Dear DevZone,
I am trying to share a SPI instance between an SD card and an other peripheral. I am working with nRF52840.
I already opened a ticket back in time in devzone.nordicsemi.com/.../sd-card-disk_initialization-fails-when-the-fatfs-example-is-integrated-in-my-fw-project for initial configuration of the fatfs example.
Now, the fatfs example is correctly initializing the board if no other SPI periherals are initialized.
However, if I try to initialize my other peripheral before the fatfs example, the other peripheral correctly initializes, but the fatfs example goes in BREAKPOINT condition when trying to initialize the disk (disk_initialization) during spi setup. Here the SPI initialization from the other peripheral. I deassert the CS pin after the other peripheral initialization
// spi_master_init: function that initializes the SPI master, its pins and the order in which it sends the bits on the bus uint32_t spi_master_init(void) { uint32_t err_code; nrf_drv_spi_config_t spi_config = NRF_DRV_SPI_DEFAULT_CONFIG; spi_config.ss_pin = NRF_DRV_SPI_PIN_NOT_USED; // unconnected, we are going to use a custom function to switch between SSx spi_config.miso_pin = SPI_MISO_PIN; spi_config.mosi_pin = SPI_MOSI_PIN; spi_config.sck_pin = SPI_SCK_PIN; spi_config.bit_order = SPI_CONFIG_ORDER_MsbFirst; err_code = nrf_drv_spi_init(&spi, &spi_config, spi_event_handler, NULL); APP_ERROR_CHECK(err_code); }
The same (but specular) happens if I try to run before the fatfs example and then initialize the other peripheral: the fatfs correctly initializes the SD card, but then the SPI initialization fails with a BREAKPOINT condition when it tryies to do a transfer. Here the two sequences of operations:
int main(void) { status = INIT; ret_code_t err_code; uint32_t time_ticks; init_message_data(); bsp_board_init(BSP_INIT_LEDS); gpio_init(); // // initialization of SPI protocol err_code = spi_master_init(); //******************AD7147 initialization********************************* // this call initializes the converters CDCInit(); //******************************************************************************************* // some delay needed to allow the previous operations to be successfull nrf_delay_ms(1000); //******************SD card initialization********************************* APP_ERROR_CHECK(NRF_LOG_INIT(NULL)); NRF_LOG_DEFAULT_BACKENDS_INIT(); // this call initializes the SD card fatfs_example(); //*******************************************************************************************
Here the breakpoint condition - NRF_LOG_ERROR("ERROR %u [%s] at %s:%u\r\nPC at: 0x%08x",:
case NRF_FAULT_ID_SDK_ERROR: { error_info_t * p_info = (error_info_t *)info; NRF_LOG_ERROR("ERROR %u [%s] at %s:%u\r\nPC at: 0x%08x", p_info->err_code, nrf_strerror_get(p_info->err_code), p_info->p_file_name, p_info->line_num, pc); NRF_LOG_ERROR("End of error report"); break; } default: NRF_LOG_ERROR("UNKNOWN FAULT at 0x%08X", pc); break; } #endif NRF_BREAKPOINT_COND;
Which can be the issue?
Thank you very much,
best regards
Gianluca
