Can nRF5340 keep two links simultaneously? One BLE audio link with another nRF5340, one custom BLE link with Smart Phone for configuration
I have kept following BLE audio since the nRF5340 audio DK was available. Recently, we came up with an idea of developing a broadcasting system. While we demoed the idea to potential customer, they required to control the BLE audio nodes with phone app, such as volume up, mute, etc. Is it possible to make a nRF5340 keep connected with 2 devices at the same time, one is on BLE audio, and another is a phone with normal BLE support? If not simultaneously, could be in the same firmware?
Thank you
Junmin
  • Hello Junmin,
    Thank you for your extreme patience with this - I was unfortunately out of office for the first few days of this week due to sickness, but now I am back.
    Junmin said:
    I checked my code and did some experiments, you are right, I'm attempting to use the same CIS ACL for NUS service. I though a lot and reviewed other people's related questions in DevZone, but still have no idea how to fix it, any suggestions?
    I see from your latest log that you receive the -120 error (operation already in progress) from your call to start, but it is hard for me to understand the context from which the bt_enable call was made from the code you have shared alone.
    Could you share your full main.c with me, so that I may take a look?
    Judging by this error message alone I wonder if you might be calling bt_enable elsewhere, such as in your uart_control_sub_thread? If so, please know that you only need to call bt_enable once in your main().
    Junmin said:
    At the same time, I'm trying to take the following discussion as reference,
     nRF5340 Audio DK: LE Audio and UART2 Concurrently
    Since it's based on NCS 2.20, I'll go down to this version first.
    In this case I would recommend that you instead try the same approach with v2.4, instead of downgrading to v2.2, since there are so many important LE Audio related features and improvements that have been introduced since v2.2.
    Karl
  • Hello Karl,
    Glad to know you are back from sickness!
    My main.c is as following, just adding several line on the reference application. I tried to comment out bt_enable in my thread, the error code became -112, address already in use.
     * Copyright (c) 2018 Nordic Semiconductor ASA
    #include <zephyr/kernel.h>
    #include <zephyr/debug/stack.h>
    #include <zephyr/device.h>
    #include <string.h>
    #include <zephyr/settings/settings.h>
    #include <zephyr/zbus/zbus.h>
    #include "macros_common.h"
    #include "fw_info_app.h"
    #include "led.h"
    #include "button_handler.h"
    #include "button_assignments.h"
    #include "nrfx_clock.h"
    #include "ble_core.h"
    #include "sd_card.h"
    #include "board_version.h"
    #include "audio_system.h"
    #include "channel_assignment.h"
    #include "streamctrl.h"
    //#include "ble_peripheral_uart.h"
    #include "ble_peripheral_iso.h"
    static K_SEM_DEFINE(le_audio_ok, 0, 1);
    #if defined(CONFIG_AUDIO_DFU_ENABLE)
    #include "dfu_entry.h"
    LOG_MODULE_REGISTER(main, CONFIG_MAIN_LOG_LEVEL);
    #if defined(CONFIG_INIT_STACKS)
    /* Used for printing stack usage */
    extern struct k_thread z_main_thread;
    #endif /* defined(CONFIG_INIT_STACKS) */
    static atomic_t ble_core_is_ready = (atomic_t) false;
    static struct board_version board_rev;
    ZBUS_CHAN_DECLARE(button_chan);
    ZBUS_CHAN_DECLARE(le_audio_chan);
    ZBUS_OBS_DECLARE(button_sub);
    ZBUS_OBS_DECLARE(le_audio_evt_sub);
    static int hfclock_config_and_start(void)
    	int ret;
    	/* Use this to turn on 128 MHz clock for cpu_app */
    	ret = nrfx_clock_divider_set(NRF_CLOCK_DOMAIN_HFCLK, NRF_CLOCK_HFCLK_DIV_1);
    	ret -= NRFX_ERROR_BASE_NUM;
    	if (ret) {
    		return ret;
    	nrfx_clock_hfclk_start();
    	while (!nrfx_clock_hfclk_is_running()) {
    	return 0;
    static int leds_set(void)
    	int ret;
    	/* Blink LED 3 to indicate that APP core is running */
    	ret = led_blink(LED_APP_3_GREEN);
    	if (ret) {
    		return ret;
    #if (CONFIG_AUDIO_DEV == HEADSET)
    	enum audio_channel channel;
    	channel_assignment_get(&channel);
    	if (channel == AUDIO_CH_L) {
    		ret = led_on(LED_APP_RGB, LED_COLOR_BLUE);
    	} else {
    		ret = led_on(LED_APP_RGB, LED_COLOR_MAGENTA);
    	if (ret) {
    		return ret;
    #elif (CONFIG_AUDIO_DEV == GATEWAY)
    	ret = led_on(LED_APP_RGB, LED_COLOR_GREEN);
    	if (ret) {
    		return ret;
    #endif /* (CONFIG_AUDIO_DEV == HEADSET) */
    	return 0;
    static int bonding_clear_check(void)
    	int ret;
    	bool pressed;
    	ret = button_pressed(BUTTON_5, &pressed);
    	if (ret) {
    		return ret;
    	if (pressed) {
    		if (IS_ENABLED(CONFIG_SETTINGS)) {
    			LOG_INF("Clearing all bonds");
    			bt_unpair(BT_ID_DEFAULT, NULL);
    	return 0;
    static int channel_assign_check(void)
    #if (CONFIG_AUDIO_DEV == HEADSET) && CONFIG_AUDIO_HEADSET_CHANNEL_RUNTIME
    	int ret;
    	bool pressed;
    	ret = button_pressed(BUTTON_VOLUME_DOWN, &pressed);
    	if (ret) {
    		return ret;
    	if (pressed) {
    		channel_assignment_set(AUDIO_CH_L);
    		return 0;
    	ret = button_pressed(BUTTON_VOLUME_UP, &pressed);
    	if (ret) {
    		return ret;
    	if (pressed) {
    		channel_assignment_set(AUDIO_CH_R);
    		return 0;
    	return 0;
    /* Callback from ble_core when the ble subsystem is ready */
    void on_ble_core_ready(void)
    	int ret;
    	(void)atomic_set(&ble_core_is_ready, (atomic_t) true);
    		settings_load();
    		ret = bonding_clear_check();
    		ERR_CHK(ret);
    	k_sem_give(&le_audio_ok);
    	int ret;
    	LOG_DBG("nRF5340 APP core started");
    	ret = hfclock_config_and_start();
    	ERR_CHK(ret);
    	ret = led_init();
    	ERR_CHK(ret);
    	if (IS_ENABLED(CONFIG_ZBUS) && (CONFIG_ZBUS_RUNTIME_OBSERVERS_POOL_SIZE > 0)) {
    		ret = zbus_chan_add_obs(&button_chan, &button_sub, K_MSEC(200));
    		ERR_CHK(ret);
    		ret = zbus_chan_add_obs(&le_audio_chan, &le_audio_evt_sub, K_MSEC(200));
    		ERR_CHK(ret);
    	ret = button_handler_init();
    	ERR_CHK(ret);
    	channel_assignment_init();
    	ret = channel_assign_check();
    	ERR_CHK(ret);
    	ret = fw_info_app_print();
    	ERR_CHK(ret);
    	ret = board_version_valid_check();
    	ERR_CHK(ret);
    	ret = board_version_get(&board_rev);
    	ERR_CHK(ret);
    	if (board_rev.mask & BOARD_VERSION_VALID_MSK_SD_CARD) {
    		ret = sd_card_init();
    		if (ret != -ENODEV) {
    			ERR_CHK(ret);
    	/* Check DFU BTN before initialize BLE */
    	dfu_entry_check((void *)ble_core_init);
    	/* Initialize BLE, with callback for when BLE is ready */
    	ret = ble_core_init(on_ble_core_ready);
    	ERR_CHK(ret);
    	/* Wait until ble_core/NET core is ready */
    	while (!(bool)atomic_get(&ble_core_is_ready)) {
    		(void)k_sleep(K_MSEC(100));
    	ret = leds_set();
    	ERR_CHK(ret);
    	ret = streamctrl_start();
    	ERR_CHK(ret);
        /* Don't go any further until BLE is initialized */
        k_sem_take(&le_audio_ok, K_FOREVER);
    	ret = uart_start();
    	ERR_CHK(ret);
    Another thing I always wonder is that why I can't find nRF5340 audio DK board with nRF Connect mobile, as you know, I want to do volume control with phone app, scanning devices is the first step.
    Thank you for your suggestion to stop trying on v2.2, or I would waste more time on it.
    Best Regards
    Junmin
  • Hello Junmin,
    Thank you for saying so! :)
    Oh, could you include the code where you have added the nus functionality? I incorrectly assumed that you had this added as a thread towards the end of main.c, but it seems you have that implemented in another file somewhere.
    The default nRF5340 LE Audio application will advertise using Direct Advertising in the case that it is already bonded with a peer - could this be the case here?
    Also, I think we will need to resolve the current BLE issues in order to ensure that the regular peripheral advertising actually starts in this case, before we look further into this.
    No problem at all, I am happy to help! :)
    It would be more productive to instead apply the same approach to your v2.4 based project, instead of downgrading to v2.2.
    Karl
  • Hello Karl,
    You are right, my thread is in another file as following,
     * Copyright (c) 2021 Nordic Semiconductor ASA
    #include <zephyr/types.h>
    #include <stddef.h>
    #include <string.h>
    #include <errno.h>
    #include <zephyr/sys/byteorder.h>
    #include <zephyr/bluetooth/hci.h>
    #include <zephyr/bluetooth/conn.h>
    #include <zephyr/bluetooth/iso.h>
    #include "led.h"
    LOG_MODULE_REGISTER(ble_iso);
    #define DEVICE_NAME             "Peripheral"
    #define DEVICE_NAME_LEN         (sizeof(DEVICE_NAME) - 1)
    static const struct bt_data ad[] = {
    	BT_DATA_BYTES(BT_DATA_FLAGS, (BT_LE_AD_GENERAL | BT_LE_AD_NO_BREDR)),
    	BT_DATA(BT_DATA_NAME_COMPLETE, DEVICE_NAME, DEVICE_NAME_LEN),
    static struct k_work_delayable iso_send_work;
    static struct bt_iso_chan iso_chan;
    static uint16_t seq_num;
    static atomic_t iso_tx_pool_alloc;
    NET_BUF_POOL_FIXED_DEFINE(tx_pool, 1, BT_ISO_SDU_BUF_SIZE(CONFIG_BT_ISO_TX_MTU), 8,
    			  NULL);
    #define HCI_ISO_BUF_ALLOC_PER_CHAN 2
    static void iso_timer_timeout(struct k_work *work)
    	int ret;
    	static uint8_t buf_data[CONFIG_BT_ISO_TX_MTU];
    	struct net_buf *buf;
    	static size_t len_to_send = CONFIG_BT_ISO_TX_MTU;
    	static bool hci_wrn_printed;
    	if (atomic_get(&iso_tx_pool_alloc) >= HCI_ISO_BUF_ALLOC_PER_CHAN) {
    		if (!hci_wrn_printed) {
    			LOG_WRN("HCI ISO TX overrun");
    			hci_wrn_printed = true;
    		return;
    	hci_wrn_printed = false;
    	buf = net_buf_alloc(&tx_pool, K_FOREVER);
    	net_buf_reserve(buf, BT_ISO_CHAN_SEND_RESERVE);
    	net_buf_add_mem(buf, buf_data, len_to_send);
    	atomic_inc(&iso_tx_pool_alloc);
    	ret = bt_iso_chan_send(&iso_chan, buf, seq_num++, BT_ISO_TIMESTAMP_NONE);
    	if (ret < 0) {
    		LOG_INF("Failed to send ISO data (%d)", ret);
    		net_buf_unref(buf);
    		atomic_dec(&iso_tx_pool_alloc);
    	k_work_schedule(&iso_send_work, K_MSEC(10));
    static void connected(struct bt_conn *conn, uint8_t err)
    	if (err) {
    		LOG_INF("Failed to connect to %s (%u)", addr, err);
    		return;
    	LOG_INF("Connected %s", addr);
    	LOG_INF("Disconnected from %s (reason 0x%02x)", addr, reason);
    BT_CONN_CB_DEFINE(conn_callbacks) = {
    	.connected = connected,
    	.disconnected = disconnected,
    /** Print data as d_0 d_1 d_2 ... d_(n-2) d_(n-1) d_(n) to show the 3 first and 3 last octets
     * Examples:
     * 01
     * 0102
     * 010203
     * 01020304
     * 0102030405
     * 010203040506
     * 010203...050607
     * 010203...060708
     * etc.
    static void iso_print_data(uint8_t *data, size_t data_len)
    	/* Maximum number of octets from each end of the data */
    	const uint8_t max_octets = 3;
    	char data_str[35];
    	size_t str_len;
    	str_len = bin2hex(data, MIN(max_octets, data_len), data_str, sizeof(data_str));
    	if (data_len > max_octets) {
    		if (data_len > (max_octets * 2)) {
    			static const char dots[] = "...";
    			strcat(&data_str[str_len], dots);
    			str_len += strlen(dots);
    		str_len += bin2hex(data + (data_len - MIN(max_octets, data_len - max_octets)),
    				   MIN(max_octets, data_len - max_octets),
    				   data_str + str_len,
    				   sizeof(data_str) - str_len);
    	LOG_INF("\t %s", data_str);
    static void iso_recv(struct bt_iso_chan *chan, const struct bt_iso_recv_info *info,
    		struct net_buf *buf)
    	LOG_INF("Incoming data channel %p len %u", chan, buf->len);
    	iso_print_data(buf->data, buf->len);
    static void iso_connected(struct bt_iso_chan *chan)
    	LOG_INF("ISO Channel %p connected", chan);
    	k_work_reschedule(&iso_send_work, K_MSEC(100));
    static void iso_disconnected(struct bt_iso_chan *chan, uint8_t reason)
    	LOG_INF("ISO Channel %p disconnected (reason 0x%02x)", chan, reason);
    	k_work_cancel_delayable(&iso_send_work);
    	atomic_clear(&iso_tx_pool_alloc);
    static void iso_sent(struct bt_iso_chan *chan)
    static struct bt_iso_chan_ops iso_ops = {
    	.recv		= iso_recv,
    	.connected	= iso_connected,
    	.disconnected	= iso_disconnected,
    	.sent = iso_sent,
    static struct bt_iso_chan_io_qos iso_tx = {
    	.sdu = CONFIG_BT_ISO_TX_MTU,
    	.path = NULL,
    static struct bt_iso_chan_qos iso_qos = {
    	.tx = &iso_tx,
    	.rx = NULL,
    static struct bt_iso_chan iso_chan = {
    	.ops = &iso_ops,
    	.qos = &iso_qos,
    static int iso_accept(const struct bt_iso_accept_info *info,
    		      struct bt_iso_chan **chan)
    	LOG_INF("Incoming request from %p", (void *)info->acl);
    	if (iso_chan.iso) {
    		LOG_INF("No channels available");
    		return -ENOMEM;
    	*chan = &iso_chan;
    	return 0;
    static struct bt_iso_server iso_server = {
    #if defined(CONFIG_BT_SMP)
    	.sec_level = BT_SECURITY_L1,
    #endif /* CONFIG_BT_SMP */
    	.accept = iso_accept,
    static struct k_thread uart_control_sub_thread_data;
    static k_tid_t uart_control_sub_thread_id;
    #define CONFIG_UART_CONTROL_SUB_STACK_SIZE 2048
    K_THREAD_STACK_DEFINE(uart_control_sub_thread_stack, CONFIG_UART_CONTROL_SUB_STACK_SIZE);
    static void uart_control_sub_thread(void)
    	int err;
    	err = bt_enable(NULL);
    	if (err) {
    		LOG_INF("Bluetooth init failed (err %d)", err);
    		return;
    		settings_load();
    	LOG_INF("Bluetooth initialized");
    	err = bt_iso_server_register(&iso_server);
    	if (err) {
    		LOG_INF("Unable to register ISO server (err %d)", err);
    		return;
    	err = bt_le_adv_start(BT_LE_ADV_CONN, ad, ARRAY_SIZE(ad), NULL, 0);
    	if (err) {
    		LOG_INF("Advertising failed to start (err %d)", err);
    		return;
    	LOG_INF("Advertising successfully started");
    	k_work_init_delayable(&iso_send_work, iso_timer_timeout);
    int uart_start(void)
    	int ret;
    	uart_control_sub_thread_id =
    		k_thread_create(&uart_control_sub_thread_data, uart_control_sub_thread_stack,
    						CONFIG_UART_CONTROL_SUB_STACK_SIZE,
    						(k_thread_entry_t)uart_control_sub_thread, NULL, NULL, NULL,
    						K_PRIO_PREEMPT(CONFIG_BUTTON_MSG_SUB_THREAD_PRIO), 0, K_NO_WAIT);
    	ret = k_thread_name_set(uart_control_sub_thread_id, "UART_CONTROL_SUB");
    	ERR_CHK(ret);
    	ret = led_blink(LED_APP_1_BLUE);
    	ERR_CHK(ret);
    	return 0;
    I have tested the nRF5340 LE Audio application with a Pixel 7, it's no problem to scan, bond and stream from the phone, but not vice versa. Also, at least once,I have scanned and bonded the application with nRF Connect mobile from another phone without BLE audio support, however I can't repeat the phenomenon anyhow, maybe a previous SDK version.
    Best regards and have a nice weekend,
    Junmin
  • Also, I think the key point of my case is to add a peripheral role to the nRF5340 audio application in SDK, which a phone without BLE audio support can scan, bond and communicate with.
    Junmin
