UART async UART_RX_RDY timeout
I'm currently working on a project where I use the UART in async mode.
I'm giving a timeout parameter to the uart_rx_enable() function in order to treat the UART_RX_RDY event as an End Of Frame event.
The problem is that when the buffer is full the UART_RX_RDY event is also generated before switching to the next buffer without taking into account the timeout value.
Is there a way to know if the event UART_RX_RDY has been generated specifically because of a timeout and not because of a buffer full/switch event ?
Regards
  • Hi
    Ok thanks for your clarification, I understand now.
    Whenever you receive an update with a length shorter than the expected length you can assume that a new update will come later, and wait for the second interrupt before you process the packet.
    It is not possible in my case because the frames can have variable length (SoF marker + TLV format + CRC).
    If I understand you correctly you would want to be able to verify whether or not the RX_RDY event in question was caused by a full buffer or a timeout?
    Yes, I think it would be interesting to have access to a flag that specify the source of the RX_RDY event.
    I implemented a piece of code that search for a valid frame on every RX_RDY event.
    Thanks.
    Best regards
    Alexandre
  • Hi Alexandre
    Have you considered adding a length field after the SoF marker?
    It is common to include the length in the header when sending variably sized packets.
    Best regards
    Torbjørn
  • Hi
    Yes this is included in the TLV format (type-length-value).
    I said it was not possible because I thought you were talking about fixed size frame in which case I know if the frame is too short before parsing it.
    In my case I need to parse the RX buffer to search for a valid frame on every RX event in order to find this length field, then I can compare the received data size with the length field value and skip if not received enough data.
    But it works great now so there is no more issue.
    I just had to put more time on it than I originally thought because of this timeout flag not being available.
    Thanks for your help Slight smile
    Best regards
    Alexandre
  • Hi Alexandre
    Of course, I forgot about the TLV term Wink
    Either way, good to hear you got a solution you are happy with. I will consider the case resolved then Slight smile
    Best regards
    Torbjørn
1 2
