bootloader doesnt start application
there is some weird behavior on my XIAO nrf52840. Im developing omn skd 15.3 am using a secure bootloader.
all of my dfu OTA processes work well but I noticed that some of my chips wont start the application from the bootloader. to be precise I can debug the bootloader up to this pont:
ASSERT((dst_addr % CODE_PAGE_SIZE) == 0);
in the nrf_bootloader_fw_activation.c file (line 81)
after this line the bootloader goes back to its start. this doesnt happen on every chip though so I dont know whats happening at all.
The flash readings of a chip that works and one that doesnt are identical for my firmware.
  • Can you check two working chip firmware as well to see it everything is identical?
    Are there any differences in flashing the firmware to the chip?
  • there is no difference in two working chips.
    flashing no, dfu some with android some with iOS but besides that no difference.
  • Depending upon the nature of the code, and other configurations & tools, there could be differences in the hex file output of different builds. However, I am assuming that you are flashing the same hex file (no rebuilding) to all of your boards, and also using the same procedure and platform (e.g. from the same PC and using the same method etc.).
    And then after flashing you have some good boards and some not working good.
    Good working boards have identical firmware when read-back
    Not working boards have some discrepancies when firmware read-back
    This would typically be the case that there are some issues with the boards, not with the software and tools, but with the hardware.
    Can you test your "not good" boards with other samples, starting from basic ones that does not include DFU and then see whether the firmware read-back is same or not.
  • yeah exactly its the same hex file, same pc, only difference in the DFU is android vs iOS, this might actually output a difference so I will try both and compare the hex files afterwards.
    so no general issues with the XIAO are known to you until now - I thought it might be that this board in particular has an issue.
    though it never had any issues after a normal flash just after at least one DFU process, something might be up there.
    now I at least need to consider to work with this assert, how would you go and use the line of code that I presented in the beginning to kickstart the application while ignoring this assert?
  • no differences after OTA with ios and android but for now both work also (as I said in the beginning it doesnt happen every time but rather in 10 percent of all cases)
