all use it in an efficient way for receive operations.
For nRF Connect SDK, I would recommend you to look at the example from lession 5 in Nordic Developer Academy: nRF Connect SDK Fundamentals course, or this sample.
For nRF5 SDK, the libUARTE example is the recommended example for UART with EasyDMA.
Jørgen
I am using nrf connect sdk v2.4.0.
I'm using this example: github.com/.../main.c but I'm getting an ENOSYS error.
I'm using a xiao ble board with a nrf52840 controller.
Goudam
Goudam said:I'm using this example: github.com/.../main.c but I'm getting an ENOSYS error.
Where/when do you get this error? Have you made any modifications to the sample/configuration?
Goudam said:I'm using a xiao ble board with a nrf52840 controller.
To enable EasyDMA (UARTE), you should also add the following to your board DTS or overlay file for the uart0/uart1 devices:
&uart0 { compatible = "nordic,nrf-uarte"; status = "okay"; current-speed = <115200>; pinctrl-0 = <&uart0_default>; pinctrl-1 = <&uart0_sleep>; pinctrl-names = "default", "sleep"; };
I didn't modify anything in the code. In Board DTS itself NRF_UARTE enable
I am noted one more thing CONFIG_UART_INTERRUPT_DRIVEN was enabled by default it makes any issue with ASYNC uart . If its a error means how to disable the CONFIG_UART_INTERRUPT_DRIVEN ?
I am try to disable that in prj.conf file by addingCONFIG_UART_INTERRUPT_DRIVEN=n
