Upgrading app from 2.1.2 to 2.4.0 result with error code #XFOTA: 5,1,-9
I'm trying to upgrade my SDK to 2.4.0 (so I can use the Wi-Fi location)
I'm using SDK 2.1.2
Here is how I do the FOTA:
AT+CEREG=5
OK
AT+CFUN=1
OK
+CEREG: 2,"198D","00048801",7
+CEREG: 5,"198D","00048801",7,,,"11100000","11100000"
AT#XFOTA=8
OK
AT#XFOTA=6
#XFOTA: 3,1,401580,"0.0.0+0"
OK
AT#XFOTA=1,"https://s3.amazonaws.com/firmware.v2.prod.public/app_update.bin",16842753
#XFOTA: 1,0,0
#XFOTA: 1,0,1
#XFOTA: 1,0,1
#XFOTA: 1,0,2
#XFOTA: 1,0,2
#XFOTA: 1,0,3
#XFOTA: 1,0,3
#XFOTA: 1,0,4
#XFOTA: 1,0,4
#XFOTA: 1,0,5
#XFOTA: 1,0,5
#XFOTA: 1,0,6
#XFOTA: 1,0,6
#XFOTA: 1,0,7
#XFOTA: 1,0,7
#XFOTA: 1,0,8
#XFOTA: 1,0,8
#XFOTA: 1,0,9
#XFOTA: 1,0,9
#XFOTA: 1,0,10
#XFOTA: 1,0,11
#XFOTA: 1,0,11
#XFOTA: 1,0,12
#XFOTA: 1,0,12
#XFOTA: 1,0,13
#XFOTA: 1,0,13
#XFOTA: 1,0,14
#XFOTA: 1,0,14
#XFOTA: 1,0,15
#XFOTA: 1,0,15
#XFOTA: 1,0,16
#XFOTA: 1,0,16
#XFOTA: 1,0,17
#XFOTA: 1,0,18
#XFOTA: 1,0,18
#XFOTA: 1,0,19
#XFOTA: 1,0,19
#XFOTA: 1,0,20
#XFOTA: 1,0,20
#XFOTA: 1,0,21
#XFOTA: 1,0,22
#XFOTA: 1,0,22
#XFOTA: 1,0,23
#XFOTA: 1,0,23
#XFOTA: 1,0,24
#XFOTA: 1,0,24
#XFOTA: 1,0,25
#XFOTA: 1,0,25
#XFOTA: 1,0,26
#XFOTA: 1,0,26
#XFOTA: 1,0,27
#XFOTA: 1,0,27
#XFOTA: 1,0,28
#XFOTA: 1,0,28
#XFOTA: 1,0,29
#XFOTA: 1,0,29
#XFOTA: 1,0,30
#XFOTA: 1,0,30
#XFOTA: 1,0,31
#XFOTA: 1,0,31
#XFOTA: 1,0,32
#XFOTA: 1,0,33
#XFOTA: 1,0,33
#XFOTA: 1,0,34
#XFOTA: 1,0,34
#XFOTA: 1,0,35
#XFOTA: 1,0,35
#XFOTA: 1,0,36
#XFOTA: 1,0,36
#XFOTA: 1,0,37
#XFOTA: 1,0,37
#XFOTA: 1,0,38
#XFOTA: 1,0,38
#XFOTA: 1,0,39
#XFOTA: 1,0,39
#XFOTA: 1,0,40
#XFOTA: 1,0,40
#XFOTA: 1,0,41
#XFOTA: 1,0,41
#XFOTA: 1,0,42
#XFOTA: 1,0,43
#XFOTA: 1,0,43
#XFOTA: 1,0,44
#XFOTA: 1,0,44
#XFOTA: 1,0,45
#XFOTA: 1,0,45
#XFOTA: 1,0,46
#XFOTA: 1,0,46
#XFOTA: 1,0,47
#XFOTA: 1,0,47
#XFOTA: 1,0,48
#XFOTA: 1,0,48
#XFOTA: 1,0,49
#XFOTA: 1,0,49
#XFOTA: 1,0,50
#XFOTA: 1,0,50
#XFOTA: 1,0,51
#XFOTA: 1,0,51
#XFOTA: 1,0,52
#XFOTA: 1,0,52
#XFOTA: 1,0,53
#XFOTA: 1,0,54
#XFOTA: 1,0,55
#XFOTA: 1,0,55
#XFOTA: 1,0,56
#XFOTA: 1,0,56
#XFOTA: 1,0,57
#XFOTA: 1,0,57
#XFOTA: 1,0,58
#XFOTA: 1,0,58
#XFOTA: 1,0,59
#XFOTA: 1,0,59
#XFOTA: 1,0,60
#XFOTA: 1,0,60
#XFOTA: 1,0,61
#XFOTA: 1,0,61
#XFOTA: 1,0,62
#XFOTA: 1,0,63
#XFOTA: 1,0,63
#XFOTA: 1,0,64
#XFOTA: 1,0,65
#XFOTA: 1,0,65
#XFOTA: 1,0,66
#XFOTA: 1,0,66
#XFOTA: 1,0,67
#XFOTA: 1,0,67
#XFOTA: 1,0,68
#XFOTA: 1,0,68
#XFOTA: 1,0,69
#XFOTA: 1,0,69
#XFOTA: 1,0,70
#XFOTA: 1,0,71
#XFOTA: 1,0,71
#XFOTA: 1,0,72
#XFOTA: 1,0,72
#XFOTA: 1,0,73
#XFOTA: 1,0,73
#XFOTA: 1,0,74
#XFOTA: 1,0,74
#XFOTA: 1,0,75
#XFOTA: 1,0,76
#XFOTA: 1,0,76
#XFOTA: 1,0,77
#XFOTA: 1,0,77
#XFOTA: 1,0,78
#XFOTA: 1,0,78
#XFOTA: 1,0,79
#XFOTA: 1,0,79
#XFOTA: 1,0,80
#XFOTA: 1,0,80
#XFOTA: 1,0,81
#XFOTA: 1,0,81
#XFOTA: 1,0,82
#XFOTA: 1,0,82
#XFOTA: 1,0,83
#XFOTA: 1,0,83
#XFOTA: 1,0,84
#XFOTA: 1,0,84
#XFOTA: 1,0,85
#XFOTA: 1,0,86
#XFOTA: 1,0,86
#XFOTA: 1,0,87
#XFOTA: 1,0,87
#XFOTA: 1,0,88
#XFOTA: 1,0,88
#XFOTA: 1,0,89
#XFOTA: 1,0,89
#XFOTA: 1,0,90
#XFOTA: 1,0,90
#XFOTA: 1,0,91
#XFOTA: 1,0,91
#XFOTA: 1,0,92
#XFOTA: 1,0,92
#XFOTA: 1,0,93
#XFOTA: 1,0,93
#XFOTA: 1,0,94
#XFOTA: 1,0,94
#XFOTA: 1,0,95
#XFOTA: 1,0,95
#XFOTA: 1,0,96
#XFOTA: 1,0,97
#XFOTA: 1,0,97
#XFOTA: 1,0,98
#XFOTA: 1,0,98
#XFOTA: 1,0,99
#XFOTA: 1,0,99
#XFOTA: 1,0,100
#XFOTA: 4,0
AT#XRESET
OK
Ready
And after the reset nothing happened, I waiting for about 5 minutes and reset my board and nRF didn't respond and I have to reset it at least 3-4 times and I got #XFOTA: 5,1,-9
The SDK remained 2.1.2
Any suggestions what I can do?
    Did you use a static partition configuration?
    In NCS, the flash partitioning when you have multiple images (e.g. a bootloader and an application) happens dynamically on each build. When changing SDK versions, or making changes to your application, the partitions might change, which can cause the new application image to be incompatible with the old bootloader.
    The solution to this problem is to use a static configuration of the bootloader-related partitions.
    You can read more here: https://developer.nordicsemi.com/nRF_Connect_SDK/doc/latest/nrf/scripts/partition_manager/partition_manager.html#static-configuration
    Didrik
  • Hi Didrik,
    I've tried to look at the partitions, but the problem is that I might not have the original partition from the build folder and I have products outside.
    Does that mean I wont be able to upgrade them?
    Is there a way to read the partition from a product that I have?
  • I think this is the partition of the original
    EMPTY_0:
      address: 0xc000
      end_address: 0x10000
      placement:
        before:
        - mcuboot_pad
      region: flash_primary
    EMPTY_1:
      address: 0xea000
      end_address: 0xeb000
      placement:
        after:
        - settings_storage
    EMPTY_2:
      address: 0xe0000
      end_address: 0xe8000
      placement:
        after:
        - mcuboot_secondary
    app:
      address: 0x1c200
      end_address: 0x78000
    mcuboot:
      address: 0x0
      end_address: 0xc000
      placement:
        before:
        - mcuboot_primary
    mcuboot_pad:
      address: 0x10000
      end_address: 0x10200
      placement:
        align:
          start: 0x8000
        before:
        - mcuboot_primary_app
    mcuboot_primary:
      address: 0x10000
      orig_span: &id001
      - tfm
      - app
      - mcuboot_pad
      sharers: 0x1
      span: *id001
    mcuboot_primary_app:
      address: 0x10200
      orig_span: &id002
      - app
      - tfm
      span: *id002
    mcuboot_secondary:
      address: 0x78000
      end_address: 0xe0000
      placement:
        after:
        - mcuboot_primary
        align:
          start: 0x8000
      share_size:
      - mcuboot_primary
    nonsecure_storage:
      address: 0xe8000
      end_address: 0xff000
      orig_span: &id003
      - settings_storage
      - pgps
      span: *id003
    nrf_modem_lib_ctrl:
      address: 0x20008000
      end_address: 0x200084e8
      inside:
      - sram_nonsecure
      placement:
        after:
        - tfm_sram
        - start
      region: sram_primary
    nrf_modem_lib_rx:
      address: 0x2000a4e8
      end_address: 0x2000c4e8
      inside:
      - sram_nonsecure
      placement:
        after:
        - nrf_modem_lib_tx
    nrf_modem_lib_sram:
      address: 0x20008000
      orig_span: &id004
      - nrf_modem_lib_ctrl
      - nrf_modem_lib_tx
      - nrf_modem_lib_rx
      span: *id004
    nrf_modem_lib_tx:
      address: 0x200084e8
      end_address: 0x2000a4e8
      inside:
      - sram_nonsecure
      placement:
        after:
    otp:
      address: 0xff8108
      end_address: 0xff83fc
      region: otp
    pgps:
      address: 0xeb000
      align:
        start: 0x8000
      end_address: 0x100000
      inside:
      - nonsecure_storage
      placement:
        before:
        - end
    settings_storage:
      address: 0xe8000
      end_address: 0xea000
      inside:
      - nonsecure_storage
      placement:
        align:
          start: 0x8000
        before:
        - end
    sram_nonsecure:
      address: 0x20008000
      end_address: 0x20040000
      orig_span: &id005
      - sram_primary
      - nrf_modem_lib_tx
      - nrf_modem_lib_rx
      span: *id005
    sram_primary:
      address: 0x2000c4e8
    sram_secure:
      address: 0x20000000
      end_address: 0x20008000
      orig_span: &id006
      - tfm_sram
      span: *id006
    tfm:
      address: 0x10200
      end_address: 0x1c200
      inside:
      placement:
        before:
        - app
    tfm_nonsecure:
      address: 0x1c200
      orig_span: &id007
      - app
      span: *id007
    tfm_secure:
      address: 0x10000
      orig_span: &id008
      - mcuboot_pad
      - tfm
      span: *id008
    tfm_sram:
      address: 0x20000000
      inside:
      - sram_secure
      placement:
        after:
        - start
    I tried to put is at pm_static as suggested from your link and recompile
    I got this error
    C:\nrf\v2.4.0\nrf\modules\tfm\tfm\boards\common\assert.c:16:9: note: '#pragma message:
    !!!Partition alignment error!!!
    The non-secure start address in pm_static.yml or generated partition.yml is: 0x1c200
    which is not aligned with the SPU region size.
    Refer to the documentation section 'TF-M partition alignment requirements'
    for more information.
    16 | #pragma message "\n\n!!!Partition alignment error!!!"\
    C:\nrf\v2.4.0\nrf\modules\tfm\tfm\boards\common\assert.c:22:2: error: #error "TF-M non-secure start address is not aligned on SPU region size"
    22 | #error "TF-M non-secure start address is not aligned on SPU region size"
    Any suggestion from here?
  • The problem is with the definition of the TF-M partitions. The requirements were tightened in an update, which is what causes the build error.
    However, we don't really need the TF-M partitions to be statically defined, just the MCUBoot and storage related partitions.
    If you change the pm_static.yml to be this, I think it should work:
    mcuboot:
      address: 0x0
      end_address: 0xc000
      placement:
        before:
        - mcuboot_primary
    EMPTY_0:
      address: 0xc000
      placement:
        before:
        - mcuboot_pad
    mcuboot_primary:
      address: 0x10000
      span: [tfm, app, mcuboot_pad]
    mcuboot_pad:
      address: 0x10000
      placement:
        align:
          start: 0x8000
        before:
    tfm:
      address: 0x10200
      inside:
      placement:
        before:
        - app
    tfm_secure:
      address: 0x10000
      orig_span: &id008
      - mcuboot_pad
      - tfm
      span: *id008
    tfm_nonsecure:
      address: 0x20000
      orig_span: &id007
      - app
      span: *id007
    mcuboot_secondary:
      address: 0x78000
      placement:
        after:
        - mcuboot_primary
        align:
          start: 0x8000
      share_size:
      - mcuboot_primary
    EMPTY_1:
      address: 0xe0000
      placement:
        after:
        - mcuboot_secondary
    nonsecure_storage:
      address: 0xe8000
      span: [settings_storage, pgps]
    settings_storage:
      address: 0xe8000
      inside:
      - nonsecure_storage
      placement:
        align:
          start: 0x8000
        before:
        - end
    EMPTY_2:
      address: 0xea000
      placement:
        after:
        - settings_storage
    settings_storage:
      address: 0xe8000
      inside:
      - nonsecure_storage
      placement:
        align:
          start: 0x8000
        before:
        - end
    EMPTY_3:
      address: 0xea000
    There's a couple of things to note:
    Firstly, there are quite a few empty partitions. These are needed to fill the "gaps" left between your old partitions. It might be possible to use them for application storage, but not for getting more space for the application itself.
    Secondly, I've increased the TF-M partition. This is to avoid getting a flash overflow in the TF-M partition, but depending on the size of TF-M, you might be able to reduce it by 32kB, thus freeing that space for the application.
    This configuration reduces the size of the TF-M partition, which makes the application partition bigger:
    mcuboot:
      address: 0x0
      end_address: 0xc000
      placement:
        before:
        - mcuboot_primary
    EMPTY_0:
      address: 0xc000
      placement:
        before:
        - mcuboot_pad
    mcuboot_primary:
      address: 0x10000
    mcuboot_pad:
      address: 0x10000
      placement:
        align:
          start: 0x8000
        before:
    tfm:
      address: 0x10200
      inside:
      placement:
        before:
        - app
    tfm_secure:
      address: 0x10000
      orig_span: &id008
      - mcuboot_pad
      - tfm
      span: *id008
    tfm_nonsecure:
      address: 0x18000
      orig_span: &id007
      - app
      span: *id007
    mcuboot_secondary:
      address: 0x78000
      placement:
        after:
        - mcuboot_primary
        align:
          start: 0x8000
      share_size:
      - mcuboot_primary
    EMPTY_1:
      address: 0xe0000
      placement:
        after:
        - mcuboot_secondary
    nonsecure_storage:
      address: 0xe8000
    settings_storage:
      address: 0xe8000
      inside:
      - nonsecure_storage
      placement:
        align:
          start: 0x8000
        before:
        - end
    EMPTY_2:
      address: 0xea000
      placement:
        after:
        - settings_storage
    settings_storage:
      address: 0xe8000
      inside:
      - nonsecure_storage
      placement:
        align:
          start: 0x8000
        before:
        - end
    EMPTY_3:
      address: 0xea000
    If you are able to build your project successfully with this configuration, you might want to use this one instead.
    Also, you should note that I have only tested these configurations by building the hello_world sample, so you need to check that they work for your project.
  • Hi Didrik,
    Thanks for replying
    I changed according to your suggestions
    I've tried this and received:
    [407/427] Linking C static library zephyr\kernel\libkernel.a
    [408/427] Linking C executable zephyr\zephyr_pre0.elf
    FAILED: zephyr/zephyr_pre0.elf zephyr/zephyr_pre0.map
    cmd.exe /C "cd . && C:\nordic\toolchains\31f4403e35\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-gcc.exe -gdwarf-4 @CMakeFiles\zephyr_pre0.rsp -o zephyr\zephyr_pre0.elf && cmd.exe /C "cd /D C:\nrf\v2.4.0\nrf\applications\serial_lte_modem\build\zephyr && C:\nordic\toolchains\31f4403e35\opt\bin\cmake.exe -E echo ""
    c:/nordic/toolchains/31f4403e35/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe: zephyr\zephyr_pre0.elf section `text' will not fit in region `FLASH'
    c:/nordic/toolchains/31f4403e35/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe: region `FLASH' overflowed by 95500 bytes
    collect2.exe: error: ld returned 1 exit status
    and for this I received:
    [406/427] Linking C static library modules\nrfxlib\nrfxlib\nrf_security\src\zephyr\libmbedtls_zephyr.a
    c:/nordic/toolchains/31f4403e35/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe: region `FLASH' overflowed by 62732 bytes
    FATAL ERROR: command exited with status 1: 'C:\nordic\toolchains\31f4403e35\opt\bin\cmake.EXE' --build 'c:\nrf\v2.4.0\nrf\applications\serial_lte_modem\build'
    We wont use PGPS only AGPS, maybe this can help?
