multi-nus peripheral nrf52833
Hi All!
Hope you are doing well! I am using the multi-NUS-master.zip, https://github.com/NordicMatt/multi-NUS.
Converted the above-mentioned code to NCS version 2.0.2 and for peripheral_uart I am using 2.3.0 using Vscode studio as an IDE.
I set one device as Central(nrf52833DK) and loaded the above-mentioned code with some changes to work it for coded phy.
and 2 more devices (nrf52833DK and custom (nrf52833)) loaded with peripheral_uart code (coded phy).
Everything works fine. Both the peripherals connect and disconnect with bidirectional data transfer.
Now the issue I am facing is that,
1) Sometimes 2 out of 10 times, when I reset both the peripherals to connect again with the central, the central device not scanning the peripherals
Although both are advertising as I reset both.
2)To solve the above point, when I reset the central then it connects both the peripherals again and starts communication. Central is not in a hang state because hello messages are seen at the dock light.
3)Sometimes 3 out of 10 times, the custom board (nrf52833) stops communication with the central automatically so need to reset it. But it never happened with peripheral (DK).
4)Is there any filter on the Mac address? .Because the Custom board address starts with F7:13 and DK from E2:2B.malfuncationing behaviour observed with central as mentioned in point #  3
I have attached the central converted code to ncs 2.0.2
 * Copyright (c) 2018 Nordic Semiconductor ASA
/** @file
 *  @brief Nordic UART Service Client sample
#include <errno.h>
#include <zephyr/kernel.h>
#include <zephyr/device.h>
#include <zephyr/sys/byteorder.h>
#include <zephyr/bluetooth/hci.h>
#include <zephyr/bluetooth/conn.h>
#include <zephyr/bluetooth/uuid.h>
#include <zephyr/bluetooth/gatt.h>
#include <bluetooth/services/nus.h>
#include <bluetooth/services/nus_client.h>
#include <bluetooth/gatt_dm.h>
#include <bluetooth/scan.h>
#include <bluetooth/conn_ctx.h>
#include <zephyr/settings/settings.h>
#include <zephyr/drivers/uart.h>
//#include <bluetooth/conn.h>
#define LOG_MODULE_NAME central_uart
LOG_MODULE_REGISTER(LOG_MODULE_NAME,LOG_LEVEL_DBG);
/* UART payload buffer element size. */
#define UART_BUF_SIZE 20   // 20
#define KEY_PASSKEY_ACCEPT DK_BTN1_MSK
#define KEY_PASSKEY_REJECT DK_BTN2_MSK
#define NUS_WRITE_TIMEOUT K_MSEC(150)
#define UART_WAIT_FOR_BUF_DELAY K_MSEC(50)
#define UART_RX_TIMEOUT 50
#define ROUTED_MESSAGE_CHAR '*'
#define BROADCAST_INDEX 99
static const struct device *uart = DEVICE_DT_GET(DT_NODELABEL(uart0));
static struct k_work_delayable uart_work;
static K_SEM_DEFINE(nus_write_sem, 0, 1);
struct uart_data_t {
	void *fifo_reserved;
	uint8_t  data[UART_BUF_SIZE];
	uint16_t len;
BT_CONN_CTX_DEF(conns, CONFIG_BT_MAX_CONN, sizeof(struct bt_nus_client));
static K_FIFO_DEFINE(fifo_uart_tx_data);
static K_FIFO_DEFINE(fifo_uart_rx_data);
static struct bt_conn *default_conn;
static bool routedMessage = false;
static bool messageStart = true;
static struct bt_nus_client nus_client;
struct bt_le_scan_param m_scan_param = {
		.type     = BT_LE_SCAN_TYPE_ACTIVE,
		.interval = BT_GAP_SCAN_FAST_INTERVAL,
		.window   = BT_GAP_SCAN_FAST_WINDOW,
		.options  = BT_LE_SCAN_OPT_CODED | BT_LE_SCAN_OPT_NO_1M
static void ble_data_sent(struct bt_nus_client *nus, uint8_t err,
					const uint8_t *const data, uint16_t len)
	ARG_UNUSED(nus);
	struct uart_data_t *buf;
	// Retrieve buffer context. //
	buf = CONTAINER_OF(data, struct uart_data_t, data);
	k_free(buf);
	k_sem_give(&nus_write_sem);
	if (err) {
		LOG_WRN("ATT error code: 0x%02X", err);
static void ble_data_sent(uint8_t err, const uint8_t *const data, uint16_t len)
	if (err) {
/*	New function for sending data into the multi-NUS
* 	Extensions to the behavior of message routing can be made here.
*	If the first character is *, this indicates a routed message.
*	If the first character is not *, then this is a broadcast message sent to all peers.
* 	Iaf the message is routed, the two characters after the * will be read as the peer number
*	and the message will be sent only to that peer. Numbers must be written as two digits, i.e 01 for 1.
*	The default behavior will be to broadcast in the case of failure of message parsing.
static int multi_nus_send(struct uart_data_t *buf){
	int err = 0;
	char * message = buf->data;
	int length = buf->len;
	static bool broadcast = false;
	static int nus_index = 0;
	LOG_INF("Multi-Nus Send");
	/*How many connections are there in the Connection Context Library?*/
	const size_t num_nus_conns = bt_conn_ctx_count(&conns_ctx_lib);
	/*Handle the routing of the message only at the beginning of the message*/
	if (messageStart) {
		messageStart = false;
		/*Check if it's a routed message*/
		if (message[0] == ROUTED_MESSAGE_CHAR) {
			routedMessage = true;
			/*Determine who the intended recipient is*/
			char str[2];
			str[0] = message[1];
			str[1] = message[2];
			nus_index = atoi(str);
			/*Is this a number that makes sense?*/
			if ((nus_index >= 0) && (nus_index < num_nus_conns)){
				broadcast = false;
				/*Move the data buffer pointer to after the recipient info and
				shorten the length*/
				message =  &message[3];
				length = length - 3;
			} else if (nus_index == BROADCAST_INDEX) {
				broadcast = true;
		} else {
			broadcast = true;
	/*	If it's a routed message, send it to that guy.
	*	If it's not, broadcast it to everyone.
	if (broadcast == false){
		const struct bt_conn_ctx *ctx =
				bt_conn_ctx_get_by_id(&conns_ctx_lib, nus_index);
		LOG_INF("Trying to send to server %d", nus_index);
		if (ctx) {
			struct bt_nus_client *nus_client = ctx->data;
			if (nus_client) {
				err = bt_nus_client_send(nus_client,
								     message,
								     length);
				if (err) {
					LOG_WRN("Failed to send data over BLE connection"
						"(err %d)",
						err);
				}else{
					LOG_INF("Sent to server %d: %s", nus_index, log_strdup(message));
				err = k_sem_take(&nus_write_sem,
							NUS_WRITE_TIMEOUT);
				if (err) {
					LOG_WRN("NUS send timeout");
			bt_conn_ctx_release(&conns_ctx_lib,
							(void *)ctx->data);
	}else{//Broadcast message
		LOG_INF("Broadcast");
		for (int i = 0; i < num_nus_conns; i++) {
				bt_conn_ctx_get_by_id(&conns_ctx_lib, i);
			if (ctx) {
				if (nus_client) {
								     message,
								     length);
					if (err) {
							"(err %d)",
							err);
					}else{
						LOG_INF("Sent to server %d: %s", i, log_strdup(message));
							    (void *)ctx->data);
							 NUS_WRITE_TIMEOUT);
					if (err) {
	if ( (message[length-1] == '\n') || (message[length-1] == '\r') ) {
	return err;
/*	This function has been updated to add the ability for a peer to route a message by
*	appending a '*' as in the multi-NUS send function. So a peer could send the message
*	*00 to send a message to peer 0. If the peer sends a *99, that message is broadcast to
*	all peers
static uint8_t ble_data_received(struct bt_nus_client *nus,
						const uint8_t *data, uint16_t len)
	ARG_UNUSED(nus);
	int err;
	for (uint16_t pos = 0; pos != len;) {
		struct uart_data_t *tx = k_malloc(sizeof(*tx));
		if (!tx) {
			LOG_WRN("Not able to allocate UART send data buffer");
			return BT_GATT_ITER_CONTINUE;
		/* Keep the last byte of TX buffer for potential LF char. */
		size_t tx_data_size = sizeof(tx->data) ;//- 1; Added
		if ((len - pos) > tx_data_size) {
			tx->len = tx_data_size;
		} else {
			tx->len = (len - pos);
		memcpy(tx->data, &data[pos], tx->len);
		pos += tx->len;
		/* Append the LF character when the CR character triggered
		 * transmission from the peer.
		if ((pos == len) && (data[len - 1] == '\r')) {
			tx->data[tx->len] = '\n';
			tx->len++;
        /*	Routed messages. See the comments above.
		*	Check for *, if there's a star, send it over to the multi-nus send function
	    if (( data[0] == '*') || (routedMessage == true) ) {
			multi_nus_send(tx);
		err = uart_tx(uart, tx->data, tx->len, SYS_FOREVER_MS);
		if (err) {
			k_fifo_put(&fifo_uart_tx_data, tx);
static void uart_cb(const struct device *dev, struct uart_event *evt, void *user_data)
	ARG_UNUSED(dev);
	static size_t aborted_len;
	static uint8_t *aborted_buf;
	static bool disable_req;
	switch (evt->type) {
	case UART_TX_DONE:
		LOG_DBG("UART_TX_DONE");
		if ((evt->data.tx.len == 0) ||
		    (!evt->data.tx.buf)) {
			return;
		if (aborted_buf) {
			buf = CONTAINER_OF(aborted_buf, struct uart_data_t,
					   data);
			aborted_buf = NULL;
			aborted_len = 0;
		} else {
			buf = CONTAINER_OF(evt->data.tx.buf,
					   struct uart_data_t,
					   data);
		k_free(buf);
		buf = k_fifo_get(&fifo_uart_tx_data, K_NO_WAIT);
		if (!buf) {
			return;
		if (uart_tx(uart, buf->data, buf->len, SYS_FOREVER_MS)) {
			LOG_WRN("Failed to send data over UART");
	case UART_RX_RDY:
		LOG_DBG("UART_RX_RDY");
		buf = CONTAINER_OF(evt->data.rx.buf, struct uart_data_t, data);
		buf->len += evt->data.rx.len;
		if (disable_req) {
			return;
		if ((evt->data.rx.buf[buf->len - 1] == '\n') ||
		    (evt->data.rx.buf[buf->len - 1] == '\r')) {
			disable_req = true;
			uart_rx_disable(uart);
	case UART_RX_DISABLED:
		LOG_DBG("UART_RX_DISABLED");
		disable_req = false;
		buf = k_malloc(sizeof(*buf));
		if (buf) {
			buf->len = 0;
		} else {
			LOG_WRN("Not able to allocate UART receive buffer");
			k_work_reschedule(&uart_work, UART_WAIT_FOR_BUF_DELAY);
			return;
		uart_rx_enable(uart, buf->data, sizeof(buf->data),
			       UART_RX_TIMEOUT);
	case UART_RX_BUF_REQUEST:
		LOG_DBG("UART_RX_BUF_REQUEST");
		if (buf) {
			buf->len = 0;
			uart_rx_buf_rsp(uart, buf->data, sizeof(buf->data));
		} else {
	case UART_RX_BUF_RELEASED:
		LOG_DBG("UART_RX_BUF_RELEASED");
		buf = CONTAINER_OF(evt->data.rx_buf.buf, struct uart_data_t,
				   data);
		if (buf->len > 0) {
			k_fifo_put(&fifo_uart_rx_data, buf);
		} else {
			k_free(buf);
	case UART_TX_ABORTED:
		LOG_DBG("UART_TX_ABORTED");
		if (!aborted_buf) {
			aborted_buf = (uint8_t *)evt->data.tx.buf;
		aborted_len += evt->data.tx.len;
				   data);
		uart_tx(uart, &buf->data[aborted_len],
			buf->len - aborted_len, SYS_FOREVER_MS);
static void uart_work_handler(struct k_work *item)
	if (buf) {
		buf->len = 0;
	} else {
		return;
	uart_rx_enable(uart, buf->data, sizeof(buf->data), UART_RX_TIMEOUT);
static int uart_init(void)
	int err;
	struct uart_data_t *rx;
	if (!device_is_ready(uart)) {
		LOG_ERR("UART device not ready");
		return -ENODEV;
	rx = k_malloc(sizeof(*rx));
	if (rx) {
		rx->len = 0;
	} else {
		return -ENOMEM;
	k_work_init_delayable(&uart_work, uart_work_handler);
	err = uart_callback_set(uart, uart_cb, NULL);
	if (err) {
		return err;
	return uart_rx_enable(uart, rx->data, sizeof(rx->data),
			      UART_RX_TIMEOUT);
static void discovery_complete(struct bt_gatt_dm *dm,
			       void *context)
	struct bt_nus_client *nus = context;
	LOG_INF("Service discovery completed");
	bt_gatt_dm_data_print(dm);
	bt_nus_handles_assign(dm, nus);
	bt_nus_subscribe_receive(nus);
	bt_gatt_dm_data_release(dm);
    // Added code from multinus
	int err = bt_scan_start(BT_SCAN_TYPE_SCAN_ACTIVE);
	if (err) {
		LOG_ERR("Scanning failed to start (err %d)", err);
	} else {
		LOG_INF("Scanning started");
	/*	Send a message to the new NUS server informing it of its ID in this
	*	mini-network
	*	The new NUS will have been added to the connection context library and so
	* 	will be the highest index as they are added incrementally upwards.
	*	This is a bit of a workaround because in this function, I don't know
	*	the ID of this connection which is the piece of info I want to transmit.
	size_t nus_index = 99;
	/*	This is a little inelegant but we must get the index of the device to
	* 	convey it. This bit sends the index number to the peripheral.
	for (size_t i = 0; i < num_nus_conns; i++) {
		if (ctx) {
			if (ctx->data == nus) {
				nus_index = i;
				char message[3];
				sprintf(message, "%d", nus_index);
				message[2] = '\r';
				int length = 3;
				err = bt_nus_client_send(nus, message, length);
				if (err) {
						"(err %d)",
						err);
				} else {
						    (void *)ctx->data);
			} else {
						    (void *)ctx->data);
static void discovery_service_not_found(struct bt_conn *conn,
					void *context)
	LOG_INF("Service not found");
static void discovery_error(struct bt_conn *conn,
			    int err,
			    void *context)
	LOG_WRN("Error while discovering GATT database: (%d)", err);
struct bt_gatt_dm_cb discovery_cb = {
	.completed         = discovery_complete,
	.service_not_found = discovery_service_not_found,
	.error_found       = discovery_error,
static void gatt_discover(struct bt_conn *conn)
	int err;
	if (conn != default_conn) {
		return;
	err = bt_gatt_dm_start(conn,
			       BT_UUID_NUS_SERVICE,
			       &discovery_cb,
			       &nus_client);
	if (err) {
		LOG_ERR("could not start the discovery procedure, error "
			"code: %d", err);
	int err;
		bt_conn_ctx_get(&conns_ctx_lib, conn);
	if (!nus_client) {
		return;
			       &discovery_cb,
			       nus_client);
	if (err) {
			"code: %d", err);
	bt_conn_ctx_release(&conns_ctx_lib, (void *) nus_client);
static void exchange_func(struct bt_conn *conn, uint8_t err, struct bt_gatt_exchange_params *params)
	if (!err) {
		LOG_INF("MTU exchange done");
	} else {
		LOG_WRN("MTU exchange failed (err %" PRIu8 ")", err);
static void connected(struct bt_conn *conn, uint8_t conn_err)
	int err;
    struct bt_nus_client_init_param init = {   // code added
		.cb = {
			.received = ble_data_received,
			.sent = ble_data_sent,
	if (conn_err) {
		LOG_INF("Failed to connect to %s (%d)", log_strdup(addr),
			conn_err);
			printk("Failed to connect to %s (%d)", log_strdup(addr),
			conn_err);
		if (default_conn == conn) {
			bt_conn_unref(default_conn);
			default_conn = NULL;
			if (err) {
					err);
					printk("Scanning failed to start (err %d)",
					err);
		return;
	LOG_INF("Connected: %s", log_strdup(addr));
	// code added
	/*Allocate memory for this connection using the connection context library. For reference,
	this code was taken from hids.c
	struct bt_nus_client *nus_client = bt_conn_ctx_alloc(&conns_ctx_lib, conn);
	if (!nus_client) {
		LOG_WRN("There is no free memory to "
			"allocate the connection context");
	memset(nus_client, 0, bt_conn_ctx_block_size_get(&conns_ctx_lib));
	err = bt_nus_client_init(nus_client, &init);
	bt_conn_ctx_release(&conns_ctx_lib, (void *)nus_client);
	if (err) {
		LOG_ERR("NUS Client initialization failed (err %d)", err);
	}else{
		LOG_INF("NUS Client module initialized");
	gatt_discover(conn);
	static struct bt_gatt_exchange_params exchange_params;
	exchange_params.func = exchange_func;
	err = bt_gatt_exchange_mtu(conn, &exchange_params);
	if (err) {
		LOG_WRN("MTU exchange failed (err %d)", err);
	err = bt_conn_set_security(conn, BT_SECURITY_L2);
	if (err) {
		LOG_WRN("Failed to set security: %d", err);
	err = bt_scan_stop();
	if ((!err) && (err != -EALREADY)) {
		LOG_ERR("Stop LE scan failed (err %d)", err);
	int err;
	LOG_INF("Disconnected: %s (reason %u)", log_strdup(addr),
		reason);
    err = bt_conn_ctx_free(&conns_ctx_lib, conn);  // code added
	if (err) {
		LOG_WRN("The memory was not allocated for the context of this "
			"connection.");
	bt_conn_unref(conn);
	if (default_conn != conn) {
		return;
	if (err) {
			err);
static void security_changed(struct bt_conn *conn, bt_security_t level,
			     enum bt_security_err err)
	if (!err) {
		LOG_INF("Security changed: %s level %u", log_strdup(addr),
			level);
	} else {
		LOG_WRN("Security failed: %s level %u err %d", log_strdup(addr),
			level, err);
BT_CONN_CB_DEFINE(conn_callbacks) = {
	.connected = connected,
	.disconnected = disconnected,
	.security_changed = security_changed
static void scan_filter_match(struct bt_scan_device_info *device_info,
			      struct bt_scan_filter_match *filter_match,
			      bool connectable)
	int err;
	struct bt_conn_le_create_param *conn_params;
	bt_addr_le_to_str(device_info->recv_info->addr, addr, sizeof(addr));
    printk("Filters matched. Address: %s connectable: %s\n",
		addr, connectable ? "yes" : "no");
	if (err) {
		printk("Stop LE scan failed (err %d)\n", err);
	conn_params = BT_CONN_LE_CREATE_PARAM(
			BT_CONN_LE_OPT_CODED | BT_CONN_LE_OPT_NO_1M,
			BT_GAP_SCAN_FAST_INTERVAL);
	err = bt_conn_le_create(device_info->recv_info->addr, conn_params,
				BT_LE_CONN_PARAM_DEFAULT,
				&default_conn);
	if (err) {
		printk("Create conn failed (err %d)\n", err);
		if (err) {
			printk("Scanning failed to start (err %d)\n", err);
			return;
	printk("Connection pending\n");
//BT_SCAN_CB_INIT(scan_cb, scan_filter_match, NULL, NULL, NULL);
//BT_SCAN_CB_INIT(scan_cb, scan_filter_match, NULL,scan_connecting_error, scan_connecting);
static void scan_connecting_error(struct bt_scan_device_info *device_info)
	LOG_WRN("Connecting failed");
static void scan_connecting(struct bt_scan_device_info *device_info,
	default_conn = bt_conn_ref(conn);
static int nus_client_init(void)
	int err;
		.cb = {
	err = bt_nus_client_init(&nus_client, &init);
	if (err) {
		return err;
	return err;
static void scan_init(void)
	int err;
	// Use active scanning and disable duplicate filtering to handle any
	 // devices that might update their advertising data at runtime.
    const char *perName1="Nordic_UART_Service";
    struct bt_le_conn_param m_conn_param={
        .interval_min=120,
		.interval_max=220,
		.timeout=100,
	struct bt_scan_init_param scan_init = {
		.connect_if_match = 1,            //1
		.scan_param = &m_scan_param,
		.conn_param = &m_conn_param,     //NULL              //
	bt_scan_init(&scan_init);
	bt_scan_cb_register(&scan_cb);
	//err = bt_scan_filter_add(BT_SCAN_FILTER_TYPE_UUID, BT_UUID_NUS_SERVICE);
     err = bt_scan_filter_add(BT_SCAN_FILTER_TYPE_NAME,perName1);
	if (err) {
		printk("Scanning filters cannot be set (err %d)\n", err);
		return;
	//err = bt_scan_filter_enable(BT_SCAN_UUID_FILTER, false);
    err = bt_scan_filter_enable(BT_SCAN_NAME_FILTER, false);
	if (err) {
		printk("Filters cannot be turned on (err %d)\n", err);
static int scan_init(void)
	int err;
	if (err) {
		LOG_ERR("Scanning filters cannot be set (err %d)", err);
		return err;
	if (err) {
		LOG_ERR("Filters cannot be turned on (err %d)", err);
		return err;
	LOG_INF("Scan module initialized");
	return err;
static void auth_cancel(struct bt_conn *conn)
	LOG_INF("Pairing cancelled: %s", log_strdup(addr));
static void pairing_complete(struct bt_conn *conn, bool bonded)
	LOG_INF("Pairing completed: %s, bonded: %d", log_strdup(addr),
		bonded);
static void pairing_failed(struct bt_conn *conn, enum bt_security_err reason)
	LOG_WRN("Pairing failed conn: %s, reason %d", log_strdup(addr),
		reason);
static struct bt_conn_auth_cb conn_auth_callbacks = {
	.cancel = auth_cancel,
static struct bt_conn_auth_info_cb conn_auth_info_callbacks = {
	.pairing_complete = pairing_complete,
	.pairing_failed = pairing_failed
void main(void)
	int err;
	err = bt_conn_auth_cb_register(&conn_auth_callbacks);
	if (err) {
		LOG_ERR("Failed to register authorization callbacks.");
		return;
	err = bt_conn_auth_info_cb_register(&conn_auth_info_callbacks);
	if (err) {
		printk("Failed to register authorization info callbacks.\n");
		return;
	err = bt_enable(NULL);
	if (err) {
		LOG_ERR("Bluetooth init failed (err %d)", err);
		return;
	LOG_INF("Bluetooth initialized");
	if (IS_ENABLED(CONFIG_SETTINGS)) {
		settings_load();
  //  bt_conn_cb_register(&conn_callback);
	int (*module_init[])(void) = {uart_init, scan_init, nus_client_init};
	for (size_t i = 0; i < ARRAY_SIZE(module_init); i++) {
		err = (*module_init[i])();
		if (err) {
			return;
	printk("Starting Bluetooth Central UART example\n");
	if (err) {
		return;
	LOG_INF("Scanning successfully started");
	for (;;) {
		// Wait indefinitely for data to be sent over Bluetooth //
		/*struct uart_data_t *buf = k_fifo_get(&fifo_uart_rx_data,
						     K_FOREVER);
		err = bt_nus_client_send(&nus_client, buf->data, buf->len);
		if (err) {
				"(err %d)", err);
				printk("Failed to send data over BLE connection"
        "(err %d)", err);
		err = k_sem_take(&nus_write_sem, NUS_WRITE_TIMEOUT);
		if (err) {
			printk("NUS send timeout");
			/* Wait indefinitely for data to be sent over Bluetooth */
						     K_FOREVER);
		multi_nus_send(buf);
		k_free(buf);
Thanks and Regards,
Muhammad Usman
  • Hi Einar!
    Thank you so much for the response!
    Is it so that you trigger this by resetting the peripheral
    Yes, you are right. I am trying to simulate that the peripheral is going to sleep mode and then wake up to send the data.
    So what is your expert opinion regarding that?
    Thanks in advance! For your response!
    I have not tested on my end, but based on what you describe and your code, I wonder if this is what is happening:
    1. The central have a connection with a perhiperal
    2. The periperal is reset
    3. The central is still connected to the peripheral until supervision timeout, but the peripheral starts advertising
    4. The central, as it is intended for multiple devices, scans even though it is still connected, and sees the old peripheral advertise and attempts to connect.  This triggers the error you see (bt_conn_le_create() calls bt_conn_exists_le() and this prints the "" error, and then bt_conn_le_create returns -EINVAL.).
    Are you able to verify that bt_conn_le_create() returns -EINVAL when this issue occurs?
    If this is the problem, you could either add some logic to avoid connecting to a device you already have a connection (using a similar method as what is used in the stack when you get this error), or you could ignore the -EINVAL return value from bt_conn_le_create(), though that may not be a good idea as there are also other reasons you could get that error code from bt_conn_le_create().
