Sharing SPI interface between SD card and other peripheral
Dear DevZone,
I am trying to share a SPI instance between an SD card and an other peripheral. I am working with nRF52840.
I already opened a ticket back in time in devzone.nordicsemi.com/.../sd-card-disk_initialization-fails-when-the-fatfs-example-is-integrated-in-my-fw-project for initial configuration of the fatfs example.
Now, the fatfs example is correctly initializing the board if no other SPI periherals are initialized.
However, if I try to initialize my other peripheral before the fatfs example, the other peripheral correctly initializes, but the fatfs example goes in BREAKPOINT condition when trying to initialize the disk (disk_initialization) during spi setup.  Here the SPI initialization from the other peripheral. I deassert the CS pin after the other peripheral initialization
// spi_master_init: function that initializes the SPI master, its pins and the order in which it sends the bits on the bus
uint32_t spi_master_init(void)
	uint32_t err_code;
        nrf_drv_spi_config_t spi_config = NRF_DRV_SPI_DEFAULT_CONFIG;
        spi_config.ss_pin   = NRF_DRV_SPI_PIN_NOT_USED;                             // unconnected, we are going to use a custom function to switch between SSx
        spi_config.miso_pin = SPI_MISO_PIN;
        spi_config.mosi_pin = SPI_MOSI_PIN;
        spi_config.sck_pin  = SPI_SCK_PIN;
	spi_config.bit_order = SPI_CONFIG_ORDER_MsbFirst;
        err_code = nrf_drv_spi_init(&spi, &spi_config, spi_event_handler, NULL);
The same (but specular) happens if I try to run before the fatfs example and then initialize the other peripheral: the fatfs correctly initializes the SD card, but then the SPI initialization fails with a BREAKPOINT condition when it tryies to do a transfer. Here the two sequences of operations:
    status = INIT;
    ret_code_t err_code;
    uint32_t time_ticks;
    init_message_data();
    gpio_init();
//    // initialization of SPI protocol
    err_code = spi_master_init();
//******************AD7147 initialization*********************************
    // this call initializes the converters
    CDCInit();
    // some delay needed to allow the previous operations to be successfull
    nrf_delay_ms(1000);
//******************SD card initialization*********************************
    // this call initializes the SD card
    fatfs_example();
Here the breakpoint condition - NRF_LOG_ERROR("ERROR %u [%s] at %s:%u\r\nPC at: 0x%08x",:
        case NRF_FAULT_ID_SDK_ERROR:
            error_info_t * p_info = (error_info_t *)info;
                          p_info->err_code,
                          nrf_strerror_get(p_info->err_code),
                          p_info->p_file_name,
                          p_info->line_num,
                          pc);
             NRF_LOG_ERROR("End of error report");
            NRF_LOG_ERROR("UNKNOWN FAULT at 0x%08X", pc);
    NRF_BREAKPOINT_COND;
Which can be the issue?
Thank you very much,
best regards
Gianluca
  • I don't know for sure whether I have exact answer for your query or not,
    but we can see in the fatfs example that first static initializations are done and then there are two steps namely disk-initialization and disk-mounting. After these steps you can read and write from the disk. Similarly, afterwards we need to unmount and then uninitialize the disk if we want to use the other peripheral. I can see that just going through fatfs_example function takes approximately 10ms.
