Can nRF5340 keep two links simultaneously? One BLE audio link with another nRF5340, one custom BLE link with Smart Phone for configuration
I have kept following BLE audio since the nRF5340 audio DK was available. Recently, we came up with an idea of developing a broadcasting system. While we demoed the idea to potential customer, they required to control the BLE audio nodes with phone app, such as volume up, mute, etc. Is it possible to make a nRF5340 keep connected with 2 devices at the same time, one is on BLE audio, and another is a phone with normal BLE support? If not simultaneously, could be in the same firmware?
Thank you
Junmin
  • Hello Junmin,
    Junmin said:
    I have tested the nRF5340 LE Audio application with a Pixel 7, it's no problem to scan, bond and stream from the phone, but not vice versa. Also, at least once,I have scanned and bonded the application with nRF Connect mobile from another phone without BLE audio support, however I can't repeat the phenomenon anyhow, maybe a previous SDK version.
    I am glad to read that you were able to test this against a Pixel 7 as expected, but I am not quite sure what you mean when you say that it did not work the other way around - does this mean that you wanted the Pixel 7 to function as a peripheral with a nRF5340 Audio DK working as the central/gateway?
    If you bond the nRF5340 Audio reference application with another device then it will be using direct advertising to advertise to this specific device again by default, and so it will not be visible to other devices (unless you use a BLE sniffer to see all BLE traffic). Does the device show up again as advertising if you reprogram it? If so, the issue is likely that it is using direct advertising since it is already bonded to the other device.
    Junmin said:
    Also, I think the key point of my case is to add a peripheral role to the nRF5340 audio application in SDK, which a phone without BLE audio support can scan, bond and communicate with.
    Please see the example referenced earlier (and at the last sentence of this comment) for how you can add this to your application.
    Junmin said:
    You are right, my thread is in another file as following,
    Thank you for sharing the code - you do not need to call bt_enable again in your uart_control_sub_thread call since this is already called in your main() startup.
    It also seems to me that you are trying to register an iso server in your uart_control_sub_thread, which I am not sure why you would do, if you only wish for the NUS service to run alongside the existing CIS (that you setup in your main() already).
    Regarding your code, do you intend for the NUS service to be available alongside the other LE Audio services, or do you intend for it to be a separate connection (potentially to another device) entirely?
    In case of the former, which is the impression I have had from your earlier description, you can use this example as a reference regarding how you can add the NUS service to your gateway code.
    Karl
  • Hello Karl,
    As for the Pixel 7 test, I mean the nRF5340 audio DK board works as a BT speaker instead of headset, which can stream audio signal from Pixel 7 to the DK board but can't stream sound back to Pixel 7. The test does nothing with our current application, sorry for making you feel confused.
    Thank you for explaining me the direct advertising concept, now I understand what I have observed before.
    I intend to use a separate connection to do real time configuration, and made some progress last weekend taking the " Multiple advertising sets' example as reference.
    Best Regards
    Junmin
  • Hello Junmin,
    No worries - I will just ask for clarifications if there is somethings that are unclear to me! :)
    I am still not sure that I understand this configuration you describe correctly, unfortunately - could you possibly draw a quick diagram of the configuration you are testing with here? Will the nRF5340 Audio DK be a gateway device that sends a CIS stream to a Pixel 7, or will you use the nRF5340 Audio DK as a headset device that outputs the audio it received from the Pixel 7 to a speaker or similar?
    No problem at all, I am glad to read that this explanation matches the behavior you described.
    Do you mean a separate connection between the same devices? If so, why could you not just do these configurations over the ACL that is already established for the CIS? You can add both custom and standard services to the headset/peripheral device, which would function just as it would on a regular non-LE Audio device, or without the CIS in place.
    Karl
  • Hello Karl,
    In the Pixel 7 test, I just used the nRF5340 Audio DK as a headset device that outputs the audio it received from the Pixel 7 to a speaker, but I hope I can use it as a real headset to make phone call some day, therefore I keep following the nRF Connect SDK upgrade.
    In my application, separate connection means connection between devices and mobile phone. Fortunately I made it last weekend under our helpful discussions.
    Thank You and Best Regard
    Junmin
  • Hello Junmin,
    Thank you for clarifying, this is very helpful to know!
    As soon as the CCP and TBS services are implemented on both sides of the link this will be possible, just as you would have done it regularly :)
    Great, I am glad to hear that you got this working as intended! :)
    Karl
